Problems with compiz
PROXIMO
Slackware: 12.1
Kernel: 2.6.26
Desktop: KDE 3.5.9
Messaggio da PROXIMO »
hi everyone, it is such a great site that u have. Congrats
now tried to install compiz and is seems to work but i cant start ccsm here is what it shows
valio@slackware:~$ ccsm
(ccsm:16695): Gtk-WARNING **: Locale not supported by C library.
Using the fallback 'C' locale.
Traceback (most recent call last):
File "/usr/bin/ccsm", line 39, in <module>
import ccm
File "/tmp/tgz/package/ccsm/usr/lib/python2.5/site-packages/ccm/__init__.py", line 1, in <module>
File "/tmp/tgz/package/ccsm/usr/lib/python2.5/site-packages/ccm/Conflicts.py", line 26, in <module>
File "/usr/lib/python2.5/site-packages/ccm/Constants.py", line 83, in <module>
locale.setlocale(locale.LC_ALL, "")
File "/usr/lib/python2.5/locale.py", line 476, in setlocale
return _setlocale(category, locale)
locale.Error: unsupported locale setting
valio@slackware:~$
10x
edit:
and second is do u know how to make the transparency of kwin-crystal and console show whats below not the wall picture.
414N
Kernel: 5.15.19
Re: Problems with compiz
Messaggio da 414N »
:-k
What's the output of
echo "$LANG"
PROXIMO
Slackware: 12.1
Kernel: 2.6.26
Desktop: KDE 3.5.9
us_US.cp1251 i use cyrlic alphabet as well
414N
Kernel: 5.15.19
Messaggio da 414N »
Seems like that locale isn't supported. For a list of supported locales, type
locale -a
and put the one that suits you in /etc/profile.d/lang.sh inside the LANG variable.
Try setting it to en_US or en_US.utf8 (ignoring cyrillic alphabet for now) and see what happens.
About you second question I actually don't know of a setting to make the windows transparent, but if you're using compiz you can play with the opacity of a window using ALT+Mouse Wheel when the cursor is over it
PROXIMO
Slackware: 12.1
Kernel: 2.6.26
Desktop: KDE 3.5.9
:PP yes u were right . i tried before with the previous compiz like 10 times, it was because of that, but i need this encoding, can i have both
414N
Kernel: 5.15.19
Messaggio da 414N »
:-k I really don't know.
You could try leaving the LANG variable at the previuos setting (with cyrillic alphabet) and only define the LC_ALL variable with en_US/en_US.utf8 and see what happens.
I found a page which describes how to redefine only certain settings of a locale: http://www.linuxselfhelp.com/howtos/Cyr ... TO-11.html. Hope it can help.
PROXIMO
Slackware: 12.1
Kernel: 2.6.26
Desktop: KDE 3.5.9
what should i do to enable auto cube rotation while dragging a window off the screen
414N
Kernel: 5.15.19
Messaggio da 414N »
Did you try launching compiz with rotate plugin?
PROXIMO
Slackware: 12.1
Kernel: 2.6.26
Desktop: KDE 3.5.9
yes it works fine ,even 3d desktop with reflection. But i can see alot of bugs. Main is that desktops are bugged multiplied by 4. I cant be with my 4 standard desktops, then my screensaver bugges - it is not like full screen but as if moved at 1 side. Often when i use some extras and press Esc the window manager crashes so i have to restart X, and some more. Am i the only 1 having this issues?! I like it but this is annoing.
414N
Kernel: 5.15.19
Messaggio da 414N »
Maybe you need to update your graphic card drivers.
PROXIMO
Slackware: 12.1
Kernel: 2.6.26
Desktop: KDE 3.5.9
well i think i have the latest from Nvidia. or at least they were several months ago.
PC conf is Core2D @3200
Gigabyte P35 DS4
2x1GB@1000
2x320GB Hdd
7600GT ddr3 - and soon 9600 or 8800GT
this is my LCD Asus PW201
http://prohardver.hu/dl/rev/2006-12/137 ... ont3sm.jpg
overall the PC is madness :P
414N
Kernel: 5.15.19
Messaggio da 414N »
I really don't know how to solve this.
What version of compiz are you using?
414N
Kernel: 5.15.19
Messaggio da 414N »
PROXIMO ha scritto:But i can see alot of bugs. Main is that desktops are bugged multiplied by 4. I cant be with my 4 standard desktops
Do you mean that the 4 desktop previews located in KDE Kicker are broken when you start compiz?
This is normal. You need to install kicker compiz: http://www.kde-apps.org/content/show.php?content=46021 and add it to the applets in your Kicker.
nuitari
Slackware: 12.0
Messaggio da nuitari »
which version of compiz do u have?
I'm using compiz-git with a 8800m gti and it's working fine (only a crash sometime with quanta+ upload dialog), mb u can consider to upgrade to compiz-git?
http://www.slacky.eu/wikislack/index.ph ... Compiz-git
