mi scuso anticipatamente per la lunghezza del post....
Eseguendo dmesg ho ottenuto il seguente output e vorrei sapere gentilmente se è normale (a me non sembra!!!)
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
r8169: eth0: link up
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
ip_tables: (C) 2000-2006 Netfilter Core Team
eth0: no IPv6 routers present
PPP BSD Compression module registered
IN=ppp0 OUT= MAC= SRC=82.255.126.210 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=35 ID=34111 DF PROTO=TCP SPT=1910 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.255.126.210 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=35 ID=34400 DF PROTO=TCP SPT=1910 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.255.126.210 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=35 ID=34401 DF PROTO=TCP SPT=1910 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.116.59 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=62373 DF PROTO=TCP SPT=29116 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.116.59 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=63163 DF PROTO=TCP SPT=29116 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.49.102.121 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=43 ID=56590 DF PROTO=TCP SPT=2107 DPT=445 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.49.102.121 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=43 ID=56953 DF PROTO=TCP SPT=2107 DPT=445 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.116.59 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=4974 DF PROTO=TCP SPT=37627 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.174.121 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=41 ID=51429 DF PROTO=TCP SPT=2498 DPT=80 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.50.173 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=52155 DF PROTO=TCP SPT=4452 DPT=135 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.50.173 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=56366 DF PROTO=TCP SPT=3879 DPT=135 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.169.142 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=13052 DF PROTO=TCP SPT=2125 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.169.142 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=13583 DF PROTO=TCP SPT=2125 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.169.142 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=14201 DF PROTO=TCP SPT=4488 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.169.142 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=14822 DF PROTO=TCP SPT=4488 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.166.183 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=120 ID=21599 DF PROTO=TCP SPT=3706 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.166.183 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=120 ID=21669 DF PROTO=TCP SPT=3706 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.183.11 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=16965 DF PROTO=TCP SPT=4438 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.183.11 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=17500 DF PROTO=TCP SPT=4438 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.39.178 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=40 ID=40620 DF PROTO=TCP SPT=1544 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.160.69 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=15354 DF PROTO=TCP SPT=1437 DPT=2967 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.160.69 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=15578 DF PROTO=TCP SPT=1437 DPT=2967 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.114.178 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=39 ID=54766 DF PROTO=TCP SPT=4992 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.99 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=9031 DF PROTO=TCP SPT=2396 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.99 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=9298 DF PROTO=TCP SPT=2396 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.84.15 DST=82.50.96.8 LEN=40 TOS=0x00 PREC=0x00 TTL=121 ID=8297 PROTO=TCP SPT=23571 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.84.15 DST=82.50.96.8 LEN=40 TOS=0x00 PREC=0x00 TTL=121 ID=5499 PROTO=TCP SPT=23571 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.120 DST=82.50.96.8 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=10535 DF PROTO=TCP SPT=3991 DPT=5800 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.120 DST=82.50.96.8 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=10724 DF PROTO=TCP SPT=4189 DPT=139 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.120 DST=82.50.96.8 LEN=52 TOS=0x00 PREC=0x00 TTL=121 ID=10915 DF PROTO=TCP SPT=4388 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.64.215 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=60137 DF PROTO=TCP SPT=3938 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.64.215 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=60192 DF PROTO=TCP SPT=4009 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.64.215 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=61435 DF PROTO=TCP SPT=3938 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.64.215 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=61489 DF PROTO=TCP SPT=4009 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.64.215 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=63929 DF PROTO=TCP SPT=3938 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.147 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=55710 DF PROTO=TCP SPT=32687 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.147 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=56067 DF PROTO=TCP SPT=32687 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.39.178 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=40 ID=53200 DF PROTO=TCP SPT=4097 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.99 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=43455 DF PROTO=TCP SPT=1330 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.99 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=43871 DF PROTO=TCP SPT=1330 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.99 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=44577 DF PROTO=TCP SPT=1821 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.78.99 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=44909 DF PROTO=TCP SPT=1821 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.50.173 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=52471 DF PROTO=TCP SPT=3377 DPT=135 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.50.173 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=58015 DF PROTO=TCP SPT=2828 DPT=135 WINDOW=65535 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=68.161.241.111 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=18001 DF PROTO=TCP SPT=2247 DPT=2967 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=68.161.241.111 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=18735 DF PROTO=TCP SPT=2247 DPT=2967 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.145.213 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=41 ID=30878 DF PROTO=TCP SPT=4404 DPT=445 WINDOW=53760 RES=0x00 SYN URGP=8197
IN=ppp0 OUT= MAC= SRC=82.50.145.213 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=41 ID=32073 DF PROTO=TCP SPT=4404 DPT=445 WINDOW=53760 RES=0x00 SYN URGP=512
IN=ppp0 OUT= MAC= SRC=82.49.99.53 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=122 ID=58349 DF PROTO=TCP SPT=3681 DPT=5900 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.64.215 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=40116 DF PROTO=TCP SPT=1794 DPT=445 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.49.112.87 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=120 ID=14604 DF PROTO=TCP SPT=1484 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.114.178 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=39 ID=29115 DF PROTO=TCP SPT=2636 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=217.42.189.38 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=13482 DF PROTO=TCP SPT=2653 DPT=6348 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=217.42.189.38 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=13514 DF PROTO=TCP SPT=2653 DPT=6348 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=217.42.189.38 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=110 ID=13594 DF PROTO=TCP SPT=2653 DPT=6348 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.183.11 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=4557 DF PROTO=TCP SPT=1657 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.97.59 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=126 ID=40009 DF PROTO=TCP SPT=10126 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.97.59 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=126 ID=40182 DF PROTO=TCP SPT=10126 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.49.102.121 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=43 ID=52497 DF PROTO=TCP SPT=4371 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.183.11 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=11102 DF PROTO=TCP SPT=1729 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.49.102.121 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=43 ID=52819 DF PROTO=TCP SPT=4371 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.183.11 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=11617 DF PROTO=TCP SPT=1729 DPT=445 WINDOW=64800 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.145.80 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=41 ID=43919 DF PROTO=TCP SPT=4570 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.145.80 DST=82.50.96.8 LEN=64 TOS=0x00 PREC=0x00 TTL=41 ID=44757 DF PROTO=TCP SPT=4570 DPT=135 WINDOW=53760 RES=0x00 SYN URGP=0
IN=ppp0 OUT= MAC= SRC=82.50.73.134 DST=82.50.96.8 LEN=48 TOS=0x00 PREC=0x00 TTL=121 ID=14573 DF PROTO=TCP SPT=1190 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0
