ciao ragazzi,ho da poco tentato di installarmi da sorgenti il programma Video DVD::RIP ma ho problemi a causa delle molte dipendenze...
mi richied gtk che a sua volta richiede
-glib-2.0 >= 2.8.5
-atk >= 1.0.1
-pango >= 1.9.0
-cairo >= 0.9.2...
ma una volta installato glib 2.8.6,provando ad installare atk e eseguendo
checking for GLIB - version >= 2.5.7... no
*** Could not run GLIB test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GLIB is incorrectly installed.
checking for pkg-config... (cached) /usr/bin/pkg-config
checking for GLIB - version >= 2.0.0... no
configure: error:
*** GLIB 2.0.0 or better is required. The latest version of
*** GLIB is always available from ftp://ftp.gtk.org/. If GLIB is installed
*** but not in the same location as pkg-config add the location of the file
*** glib-2.0.pc to the environment variable PKG_CONFIG_PATH.
poi...ho provato in qualsiasi modo ad installare le dipendenze e quando eseguo dvdrip mi da:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_COLLATE = "C",
LANG = "en_US"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Can't locate Locale/TextDomain.pm in @INC (@INC contains: lib /usr/lib/perl5/5.8.4/i486-linux /usr/lib/perl5/5.8.4 /usr/lib/perl5/site_perl/5.8.4/i486-linux /usr/lib/perl5/site_perl/5.8.4 /usr/lib/perl5/site_perl .) at /usr/bin/dvdrip line 21.
BEGIN failed--compilation aborted at /usr/bin/dvdrip line 21.
non mi capisco piu...se per favore mi date una mano e mi spiegate passo x passo come fare ve ne sarei molto grato
...grazie!
configure: error:
se hai installato le glib controlla di avere il file glib-2.0.pc
dovrebbe stare o in /usr/lib/pkgconfig/ oin /usr/local/lib/pkgconfig o alternativamente puoi modificare la variabile PKG_CONFIG_PATH perchè contenga il path di quel file.
elmetal ha scritto:ciao ragazzi,ho da poco tentato di installarmi da sorgenti il programma Video DVD::RIP ma ho problemi a causa delle molte dipendenze...
-glib-2.0 >= 2.8.5
-atk >= 1.0.1
-pango >= 1.9.0
-cairo >= 0.9.2...
configure: error:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_COLLATE = "C",
LANG = "en_US"
...grazie!
