KDE error
mirko77
KDE error
Messaggio da mirko77 »
Guardate che errori mi da dando il comando seguente:
/usr/bin/startkde: line 123: kstartupconfig: command not found
/home/topolinux/.kde/share/config/startupconfig: line 1: kcminputrc: command not
 found
/home/topolinux/.kde/share/config/startupconfig: line 2: kcminputrc: command not
 found
/home/topolinux/.kde/share/config/startupconfig: line 3: kpersonalizerrc: comman
d not found
/home/topolinux/.kde/share/config/startupconfig: line 4: ksplashrc: command not
found
/home/topolinux/.kde/share/config/startupconfig: line 5: kcmrandrrc: command not
 found
/home/topolinux/.kde/share/config/startupconfig: line 6: kcmrandrrc: command not
 found
/home/topolinux/.kde/share/config/startupconfig: line 7: kcmrandrrc: command not
 found
/home/topolinux/.kde/share/config/startupconfig: line 8: kcmrandrrc: command not
 found
/home/topolinux/.kde/share/config/startupconfig: line 9: kcmrandrrc: command not
 found
startkde: Starting up...
Could not find 'krandrinithack' executable.
kbuildsycoca running...
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/kcm_kdnssd.so: undefined
symbol: init_kdnssd
kwin: it looks like there's already a window manager running. kwin not started.
KDE non parte come risolvo?
phobos3576
Kernel: 2.6.37-smp
Desktop: KDE 4.5.3
Messaggio da phobos3576 »
Ma scusa, perché devi eseguire il comando startkde?
Quel comando viene invocato dallo script startx; per la precisione (almeno in relazione alla Slack), startx esegue /etc/X11/xinit/xinitrc che è un link simbolico al window manager da usare (KDE, Gnome, etc).
mirko77
lo so. Ma non parte lo stesso.
