We are waiting for the new SlackWare 11, for build new packages! But you can compile it, with Jasper, Libiconv, GnupgMe and GNOME installed!
In my SlackWare 10.2 i need to disable gtktest and glibtest, for compile it.
I write this SlackBuild i hope can help you, for package please wait the new SlackWare 11.
This program seem to be very nice!
#!/bin/sh
# Heavily based on the Slackware 10.2 SlackBuild
http://gyachi.sourceforge.net
# Packagers Gohanz ( gohanz @ infinito.it)
http://www.slacky.it
# Required: GnupgMe; Jasper; LibIconv; GNOME
CWD=`pwd`
if ["$TMP" = ""]; then
TMP=/tmp
fi
PKG=$TMP/package-gyachi
NAME=gyachi
VERSION=1.0.5
TARGET=i486
ARCH=${ARCH:-i486}
BUILD=1as
if [ "$ARCH" = "i486" ]; then
SLKCFLAGS="-O2 -march=i486 -mcpu=i686"
elif [ "$ARCH" = "i686" ]; then
SLKCFLAGS="-O2 -march=i686 -mcpu=i686"
SLKCFLAGS="-O2"
elif [ "$ARCH" = "athlonxp" ]; then
SLKCFLAGS="-O3 -march=athlon-xp -mcpu=athlon-xp -pipe -fomit-frame-pointer -ffast-math -mmmx -m3dnow -msse -mfpmath=sse"
fi
if [ ! -d $TMP ]; then
mkdir -p $TMP
fi
if [ ! -d $PKG ]; then
mkdir -p $PKG
fi
cd $TMP
tar xvzf $CWD/$NAME-$VERSION.tar.gz
echo "+-----------------------------------+"
echo "| Starting SlackBuild $NAME-$VERSION |"
cd $NAME-$VERSION
find . -perm 777 -exec chmod 755 {} \;
find . -perm 775 -exec chmod 755 {} \;
find . -perm 555 -exec chmod 755 {} \;
find . -perm 666 -exec chmod 644 {} \;
find . -perm 664 -exec chmod 644 {} \;
find . -perm 444 -exec chmod 644 {} \;
chown -R root.root .
CFLAGS="$SLKCFLAGS" \
./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var \
--disable-gtktest \
--disable-glibtest \
--program-prefix="" \
--program-suffix="" \
$TARGET-slackware-linux
make
make install DESTDIR=$PKG
( cd $PKG
find . | xargs file | grep "executable" | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
find . | xargs file | grep "shared object" | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
find . | xargs file | grep "current ar archive" | cut -f 1 -d : | xargs strip -g 2> /dev/null
mkdir -p $PKG/usr/doc/$NAME-$VERSION
cp -a ABOUT-NLS ChangeLog \
mkdir -p $PKG/install
cd $CWD
cp -a *.SlackBuild slack-desc $PKG/usr/doc/$NAME-$VERSION
chown -R root:root $PKG/usr/doc/$NAME-$VERSION
chown -R root:root $PKG/usr/bin
cd $PKG
requiredbuilder -v -y -s $CWD $PKG
makepkg -l y -c n $CWD/$NAME-$VERSION-$ARCH-$BUILD.tgz
if [ "$1" = "--cleanup" ]; then
rm -rf $TMP/$NAME-$VERSION
rm -rf $PKG
fi
