file upgrade.txt della slack 12
Feste
Slackware: 13
Desktop: KDE 4.2.4
Messaggio da Feste »
Ciao a tutti :)
ho un problemino non riesco a capire alcune cose del file upgrade.txt del dvd della slackware 12
12. Be sure to move your *.new config files into place and merge any custom
changes you had made to the originals. To find them, run:
find /etc -name "*.new"
You will need to leave passwd, shadow, group, and gshadow alone for the
most part (do not copy the *.new versions over the existing ones), but
you will need to add any new user/group accounts in passwd.new and
group.new to the existing files. There have also been some changes to
the network scripts, so pay close attention to those as well.
e questo
sysvinit and udev were upgraded, and the actual init scripts were split out
into the sysvinit-scripts package. Be sure to install it, and don't forget
to move/merge all of the associated *.new files into place or your system
will not boot. If you have more than one network card and have been using
/etc/udev/rules.d/network-devices.rules, the new syntax requires using
ATTR{address} instead of SYSFS{address}, and the file is now called
/etc/udev/rules.d/75-network-devices.rules. While we're on the subject of
udev, all udev rules files should now have numerical prefixes, so you should
remove any leftover rules files that do not have numerical prefixes and
rename any custom rules files.
la domanda è: dove e come li metto questi *.new files?
metto anche il link al file upgrade.txt completo ftp://ftp.heanet.ie/mirrors/ftp.slackwa ... PGRADE.TXT
dapuzz
Messaggio da dapuzz »
Cosa non ti è chiaro? La traduzione? Il motivo? Il come si fa?
In poche parole, quando slackware installa file di configurazione di cui è già presente una versione modificata, aggiunge il suffisso .new al nuovo file in modo da permettere all'utente di confrontare le due versioni e fare una fusione del vecchio con il nuovo.
Per la maggior parte dei .new, puoi sovrascrivere il vecchio con il nuovo (mv nomefile.new nomefile) ma in altri (come ad esempio il file che contiene la lista degli utenti, o il file /etc/rc.d/rc.local) una operazione del genere ti porterebbe a 'cancellare' le tue modifiche e al conseguente ripristino delle impostazioni di default di slackware.
Con tanta pazienza devi quindi valutare se ti conviene modificare il vecchio aggiungendo le nuove modifiche o partire dal nuovo e riaggiungere le personalizzazioni del vecchio
Per quanto riguarda sysvinit ti avvisa che devi instalare sia sysvinit-scripts sia sysvinit-functions.
Per udev ti avvisa che è cambiata la sintassi. Se non hai impostato regole personalizzate puoi semplicemente prenderne atto e passare avanti!
Lean
Slackware: 12.1
Kernel: 2.6.24.5-smp
Desktop: KDE 3.5.9
Messaggio da Lean »
Grazie Dapuzz
Ho chiesto io a Feste di scrivere il post perché non potevo... non capivo cosa dovevo farci con i .new.
Un mv quindi va bene... tranne ovviamente per i files più "particolari".
Inizia l'avventura dell'upgrade :)
ps
non formatto da oltre 2 anni e mi secca farlo adesso. solo che con la 12 sembra un po' più ostica per cui volevo sincerarmi dei passi giusti da compiere e su quello avevo il dubbio
