ati 8.28.8, radeon 9200se
Luke88
Kernel: 2.6.30-zen4
Desktop: xfce4
Messaggio da Luke88 »
uff... ancora problemi ati...
allora... ottengo dallo schermo i 1280x1024, ma fglrxinfo dice che ho caricato ancora i mesa, quindi niente accellerazione 3d...
sono su slackware curent, devo usare i driver "vecchi" perchè i nuovi non supportano la scheda video...
ho fatto la solita trafila: install da .run, compilo e installo il modulo da /lib/modules/fglrx...., nessun errore, do aticonfig --initial che mi modifica xorg.conf, e mi rivedo lo xorg.conf generato, ho messo questa riga in fstab:
shm /dev/shm tmpfs defaults 0 0
e non va...
vi posto xorg.conf e `cat /var/log/Xorg.o.log|grep WW`
Section "ServerLayout"
        Identifier     "Simple Layout"
        Screen         "aticonfig-Screen[0]"
        InputDevice    "Mouse1" "CorePointer"
        InputDevice    "Keyboard1" "CoreKeyboard"
EndSection
Section "Files"
        RgbPath      "/usr/X11R6/lib/X11/rgb"
        FontPath     "/usr/X11R6/lib/X11/fonts/local/"
        FontPath     "/usr/X11R6/lib/X11/fonts/misc/"
        FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/Type1/"
        FontPath     "/usr/X11R6/lib/X11/fonts/CID/"
        FontPath     "/usr/X11R6/lib/X11/fonts/Speedo/"
        FontPath     "/usr/X11R6/lib/X11/fonts/75dpi/"
        FontPath     "/usr/X11R6/lib/X11/fonts/100dpi/"
        FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic/"
EndSection
Section "dri"
        Mode    0666
EndSection
Section "Module"
        SubSection "extmod"
        EndSubSection
        Load  "type1"
        Load  "freetype"
        Load  "glx"
        Load  "dri"
EndSection
Section "InputDevice"
    Option     "XkbModel"      "pc105"
    Option     "XkbLayout"     "it"
        Identifier  "Keyboard1"
        Driver      "kbd"
EndSection
        Identifier  "Mouse1"
        Driver      "mouse"
        Option      "Protocol" "IMPS/2"
        Option      "Device" "/dev/mouse"
EndSection
Section "Monitor"
        Identifier   "My Monitor"
        HorizSync    31.5 - 50.0
        VertRefresh  40.0 - 90.0
EndSection
Section "Monitor"
        Identifier   "aticonfig-Monitor[0]"
        Option      "VendorName" "ATI Proprietary Driver"
        Option      "ModelName" "Generic Autodetecting Monitor"
        Option      "DPMS" "true"
EndSection
Section "Device"
        Identifier  "aticonfig-Device[0]"
        BusID       "PCI:1:0:0"
        Driver      "fglrx"
EndSection
Section "Screen"
        Identifier "aticonfig-Screen[0]"
        Device     "aticonfig-Device[0]"
        Monitor    "aticonfig-Monitor[0]"
        DefaultDepth     24
        SubSection "Display"
                Viewport   0 0
                Depth     8
        EndSubSection
                Viewport   0 0
                Depth     16
        EndSubSection
                Viewport   0 0
                Depth     24
        EndSubSection
                Viewport   0 0
                Depth     32
        EndSubSection
EndSection
ora i warning da /var/log/Xorg.conf
grep WW /var/log/Xorg.conf ha scritto: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(WW) `fonts.dir' not found (or not valid) in "/usr/X11R6/lib/X11/fonts/local/".
(WW) `fonts.dir' not found (or not valid) in "/usr/X11R6/lib/X11/fonts/Speedo/".
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed! *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO) *
(WW) fglrx(0): * no 3D acceleration available *
(WW) fglrx(0): ********************************************* *
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(WW) fglrx(0): * DRI initialization disabled! *
lspci|grep ATI ha scritto: 01:00.0 VGA compatible controller: ATI Technologies Inc RV280 [Radeon 9200 SE] (rev 01)
01:00.1 Display controller: ATI Technologies Inc RV280 [Radeon 9200 SE] (Secondary) (rev 01)
io non so che fare... mi sembra di avere fatto tutto, ma non capisco perchè non va...
avete idee?
Grazie, Luke
syaochan
Nome Cognome: Christian
Slackware: current 64
Kernel: 2.6.38.7
Desktop: KDE 4.5.5
Messaggio da syaochan »
Non e' che anche qui come su ubuntu, i driver ati proprietari sovrascrivono una libreria (libGL?), che bisogna poi rimettere "a manina" al suo posto, altrimenti non funziona opengl?
goldy
Slackware: Current
Kernel: 2.6.26.5
Desktop: KDE 3.5.10
Messaggio da goldy »
La mia riga in /etc/fstab è questa
tmpfs     /dev/shm           tmpfs        defaults            0   0
e in più ,non so perchè, ma ho dovuto mettere in
/etc/rc/rc.local
mount -a /dev/shm
perchè ad ogni riavvio non avevo più l'accelerazione
aLvArO
Nome Cognome: alessio
Kernel: 2.6.30-rc8-smp
Desktop: kde 4.2.4
Messaggio da aLvArO »
nel kernel drm dri sono abilitati? agp è abilitato? hai tolto tutti i moduli relativi alle altre skede video comprese la tua ati lasciando solo quella per il tuo cip?
