Il topic dice tutto!!!!!!!!!! Sono appena usciti, li devo ancora provare, ma come si legge dal readme
New Features
This release of the ATI Catalyst™ Linux driver introduces the following new features:
* Support for Accelerated Indirect Rendering (AIGLX)
* Support for X.org version 7.3
* Products older than Radeon™ HD 2x00 are now supported after being enabled only for testing in 8.41.7
* A new 3D user interface is now avaialble in the ATI Catalyst™ Control Center-Linux Edition. The new interface allows for the setting of Anti-Aliasing, Anisotropic Filtering, and VSync. Included on the new 3D interface are static preview images showing the visual effects of the different 3D settings
Resolved Issues
The following section provide a brief description of resolved issues with the latest version of the ATI Catalyst™ Linux software suite. These include:
* Playing videos with TexturedVideo no longer results in stuttering being noticed
* Corruption is no longer noticed when the Composite extension is enabled
* Segmentation faults in OpenGL applications and the ATI Catalyst™ Control Center Linux Edition with Rialto-based AGP cards no longer occur
* Various error messages no longer appear during RPM installation under SuSE 10.2. Further details can be found in topic number 737-29576
FINALMENTEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!
http://www2.ati.com/drivers/linux/ati-d ... x86_64.run
I nuovi driver ATI supportano AIGLX
- nuitari
- Slackware: 12.0
Ultima modifica di nuitari il gio 25 ott 2007, 21:03, modificato 1 volta in totale.
- nuitari
- Slackware: 12.0
Dunque, funzionare funzionano... anche se ancora in indirect rendering. Io personalmente ho rallentamenti evidenti su alcuni effetti, in generale su tutti i ridimensionamenti e sullo scrolling nelle finestre, per cui per me è ancora inutilizzabile (compiz, non il driver in se).
Vorrei sapere se anche altri hanno il medesimo problema, e se non ce l'hanno che tipo di file xorg.conf hanno e che procedura hanno seguito per installare compiz-fusion.
