Anch'io ho provato con SmartFTP da Windows in una rete casalinga e tutto funziona perfettamente.
Come viene spiegato nei manuali di proftpd, nel caso di reti domestiche bisogna configurare opportunamente il file
/etc/proftpd.conf; in particolare, sono necessarie queste modifiche:
# This is a basic ProFTPD configuration file.
# It establishes a single server and a single anonymous login.
# It assumes that you have a user/group "nobody" and "ftp"
# for normal/anonymous operation.
ServerName "ProFTPD Default Installation"
ServerType standalone
DefaultServer on
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the user and group that the server normally runs at.
User nobody
Group nogroup
# This next option is required for NIS or NIS+ to work properly:
#PersistentPasswd off
SystemLog /var/log/proftpd.log
TransferLog /var/log/xferlog
# Normally, we want files to be overwriteable.
<Directory /*>
AllowOverwrite on
</Directory>
Successivamente devi aggiungere l'utente anonimo:
# A basic anonymous FTP server configuration.
# To enable this, remove the user ftp from /etc/ftpusers.
<Anonymous ~ftp>
RequireValidShell off
User ftp
Group ftp
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
# Limit the maximum number of anonymous logins
MaxClients 50
# We want 'welcome.messaggio' displayed at login, and '.message' displayed
# in each newly chdired directory.
DisplayLogin welcome.messaggio
DisplayFirstChdir .message
# Limit WRITE everywhere in the anonymous chroot
<Limit WRITE>
DenyAll
</Limit>
# An upload directory that allows storing files but not retrieving
# or creating directories.
# <Directory incoming/*>
# <Limit READ>
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
</Anonymous>
... e poi gli utenti non anonimi.
Come si legge nei commenti precedenti:
Quindi, ricordati di editare
/etc/ftpusers per commentare la riga
ftp; nel mio caso, questo file è così:
# ftpusers This file describes the names of the users that may
# _*NOT*_ log into the system via the FTP server.
# This usually includes "root", "uucp", "news" and the
# like, because those users have too much power to be
# allowed to do "just" FTP...
# Version: @(#)/etc/ftpusers 3.00 02/25/2001 volkerdi
# Original Author: Fred N. van Kempen, <waltje@uwalt.nl.mugnet.org>
# The entire line gets matched, so no comments or extra characters on
# lines containing a username.
# To enable anonymous FTP, remove the "ftp" user:
# ftp
root
uucp
news
# End of ftpusers.
P.S. Le varie directory che crei sono giustamente di proprietà dell'utente
root; infatti, tutte le operazioni relative alla creazione degli account devono essere effettuate da
root. Quindi, non devi assolutamente modificare i permessi.
