gpg: pcsc_connect failed: unknown reader (0x80100009)
gpg: card reader not available
gpg: OpenPGP card not available: general error
Se provo ad usare pcscd -f:
pcscd -f
pcscdaemon.c:297:main() pcscd set to foreground with debug send to stderr
readerfactory.c:1108:RFInitializeReader() Attempting startup of SCR24x Smart Card Reader 00 00 using /usr/local/scm/lib/libSCR24x.so
readerfactory.c:943:RFBindFunctions() Loading IFD Handler 2.0
readerfactory.c:1147:RFInitializeReader() Open Port 0 Failed (/dev/null)
readerfactory.c:1022:RFUnloadReader() Unloading reader driver.
readerfactory.c:251:RFAddReader() SCR24x Smart Card Reader init failed.
pcscdaemon.c:500:main() pcsc-lite 1.4.1 daemon ready.
hotplug_libusb.c:110:HPReadBundleValues() Cannot open PC/SC drivers directory: /usr/pcsc/drivers
hotplug_libusb.c:111:HPReadBundleValues() Disabling USB support for pcscd.
#Entry for SCR241 Serial Smart Card Reader
FRIENDLYNAME "SCR24x Smart Card Reader"
DEVICENAME /dev/null
LIBPATH /usr/local/scm/lib/libSCR24x.so
CHANNELID 0
In teoria dovrebbe andare anche senza pcscd, come dicono altri due fellows in questo mio tutorial. Lo stesso autore di gpg ne sconsiglia l'uso, anzi quando é venuto al primo fellowship meeting non andava niente
Il mio lettore usb funziona benissimo, ovvimante.. quello pcmcia no
Un problema con udev?
Grazie in anticipo
