non riesco a modificare la risoluzione del monitor da 800*600 a 1024!!!
<BR>scheda video matrox g400+32kb
<BR>ho fatto molte prove con xorg...ma niente non parte piu´ X e ho dovuto reinstallare chi mi aiuta perchè cosi si vede da schifo....<br>
matrox g400+ADI 5P+ 17.
samiel
- Slackware: 13.0
- Kernel: 2.26
- Desktop: KDE
- Distribuzione: anche Debian
Prova a postare
<BR>la sezione sul monitor
<BR>del tuo xorg.conf
<BR>M.<br>
<BR>M.<br>
eccola.
<BR># Monitor section
<BR># **********************************************************************
<BR># Any number of monitor sections may be present
<BR>Section "Monitor"
<BR> Identifier "My Monitor"
<BR># HorizSync is in kHz unless units are specified.
<BR># HorizSync may be a comma separated list of discrete values, or a
<BR># comma separated list of ranges of values.
<BR># NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR´S
<BR># USER MANUAL FOR THE CORRECT NUMBERS.
<BR> HorizSync 31.5 - 50.0
<BR># HorizSync 30-64 # multisync
<BR># HorizSync 31.5, 35.2 # multiple fixed sync frequencies
<BR># HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
<BR># VertRefresh is in Hz unless units are specified.
<BR># VertRefresh may be a comma separated list of discrete values, or a
<BR> VertRefresh 40-90
<BR>EndSection
<BR># Graphics device section
<BR># Any number of graphics device sections may be present
<BR>Section "Device"
<BR> Identifier "VESA Framebuffer"
<BR> Driver "vesa"
<BR> #VideoRam 4096
<BR> # Insert Clocks lines here if appropriate
<BR>EndSection
<BR># Screen sections
<BR># Any number of screen sections may be present. Each describes
<BR># the configuration of a single screen. A single specific screen section
<BR># may be specified from the X server command line with the "-screen"
<BR># option.
<BR>Section "Screen"
<BR> Identifier "Screen 1"
<BR> Device "VESA Framebuffer"
<BR> Monitor "My Monitor"
<BR># If your card can handle it, a higher default color depth (like 24 or 32)
<BR># is highly recommended.
<BR># DefaultDepth 8
<BR># DefaultDepth 16
<BR> DefaultDepth 24
<BR># DefaultDepth 32
<BR># "1024x768" is also a conservative usable default resolution. If you
<BR># have a better monitor, feel free to try resolutions such as
<BR># "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
<BR># card/monitor can produce)
<BR> Subsection "Display"
<BR> Depth 8
<BR> Modes "1024x768" "800x600" "640x480"
<BR> EndSubsection
<BR> Depth 16
<BR> EndSubsection
<BR> Depth 24
<BR> EndSubsection
<BR> Depth 32
<BR> EndSubsection
<BR>EndSection
<BR># ServerLayout sections.
<BR># Any number of ServerLayout sections may be present. Each describes
<BR># the way multiple screens are organised. A specific ServerLayout
<BR># section may be specified from the X server command line with the
<BR># "-layout" option. In the absence of this, the first section is used.
<BR># When now ServerLayout section is present, the first Screen section
<BR># is used alone.
<BR>Section "ServerLayout"
<BR># The Identifier line must be present
<BR> Identifier "Simple Layout"
<BR># Each Screen line specifies a Screen section name, and optionally
<BR># the relative position of other screens. The four names after
<BR># primary screen name are the screens to the top, bottom, left and right
<BR># of the primary screen. In this example, screen 2 is located to the
<BR># right of screen 1.
<BR> Screen "Screen 1"
<BR># Each InputDevice line specifies an InputDevice section name and
<BR># optionally some options to specify the way the device is to be
<BR># used. Those options include "CorePointer", "CoreKeyboard" and
<BR># "SendCoreEvents".
<BR> InputDevice "Mouse1" "CorePointer"
<BR> InputDevice "Keyboard1" "CoreKeyboard"
<BR>EndSection
<BR><br>
<BR>EndSection
<BR> Driver "vesa"
<BR> #VideoRam 4096
<BR>EndSection
<BR># option.
<BR> Depth 8
<BR> EndSubsection
<BR> Depth 16
<BR> EndSubsection
<BR> Depth 24
<BR> EndSubsection
<BR> Depth 32
<BR> EndSubsection
<BR>EndSection
<BR>EndSection
<BR><br>
samiel
- Slackware: 13.0
- Kernel: 2.26
- Desktop: KDE
Prova a sostituire
<BR>==========================
<BR>Subsection "Display"
<BR> Depth 8
<BR> EndSubsection
<BR> Depth 16
<BR> EndSubsection
<BR> Depth 24
<BR> EndSubsection
<BR> Depth 32
<BR> EndSubsection
<BR>===============================
<BR>con
<BR> Depth 8
<BR> Modes "1280x1024 1024x768" "800x600" "640x480"
<BR> EndSubsection
<BR> Depth 16
<BR> EndSubsection
<BR> Depth 24
<BR> EndSubsection
<BR> Depth 32
<BR> EndSubsection
<BR><br>
<BR> Depth 8
<BR> EndSubsection
<BR> Depth 16
<BR> EndSubsection
<BR> Depth 24
<BR> EndSubsection
<BR> Depth 32
<BR> EndSubsection
<BR>con
<BR> Depth 8
<BR> EndSubsection
<BR> Depth 16
<BR> EndSubsection
<BR> Depth 24
<BR> EndSubsection
<BR> Depth 32
<BR> EndSubsection
<BR><br>
