Ho Slackware 10.2 e ho un problema con Wine: quando provo a lanciare un eseguibile mi restituisce questo errore.
wine: creating configuration directory '/home/daniele/.wine'...
wine: Unhandled page fault on write access to 0x003ffd80 at address 0x609033af (thread 0009), starting debugger...
wine: Unhandled page fault on write access to 0x003ffd80 at address 0x609083af (thread 000b), starting debugger...
err:seh:raise_exception Unhandled exception code c0000005 flags 0 addr 0x6000b3a3
wine: wineprefixcreate failed while creating '/home/daniele/.wine'.
daniele@DANIELELAP:~/LoveDeath3$ wine: Unhandled page fault on write access to 0x003ffd80 at address 0x609083af (thread 000d), starting debugger...
daniele@DANIELELAP:~/LoveDeath3$ err:seh:raise_exception Unhandled exception code c0000005 flags 0 addr 0x6000b3a3
wineserver: could not save registry branch to /home/daniele/.wine-iDAXj4/system.reg : No such file or directory
wineserver: could not save registry branch to /home/daniele/.wine-iDAXj4/user.reg : No such file or directory
Questo errore si presenta sia da root che da user.
