Ho una slackware 11 con kernel 2.6 (huge.s), scheda di rete wireless d-link 510 e router roper.
Ho installato ndiswrapper e la navigazione internet senza fili funziona bene (senza la crittografia wep-wap). Il problema è sorto nel momento in cui ho cominciato a configurare wpa_supplicant, ho seguito passo passo la guida
http://www.slacky.eu/wikislack/index.ph ... azione_WPA
ma quando do:
wpa_supplicant -d -c/etc/wpa_supplicant.conf -iwlan0
ho questo risultato:
EAPOL: SUPP_BE entering state IDLE
RTM_NEWLINK: operstate=1 ifi_flags=0x11063 ([UP][RUNNING][LOWER_UP])
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
EAPOL: startWhen --> 0
cosa può essere?
vi allego tutti i file di configurazione:
root@slackware:~# iwlist scan
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
wlan0 Scan completed :
Cell 01 - Address: 00:13:64:2C:4B:D8
ESSID:"ROADSL2P-WG"
Protocol:IEEE 802.11g
Mode:Managed
Frequency:2.437 GHz (Channel 6)
Quality:17/100 Signal level:-85 dBm Noise level:-96 dBm
Encryption key:on
Bit Rate:1 Mb/s
Bit Rate:2 Mb/s
Bit Rate:5.5 Mb/s
Bit Rate:11 Mb/s
Bit Rate:22 Mb/s
Bit Rate:6 Mb/s
Bit Rate:9 Mb/s
Bit Rate:12 Mb/s
Bit Rate:18 Mb/s
Bit Rate:24 Mb/s
Bit Rate:36 Mb/s
Bit Rate:48 Mb/s
Bit Rate:54 Mb/s
Extra:bcn_int=200
Extra:atim=0
(Unknown Wireless Token 0x8C05)
sit0 Interface doesn't support scanning.
/etc/rc.d/rc.wireless.conf
VERBOSE=1
case "$HWADDR" in
## NOTE : Comment out the following five lines to activate the samples below ...
## --------- START SECTION TO REMOVE -----------
## Pick up any Access Point, should work on most 802.11 cards
INFO="Any ESSID"
ESSID="any"
## ---------- END SECTION TO REMOVE ------------
#io
00:13:46:*)
NFO="ios"
ESSID="ROADSL2P-WG"
MODE="Managed"
CHANNEL="6"
RATE="auto"
# See /usr/doc/wpa_supplicant-0.5.7/wpa_supplicant.conf.sample
# for many more options that you can use in this file.
# This line enables the use of wpa_cli which is used by rc.wireless
# if possible (to check for successful association)
ctrl_interface=/var/run/wpa_supplicant
# By default, only root (group 0) may use wpa_cli
ctrl_interface_group=0
eapol_version=1
ap_scan=1
fast_reauth=1
# WPA protected network, supply your own ESSID and WPAPSK here:
network={
scan_ssid=0
ssid="ROADSL2P-WG"
proto=WPA
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP WEP104 WEP40
psk="qwertyuiop"
# Plaintext connection (no WPA, no IEEE 802.1X),
# nice for hotel/airport types of WiFi network.
# You'll need a recent version of wireless-tools for this!
network={
ssid="any"
key_mgmt=NONE
priority=2
/etc/rc.d/rc.inet1.conf
# Config information for eth0:
IPADDR[0]=""
NETMASK[0]=""
USE_DHCP[0]=""
DHCP_HOSTNAME[0]=""
# Config information for eth1:
IPADDR[1]=""
NETMASK[1]=""
USE_DHCP[1]=""
DHCP_HOSTNAME[1]=""
# Config information for eth2:
IPADDR[2]=""
NETMASK[2]=""
USE_DHCP[2]=""
DHCP_HOSTNAME[2]=""
# Config information for eth3:
IPADDR[3]=""
NETMASK[3]=""
USE_DHCP[3]=""
DHCP_HOSTNAME[3]=""
# Default gateway IP address:
GATEWAY=""
