/dev/.udev/failed
strummer
/dev/.udev/failed
Messaggio da strummer »
Ciao a tutti,
premetto che sono un nuovo utente di udev (fino a slackware 12 ho sempre usato kernel 2.4.*) Durante la fase di boot viene generato questo errore:
Starting sysklogd daemons: /usr/sbin/syslogd /usr/sbin/klogd -c 3 -x
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:01.0%2f0000:01:00.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:0f.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:0f.1%2fide0%2f0.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:0f.1%2fide0%2f0.1/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:0f.1%2fide1%2f1.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:0f.1%2fide1%2f1.1/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:10.0%2fusb2%2f2-0:1.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:10.1%2fusb3%2f3-0:1.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:10.1%2fusb3%2f3-1%2f3-1:1.0/uevent: Not a directory/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:10.2%2fusb4%2f4-0:1.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:10.3%2fusb5%2f5-0:1.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:10.4%2fusb1%2f1-0:1.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpci0000:00%2f0000:00:12.0%2feth0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fplatform%2ffloppy.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fplatform%2fi8042/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fplatform%2fi8042%2fserio0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fplatform%2fpcspkr/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fplatform%2fserial8250/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fplatform%2fvesafb.0/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:00/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:01/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:02/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:03/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:04/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:05/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:06/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:07/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:08/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:09/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:0a/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:0b/uevent: Not a directory
/etc/rc.d/rc.M: line 93: /dev/.udev/failed/%2fdevices%2fpnp0%2f00:0c/uevent: Not a directory
(scusate per il lungo copia/incolla)
Da cosa può dipendere e cosa posso fare per risolvere?
grazie anticipatamente a tutti!
Probabilmente dico una scemata, ma sembra un vecchio problema di Udev, che non trova le directory interessate o che prova a caricare moduli già inclusi nel kernel.
Hai fatto una nuova installazione della 12 o un upgrade?
Che kernel usi? Huge?
strummer
uso il kernel 2.6.21
ho fatto una nuova installazione di slackware 12 e non un upgrade
strummer ha scritto:uso il kernel 2.6.21
Ma quello di default nella slackware?
In quel caso il generic o huge?
Se cerchi nel forum troverai altri problemi come il tuo, ed una possibile causa è l'uso del kernel huge, che ha alcune parti già incorporate nel kernel.
Altrimenti l'unica cosa che mi viene in mente è il cambio tra file e symlink in udev, ma risale a varie versioni fa di udev, mi sembra la 100 o giù di li.
Comunque dopo il sistema ti va?
Perché in alcuni casi consigliano di non badare a tali errori
p.s.
Comunque fai una ricerca nel forum se non l'hai già fatta
UPDATE
oh che bel nick, non ci avevo fatto caso :-)
strummer
bash-3.1$ uname -r
2.6.21.5-smp
Si è quello di default si slackware12
in realtà avevo già fatto una ricerca sul forum senza trovare molto, ne rifarò un'altra meglio magari...
si il sistema dopo parte! Il fatto strano che mi ha attirato l'attenzione è che all'inizio non mi dava questi errori in fase di boot, ma me l'ha dato qualche giorno dopo l'installazione.
Sicuramente ho fatto qualche modifica (che non mi ricordo) che poi ha generato questi errori
grazie mille per ora!
ciao
Grande Joe Strummer!!
KNOW YOUR RIGHTS!
strummer ha scritto:bash-3.1$ uname -r
Prova queste pagine:
/viewtopic.php?t=20235&highlight=dev+udev+failed
/viewtopic.php?t=18755&highlight=dev+udev+failed
e se conosci il cirillico
http://vadim303.wordpress.com/2006/11/14/003/
ma questo è relativo alla 11 mi sa
strummer ha scritto: Grande Joe Strummer!!
KNOW YOUR RIGHTS!
Eh si...
kio341
mouse ps/2 non funziona con il kernel-huge-smp-2.6.23
Messaggio da kio341 »
error