comunque se cerchi ci sono altri forum dove ci sono da eseguire altri passaggi oltre aquelli che hai fatto tu soprattutto x il kernel visto che tu nn hai citato passaggi che riguardano la ricompilazione
Paoletta
Slackware: 14.2 - 64 bit
Desktop: fluxbox
Messaggio da Paoletta »
Luke88
Kernel: 2.6.30-zen4
Desktop: xfce4
grazie dei consigli... allora...
il problema della libGL.so.1.2 da sostituire non mi sembra ci sia, poichè riguardava versioni precedenti dei driver, comunque ho provato a sostituirla con quella che avevo usato per i vecchi driver e il risultato è lo stesso...
`mount` mi dice che shm è montato, che ha 252 mb e ne usa 0... la mia scheda però ha 128 mb, shm non doveva essere la memoria video?
avevo già provato l'altra riga in fstab, non ho notato differenze, viene montata uguale, stessa dimensione, niente accellerazione.
per il kernel (2.6.17.11):
grep -i drm .config
CONFIG_DRM=m
# CONFIG_DRM_TDFX is not set
# CONFIG_DRM_R128 is not set
CONFIG_DRM_RADEON=m
# CONFIG_DRM_MGA is not set
# CONFIG_DRM_SIS is not set
# CONFIG_DRM_VIA is not set
# CONFIG_DRM_SAVAGE is not set
grep -i agp .config:
CONFIG_AGP=m
# CONFIG_AGP_ALI is not set
CONFIG_AGP_ATI=m
# CONFIG_AGP_AMD is not set
# CONFIG_AGP_AMD64 is not set
# CONFIG_AGP_INTEL is not set
# CONFIG_AGP_NVIDIA is not set
# CONFIG_AGP_SIS is not set
# CONFIG_AGP_SWORKS is not set
# CONFIG_AGP_VIA is not set
# CONFIG_AGP_EFFICEON is not set
grep -i dri .config:
# Firmware Drivers
# Bluetooth device drivers
# Device Drivers
# Generic Driver Options
# Please see Documentation/ide.txt for help/info on IDE drives
# SCSI low-level drivers
# Old CD-ROM drivers (not SCSI, not IDE)
# Device Drivers
# Protocol Drivers
# Input Device Drivers
# Serial drivers
# Watchdog Device Drivers
# Ftape, the floppy tape device driver
# CONFIG_RAW_DRIVER is not set
# Console display driver support
# USB Host Controller Drivers
# USB Device Class drivers
# USB port drivers
# USB Miscellaneous drivers
# LED drivers
ho anche cercato un po' a mano, ma non trovo niente per il dri... mi potete dire dove dovrebbe essere? Grazie.
aLvArO
Desktop: kde 4.2.4
allora
CONFIG_AGP=m
CONFIG_AGP_ATI=m
il mio è così:CONFIG_AGP_ATI is not set infatti nn ci deve essere nessum modulo della ati e poi visto che ho un ati su via CONFIG_AGP_VIA=m
come ho scritto prima nessun modulo che riguarda la skeda video ma solo quello per il cipset
ti allego anche questo http://www.slacky.it/forum/viewtopic.ph ... ight=fglrx
e questo http://www.slacky.it/forum/viewtopic.ph ... ight=fglrx[/code][/b][/quote]
Luke88
Kernel: 2.6.30-zen4
Desktop: xfce4
ok, proverò a ricompilarmi il kernel, per ora ho provato solo ad aggiungere il modulo intel_agp (il mio a quanto dice lshw usa i chip intel) l'ho caricato e ricaricato fglrx, ora ho agpgart che è usato sia da fglrx sia da intel_agp,
devi ricompilare il kernel andando in Device Drivers ---> Memory Technology Devices (MTD) ---> RAM/ROM/Flash chip drivers ---> e abilitare Detect flash chips by Common Flash Interface (CFI) probe
fatto e caricati.
ho lasciato solo i drm generici pure.
`grep -i drm .config|grep -v "#"`
CONFIG_DRM=m
`grep -i agp .config|grep -v "#"`
CONFIG_AGP=m
CONFIG_AGP_INTEL=m
lsmod dice che ho caricato agpgart, intel_agp,fglrx...
per ora continua a non funzionare...
non ho ricompilato tutto il kernel, visto che era tutto modulo mi sono imitato a dare un make modules && make modules_install e poi un reboot...
il drm però non me lo lascia caricare...
# modprobe drm
FATAL: Error inserting drm (/lib/modules/2.6.17.11/kernel/drivers/char/drm/drm.ko): Cannot allocate memory
Paoletta
Desktop: fluxbox
il drm non ti serve, è una dipendenza del modulo radeon (i driver ati fatti dagli sviluppatori del kernel)
