k3b non si installa
mirko77
k3b non si installa
Messaggio da mirko77 »
Ecco questo è il tgz
bash-3.00# installpkg k3b-0.12.14-i486-1kjz.tgz
Installing package k3b-0.12.14-i486-1kjz...
PACKAGE DESCRIPTION:
k3b: K3b - The CD Kreator
k3b:
k3b: K3b is a CD and DVD burning application for Linux systems, optimized
k3b: for KDE.  It provides a comfortable user interface to perform most
k3b: CD/DVD burning tasks, like creating an Audio CD from a set of audio
k3b: files, or copying a CD.  The actual burning in K3b is done by the
k3b: command line utilities cdrecord, cdrdao, and growisofs.
k3b: Requires: FFMpeg, FLAC, Lame, libsamplerate, libsndfile, Musepack,
k3b: MusicBrainz, Ogg Vorbis, and Taglib.
k3b: Homepage: http://www.k3b.org/
k3b: Packaged by Ken Zalewski (kennyz@nycap.rr.com)
Executing install script for k3b-0.12.14-i486-1kjz...
bash-3.00# k3b
bash: k3b: command not found
bash-3.00#
Questo è il tar.bz2:
K3b Configure results:
Ogg Vorbis support:                    yes
Mp3 decoding support (libmad):         yes
Audio meta data reading with Taglib:   yes
libsndfile audio decoding support:     yes
FLAC support:                          yes
Musepack support:                       no
    You are missing the Musepack headers and libraries >= 1.1.
    The Musepack audio decoding plugin won't be compiled.
Lame Mp3 encoder plugin:               yes
Audio resampling:
            using version bundled with K3b
FFMpeg decoder plugin (decodes wma and others):
                                        no
    You are missing the ffmpeg headers and libraries
    version 0.4.9 or higher.
    The ffmpeg audio decoding plugin (decodes wma and
    others) won't be compiled.
Resmgr support:                         no
Audioplayer available (aRts)           yes
Compile K3bSetup 2:                    yes
Tag guessing using MusicBrainz         yes
Compile HAL support                     no
    You are missing the HAL >= 0.4 headers and libraries
    or the DBus Qt bindings.
Good - your configure finished. Start make now
Dopo aver estratto così: tar -xjvf k3b.tar.bz2
e dato ./configure poi make e make install da root scrivo k3b è questo è il risultato:
Making install in audioprojectcddb
make[3]: Entering directory `/home/topolinux/k3b-0.12.14/plugins/project/audioprojectcddb'
make[4]: Entering directory `/home/topolinux/k3b-0.12.14/plugins/project/audioprojectcddb'
/bin/sh ../../../admin/mkinstalldirs /opt/kde/lib
 /bin/sh ../../../libtool --silent --mode=install /usr/bin/ginstall -c -p  libk3baudioprojectcddbplugin.la /opt/kde/lib/libk3baudioprojectcddbplugin.la
PATH="$PATH:/sbin" ldconfig -n /opt/kde/lib
/bin/sh ../../../admin/mkinstalldirs /opt/kde/share/apps/k3b/plugins
 /usr/bin/ginstall -c -p -m 644 k3baudioprojectcddbplugin.plugin /opt/kde/share/apps/k3b/plugins/k3baudioprojectcddbplugin.plugin
make[4]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project/audioprojectcddb'
make[3]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project/audioprojectcddb'
Making install in audiometainforenamer
make[3]: Entering directory `/home/topolinux/k3b-0.12.14/plugins/project/audiometainforenamer'
make[4]: Entering directory `/home/topolinux/k3b-0.12.14/plugins/project/audiometainforenamer'
 /bin/sh ../../../libtool --silent --mode=install /usr/bin/ginstall -c -p  libk3baudiometainforenamerplugin.la /opt/kde/lib/libk3baudiometainforenamerplugin.la
 /usr/bin/ginstall -c -p -m 644 k3baudiometainforenamerplugin.plugin /opt/kde/share/apps/k3b/plugins/k3baudiometainforenamerplugin.plugin
make[4]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project/audiometainforenamer'
make[3]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project/audiometainforenamer'
make[3]: Entering directory `/home/topolinux/k3b-0.12.14/plugins/project'
make[4]: Entering directory `/home/topolinux/k3b-0.12.14/plugins/project'
make[4]: Nothing to be done for `install-exec-am'.
make[4]: Nothing to be done for `install-data-am'.
make[4]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project'
make[3]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project'
make[2]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins/project'
make[2]: Entering directory `/home/topolinux/k3b-0.12.14/plugins'
make[3]: Entering directory `/home/topolinux/k3b-0.12.14/plugins'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins'
make[2]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins'
make[1]: Leaving directory `/home/topolinux/k3b-0.12.14/plugins'
Making install in k3bsetup
make[1]: Entering directory `/home/topolinux/k3b-0.12.14/k3bsetup'
make[2]: Entering directory `/home/topolinux/k3b-0.12.14/k3bsetup'
/bin/sh ../admin/mkinstalldirs /opt/kde/bin
 /usr/bin/ginstall -c -p k3bsetup /opt/kde/bin/k3bsetup
/bin/sh ../admin/mkinstalldirs /opt/kde/lib/kde3
 /bin/sh ../libtool --silent --mode=install /usr/bin/ginstall -c -p  kcm_k3bsetup2.la /opt/kde/lib/kde3/kcm_k3bsetup2.la
PATH="$PATH:/sbin" ldconfig -n /opt/kde/lib/kde3
/bin/sh ../admin/mkinstalldirs /opt/kde/share/applnk/Settings/System
 /usr/bin/ginstall -c -p -m 644 k3bsetup2.desktop /opt/kde/share/applnk/Settings/System/k3bsetup2.desktop
make[2]: Leaving directory `/home/topolinux/k3b-0.12.14/k3bsetup'
make[1]: Leaving directory `/home/topolinux/k3b-0.12.14/k3bsetup'
make[1]: Entering directory `/home/topolinux/k3b-0.12.14'
make[2]: Entering directory `/home/topolinux/k3b-0.12.14'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/home/topolinux/k3b-0.12.14'
make[1]: Leaving directory `/home/topolinux/k3b-0.12.14'
bash-3.00# k3b
bash-3.00#
Che devo fare?
l1q1d
Messaggio da l1q1d »
invece di fare
su
devi fare
su -
in quanto il path di su non comprende anche /opt/kde/bin quindi non vede k3b
mirko77
fatto ma non funziona lo stesso
l1q1d
hai provato a vedere se esiste nella directory /opt/kde/bin ?
samiel
Nome Cognome: Mauro Sacchetto
Kernel: 2.26
Distribuzione: anche Debian
Messaggio da samiel »
Dovresti trovarlo comunque, ma prova a passare
DESTDIR=/opt/kde al configure...
M.
mirko77
l1q1d ha scritto:hai provato a vedere se esiste nella directory /opt/kde/bin ?
No non esiste
mirko77
samiel ha scritto:Dovresti trovarlo comunque, ma prova a passare
M.
Io penso che su /opt/kde ci scrive solo che non mette il bin comunque ora provo a fare come hai detto tu e vi faccio sapere
mirko77
Ho fatto un'altro paio di prove e dopo aver installato il tgz ho fatto /opt/kde/k3b
ed è partito ( strano ) prima mi partiva facendo soltanto k3b forse sarà il pacchetto nuovo boh comunque risolto :D
samiel
Kernel: 2.26
Fose ti manca il path /opt/kde/bin
M.