# Change this to "yes" for debugging output to stdout. Unfortunately,
# /sbin/hotplug seems to disable stdout so you'll only see debugging output
# when rc.inet1 is called directly.
DEBUG_ETH_UP="no"
## Example config information for wlan0. Uncomment the lines you need and fill
## in your info. (You may not need all of these for your wireless network)
#IFNAME[4]="ra0"
IFNAME[4]="wlan0"
#IPADDR[4]=""
#NETMASK[4]=""
USE_DHCP[4]="yes"
#DHCP_HOSTNAME[4]="icculus-wireless"
DHCP_KEEPRESOLV[4]="yes"
root@slackware:~# wpa_supplicant -d -c/etc/wpa_supplicant.conf -iwlan0
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ctrl_interface_group='0' (DEPRECATED)
eapol_version=1
ap_scan=1
fast_reauth=1
Priority group 2
id=1 ssid='any'
Priority group 0
id=0 ssid='ROADSL2P-WG'
Initializing interface (2) 'wlan0'
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
SIOCGIWRANGE: WE(compiled)=20 WE(source)=18 enc_capa=0xf
capabilities: key_mgmt 0xf enc 0xf
WEXT: Operstate: linkmode=1, operstate=5
Own MAC address: 00:13:46:8a:7e:67
wpa_driver_wext_set_wpa
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
wpa_driver_wext_set_drop_unencrypted
Setting scan request: 0 sec 100000 usec
Added interface wlan0
RTM_NEWLINK: operstate=0 ifi_flags=0x1022 ()
Wireless event: cmd=0x8b06 len=8
RTM_NEWLINK: operstate=0 ifi_flags=0x1023 ([UP])
State: DISCONNECTED -> SCANNING
Starting AP scan (broadcast SSID)
Trying to get current scan results first without requesting a new scan to speed up initial association
Received 268 bytes of scan results (1 BSSes)
Scan results: 1
Selecting BSS from priority group 2
0: 00:13:64:2c:4b:d8 ssid='ROADSL2P-WG' wpa_ie_len=24 rsn_ie_len=0 caps=0x11
skip - SSID mismatch
Selecting BSS from priority group 0
selected based on WPA IE
Trying to associate with 00:13:64:2c:4b:d8 (SSID='ROADSL2P-WG' freq=2437 MHz)
Cancelling scan request
WPA: clearing own WPA/RSN IE
Automatic auth_alg selection: 0x1
WPA: using IEEE 802.11i/D3.0
WPA: Selected cipher suites: group 8 pairwise 8 key_mgmt 2 proto 1
WPA: set AP WPA IE - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: clearing AP RSN IE
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using KEY_MGMT WPA-PSK
WPA: Set own WPA IE default - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
No keys have been configured - skip key clearing
State: SCANNING -> ASSOCIATING
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
WEXT: Operstate: linkmode=-1, operstate=5
wpa_driver_wext_associate
Setting authentication timeout: 10 sec 0 usec
EAPOL: External notification - EAP success=0
EAPOL: External notification - EAP fail=0
EAPOL: External notification - portControl=Auto
Wireless event: cmd=0x8b04 len=12
Wireless event: cmd=0x8b1a len=20
RTM_NEWLINK: operstate=0 ifi_flags=0x11023 ([UP][LOWER_UP])
Wireless event: cmd=0x8c07 len=51
AssocReq IE wireless event - hexdump(len=43): 00 0b 52 4f 41 44 53 4c 32 50 2d 57 47 01 04 82 84 8b 96 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
Wireless event: cmd=0x8c08 len=50
AssocResp IE wireless event - hexdump(len=42): 01 04 82 84 8b 96 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 dd 0a 08 00 28 01 01 00 02 00 ff 0f
Wireless event: cmd=0x8b15 len=20
Wireless event: new AP: 00:13:64:2c:4b:d8
Association info event
req_ies - hexdump(len=43): 00 0b 52 4f 41 44 53 4c 32 50 2d 57 47 01 04 82 84 8b 96 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
