Php 5 e Apache 2
polmol
Php 5 e Apache 2
Messaggio da polmol »
Salve, ho bisogno di apache 2 e php 5 ( devo iniziare ad usare le classi in php... :? ). Con il vecchio apache 1.3 e php 4 non avevo problemi ma ora sono incasinatissimo.
Su slacky non ho trovato nessun pacchetto così mi sono buttato su linuxpackages ed ho trovato queste 2 versioni:
php http://www.linuxpackages.net/pkg_details.php?id=9221
apache http://www.linuxpackages.net/pkg_details.php?id=9220
Ho rimosso apache 1.3 e php 4 e installato apache 2 e php 5.
Con apache non ho problemi si avvia senza dare warning o errori ma php non ne vuole sapere di funzionare e se da console digito php mi da questa sequenza di warning:
  • PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/interbase.so' - libfbclient.so.1: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/mysql.so' - libmysqlclient.so.14: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/mysqli.so' - libmysqlclient.so.14: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/odbc.so' - libodbc.so.1: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/pdo_firebird.so' - libfbclient.so.1: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/pdo_mysql.so' - libmysqlclient.so.14: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/pdo_odbc.so' - libodbc.so.1: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/pdo_pgsql.so' - libpq.so.4: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/pdo_sqlite.so' - libsqlite3.so.0: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/pgsql.so' - libpq.so.4: cannot open shared object file: No such file or directory in Unknown on line 0
    PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php/extensions/no-debug-non-zts-20050922/sqlite.so' - libsqlite.so.0: cannot open shared object file: No such file or directory in Unknown on line 0
Mi date una mano??dove posso trovare un tgz di php5 funzionante per slack???che diavolo di problema è il mio?
help me please!!!
Bakkio2
Nome Cognome: Carlo B.
Slackware: 13.37 64
Kernel: 2.6.33.4-smp
Desktop: kde-4.4.3
Messaggio da Bakkio2 »
Frose più che disinstallare e reinstallare i pacchetti, ti conveniva fare un upgrade, comunque dal post che hai fatto, non sembra che il pacchetto installato sia difettoso, ma sembra che gli manchino delle dipendenze, o che siano state installate in directory diverse da quelle che lui si aspetta.
Darathorn
Nome Cognome: Francesco Braga
Slackware: 12.1
Kernel: 2.6.24.5-smp
Desktop: fluxbox
Messaggio da Darathorn »
http://www.slackware.com
packages current testing :)
ftp://ftp.unina.it/pub/linux/distributi ... i486-2.tgz
ecco a te
a me va con apache 1.3.35 senza problemi :)
