MythTV
- linus.bash
MythTV
Ho installato i TGZ di :
mythtv-0.19-i486-1sal.tgz
mythplugins-0.19-i486-1sal.tgz
libcdaudio-0.99.12p2-i486-1sal.tgz
lame-3.97b2-i486-1sl.tgz
jack-audio-connection-kit-0.100.0-i486-2sl.tgz
Ricevo questo errore ed il prg non si apre :
No error type from QSqlError? Strange...
2006-05-06 16:29:59.706 Database not open while trying to save setting: Language
2006-05-06 16:29:59.707 Unable to connect to database!
2006-05-06 16:29:59.707 Driver error was [1/2002]:
QMYSQL3: Unable to connect
Database error was:
Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2)
QSqlQuery::exec: database not open
2006-05-06 16:29:59.758 DB Error (KickDatabase):
Query was:
SELECT NULL;
2006-05-06 16:30:07.879 Unable to connect to database!
2006-05-06 16:30:07.879 Driver error was [1/2002]:
Database error was:
2006-05-06 16:30:07.938 DB Error (KickDatabase):
Query was:
SELECT NULL;
2006-05-06 16:30:07.991 Failed to init MythContext, exiting.
Database error was:
Query was:
SELECT NULL;
Database error was:
Query was:
SELECT NULL;
- linus.bash
- linus.bash
L'errore continua ad esserci :
...ecco il finale :
2006-05-09 18:33:16.495 DB Error (KickDatabase):
Query was:
SELECT NULL;
2006-05-09 18:33:16.547 Database not open while trying to load setting: GuiVidModeResolution
2006-05-09 18:33:16.548 Unable to connect to database!
2006-05-09 18:33:16.548 Driver error was [1/2002]:
Database error was:
2006-05-09 18:33:25.224 DB Error (KickDatabase):
Query was:
SELECT NULL;
2006-05-09 18:33:33.034 Unable to connect to database!
2006-05-09 18:33:33.034 Driver error was [1/2002]:
Database error was:
2006-05-09 18:33:33.084 DB Error (KickDatabase):
Query was:
SELECT NULL;
2006-05-09 18:33:33.136 Failed to init MythContext, exiting.
...ecco il finale :
Query was:
SELECT NULL;
Database error was:
Query was:
SELECT NULL;
Database error was:
Query was:
SELECT NULL;
- linus.bash
Pensavo che si servisse di Sqlite, invece usa MySql. Quindi ti tocca configurare il DataBASe
Riprendo un passo di S4D!
Poi ti conviene usare una guida.
8.16. Eliminare il messaggio "mySQL ended"
Per eliminare il messaggio "mySQL ended" all'avvio del programma bisogna abilitarlo: si tratta della prima operazione da fare se si vuole adoperare questo database. È necessario in prima istanza scegliere uno dei quattro file /etc/my.huge.conf, /etc/my.large.conf, /etc/my.medium.conf, /etc/my.small.conf e copiarlo sempre in /etc rinominandolo /etc/my.conf. La scelta dipende dalle dimensioni che intendiamo attribuire al nostro database. Quindi bisogna lanciare in sequenza i seguenti comandi: 1) mysql_install_db, 2) cd /var/lib, 3) chown -R mysql mysql/, 4) chgrp -R mysql mysql/. In tal modo mySQL viene attivato. Eccede dalla presenta trattazione l'uso di questo database.