resp_ies - hexdump(len=42): 01 04 82 84 8b 96 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 dd 0a 08 00 28 01 01 00 02 00 ff 0f
WPA: set own WPA/RSN IE - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
State: ASSOCIATING -> ASSOCIATED
Associated to a new BSS: BSSID=00:13:64:2c:4b:d8
Associated with 00:13:64:2c:4b:d8
WPA: Association event - clear replay counter
EAPOL: External notification - portEnabled=1
EAPOL: SUPP_PAE entering state CONNECTING
RX EAPOL from 00:13:64:2c:4b:d8
IEEE 802.1X RX: version=1 type=3 length=95
EAPOL-Key type=254
key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
key_length=32 key_data_length=0
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 01
key_nonce - hexdump(len=32): f4 62 ee 7f 11 4c c5 1e 35 78 02 f9 bc 8f d4 8f 8f 26 a1 56 7b 3c 4d 8d 13 e8 fc fb 12 aa d0 32
key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
State: ASSOCIATED -> 4WAY_HANDSHAKE
WPA: RX message 1 of 4-Way Handshake from 00:13:64:2c:4b:d8 (ver=1)
WPA: Renewed SNonce - hexdump(len=32): 99 87 8c d5 65 cc ed 6f 1d 7a a9 e7 fd 8f e4 c4 84 02 d8 7e f4 61 63 30 fd a5 d3 b3 81 4a 39 bf
WPA: PMK - hexdump(len=32): [REMOVED]
WPA: PTK - hexdump(len=64): [REMOVED]
WPA: WPA IE for messaggio 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: Sending EAPOL-Key 2/4
IEEE 802.1X RX: version=1 type=3 length=119
EAPOL-Key type=254
key_info 0x1c9 (ver=1 keyidx=0 rsvd=0 Pairwise Install Ack MIC)
key_length=32 key_data_length=24
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 02
key_mic - hexdump(len=16): 57 de 55 5f 3c 3a f5 4a 5c 99 3f e0 2b 06 d6 f9
State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
WPA: RX message 3 of 4-Way Handshake from 00:13:64:2c:4b:d8 (ver=1)
WPA: IE KeyData - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: Sending EAPOL-Key 4/4
WPA: Installing PTK to the driver.
WPA: RSC - hexdump(len=6): 00 00 00 00 00 00
wpa_driver_wext_set_key: alg=2 key_idx=0 set_tx=1 seq_len=6 key_len=32
State: 4WAY_HANDSHAKE -> GROUP_HANDSHAKE
IEEE 802.1X RX: version=1 type=3 length=127
EAPOL-Key type=254
key_info 0x391 (ver=1 keyidx=1 rsvd=0 Group Ack MIC Secure)
key_length=32 key_data_length=32
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 03
key_nonce - hexdump(len=32): f4 62 ee 7f 11 4c c5 1e 35 78 02 f9 bc 8f d4 8f 8f 26 a1 56 7b 3c 4d 8d 13 e8 fc fb 12 aa d0 31
key_iv - hexdump(len=16): 8f 26 a1 56 7b 3c 4d 8d 13 e8 fc fb 12 aa d0 33
key_mic - hexdump(len=16): 8d 61 3a 36 90 5d 59 c3 b8 ac b2 9c 96 7e a8 4f
WPA: RX message 1 of Group Key Handshake from 00:13:64:2c:4b:d8 (ver=1)
State: GROUP_HANDSHAKE -> GROUP_HANDSHAKE
WPA: Group Key - hexdump(len=32): [REMOVED]
WPA: Installing GTK to the driver (keyidx=1 tx=0).
wpa_driver_wext_set_key: alg=2 key_idx=1 set_tx=0 seq_len=6 key_len=32
WPA: Sending EAPOL-Key 2/2
WPA: Key negotiation completed with 00:13:64:2c:4b:d8 [PTK=TKIP GTK=TKIP]
Cancelling authentication timeout
State: GROUP_HANDSHAKE -> COMPLETED
CTRL-EVENT-CONNECTED - Connection to 00:13:64:2c:4b:d8 completed (auth) [id=0 id_str=]
wpa_driver_wext_set_operstate: operstate 0->1 (UP)
WEXT: Operstate: linkmode=-1, operstate=6
EAPOL: External notification - portValid=1
EAPOL: External notification - EAP success=1
EAPOL: SUPP_PAE entering state AUTHENTICATING
EAPOL: SUPP_BE entering state SUCCESS
EAPOL: SUPP_PAE entering state AUTHENTICATED
