Klear
linus.bash
Klear
Messaggio da linus.bash »
root@darkstar:~ # klear
Starting up Klear version 0.5.4
Current configuration-version: 16
Needed configuration-version: 16
Klear config loaded
EIT vector set up
Playback Engine added to GUI
Starting exception protected startup
Window resized to last value
Loading channels list
Channelsconf is:/root/.klear//channels.conf
ControllerMain: Channels list found. Reading in....
Channellist loaded
KCrash: Application 'klear' crashing...
root@darkstar:~ #
A parte che non ho trovato un channel.conf con canali italiani ma non capisco perchè craschaaa. Ho installato anche scons per sicurezza ma niente.
Volevo solo provare altri prg per DVB ma questo neanche si apre. Eppure mi sembra che non ha dipendenze.Xchè?
Ecco il backtrace :
(no debugging symbols found)
Using host libthread_db library "/lib/tls/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1232275776 (LWP 9993)]
[New Thread -1232966736 (LWP 9994)]
0xb700a01c in __nanosleep_nocancel () from /lib/tls/libc.so.6
#0 0xb700a01c in __nanosleep_nocancel () from /lib/tls/libc.so.6
#1 0xb703399a in usleep () from /lib/tls/libc.so.6
#2 0x080d687d in CKlearControllerMain::TuneChannel ()
#3 0x080cfb79 in CKlearControllerMain::startUp ()
#4 0x080cf299 in CKlearControllerMain::CKlearControllerMain ()
#5 0x080e9cbf in main ()
