Maldestro col kernel...
cyberninja
Messaggio da cyberninja »
... e ora non riesco a venirne fuori. :(
Questo è il mio lilo.conf :
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/hda
# message = /boot/boot_message.txt
prompt
timeout = 300
# Override dangerous defaults that rewrite the partition table:
change-rules
reset
# vga = 791
# Normal VGA console
vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# End LILO global section
image = /boot/vmlinuz
initrd = /boot/initrd.gz
root = /dev/hda2
label = Linux-2.6
read-only
# Linux smp bootable partition config begins
image = /boot/vmlinuz-smp
root = /dev/hda2
label = Linux-2.6-smp
read-only
# Linux smp bootable partition config ends
# Windows bootable partition config begins
other = /dev/hdb1
label = Windows
table = /dev/hdb
boot-as = 0x80
# Windows bootable partition config ends
Questo il contenuto della dir /boot/
total 7514
lrwxrwxrwx 1 root root 37 2006-11-26 03:59 README.initrd -> /usr/doc/mkinitrd-1.0.1/README.initrd
lrwxrwxrwx 1 root root 28 2007-06-09 11:45 System.map -> System.map-generic-2.6.17.13
-rw-r--r-- 1 root root 711610 2006-09-09 08:14 System.map-generic-2.6.17.13
-rw-r--r-- 1 root root 723274 2006-10-01 00:20 System.map-generic-smp-2.6.17.13
-rw-r--r-- 1 root root 629105 2006-09-01 08:51 System.map-ide-2.4.33.3
lrwxrwxrwx 1 root root 32 2007-06-09 13:19 System.map-smp -> System.map-generic-smp-2.6.17.13
-rw-r--r-- 1 root root 512 2006-11-26 04:11 boot.0300
-rw-r--r-- 1 root root 168 2006-11-26 04:11 boot_message.txt
lrwxrwxrwx 1 root root 24 2007-06-09 11:45 config -> config-generic-2.6.17.13
-rw-r--r-- 1 root root 62900 2006-09-09 08:14 config-generic-2.6.17.13
-rw-r--r-- 1 root root 62425 2006-10-01 00:20 config-generic-smp-2.6.17.13
-rw-r--r-- 1 root root 41810 2006-09-01 08:51 config-ide-2.4.33.3
lrwxrwxrwx 1 root root 28 2007-06-09 13:19 config-smp -> config-generic-smp-2.6.17.13
-rw-r--r-- 1 root root 5032 2006-08-08 07:34 diag1.img
drwxr-xr-x 8 root root 304 2007-06-09 13:54 initrd-tree/
-rw------- 1 root root 547425 2007-06-09 13:54 initrd.gz
-rw------- 1 root root 62464 2007-06-09 13:20 map
lrwxrwxrwx 1 root root 25 2007-06-09 11:45 vmlinuz -> vmlinuz-generic-2.6.17.13
-rw-r--r-- 1 root root 1677856 2006-09-09 08:14 vmlinuz-generic-2.6.17.13
-rw-r--r-- 1 root root 1816886 2006-10-01 00:20 vmlinuz-generic-smp-2.6.17.13
-rw-r--r-- 1 root root 1313255 2006-09-01 08:51 vmlinuz-ide-2.4.33.3
lrwxrwxrwx 1 root root 29 2007-06-09 13:20 vmlinuz-smp -> vmlinuz-generic-smp-2.6.17.13
Ho dato questi due comandi:
mkinitrd -c -k 2.6.17.13 -f reiserfs -r /dev/hda2
mkinitrd -k 2.6.17.13-smp -f reiserfs -r /dev/hda2
Il comando lilo -v -t restituisce questo:
LILO version 22.7.1 (test mode), Copyright (C) 1992-1998 Werner Almesberger
Development beyond version 21 Copyright (C) 1999-2005 John Coffman
Released 17-Sep-2005 and compiled at 00:33:53 on Aug 8 2006.
Warning: LBA32 addressing assumed
Reading boot sector from /dev/hda
Using MENU secondary loader
Calling map_insert_data
Boot image: /boot/vmlinuz -> vmlinuz-generic-2.6.17.13
Mapping RAM disk /boot/initrd.gz
Added Linux-2.6 *
Boot image: /boot/vmlinuz-smp -> vmlinuz-generic-smp-2.6.17.13
Added Linux-2.6-smp
Boot other: /dev/hdb1, on /dev/hdb, loader CHAIN
Added Windows
The boot sector and the map file have *NOT* been altered.
Al riavvio il sistema si blocca con un kernel-panic e la prima riga è questa:
RAMDISK Couldn't find valid RAM disk image starting at 0
Poi "kernel-panic bla bla bla..."
Dov'è l'inghippo?
Per ora risolvo bootando col dvd e questa riga:
boot: huge26.s root=/dev/hda2 noinitrd ro
ma non posso farlo in eterno! :lol:
Help me, plese!
Luca
p.s.: scusate la prolissità del messaggio. 8)
Kronos
Messaggio da Kronos »
Mi sa che l'inghippo sia proprio quello che ti ho evidenziato.
Perchè non provi a dare lilo -v tralasciando l'opzione -t che è quella che impedisce a LILO di sovrascrivere l'MBR?
neongen
Nome Cognome: Enrico
Slackware: 14.0_64
Kernel: 3.4.4
Desktop: KDE 4.5.5
Distribuzione: Maemo 5
Messaggio da neongen »
prova a dare
mkinitrd -c -k 2.6.17.13 -m reiserfs
mkinitrd -c -k 2.6.17.13-smp -m reiserfs -o /boot/initrd-smp.gz
poi in lilo.conf cambi l'initrd del kernel smp e lo reinstalli senza mettere il parametro -t come suggeriva Kronos
cyberninja
Ha funzionato!
Mannaggia!
E pensare che avevo anche letto il man di lilo ma evidentemente non bene. #-o
Sono proprio niubbo! :lol:
Grazie Kronos.
Luca
