Ho installato il pacchetto precompilato di squid-2.4 che c'è sul sito di slacky , ho una slackware 12 se ranno il demone con l'opzione -X per il debugging questo è l'output e -N per non farlo funzionare in non-demon mode
root@darkstar:/proc# squid -X -N
2008/04/03 17:07:43| Memory pools are 'off'; limit: 0.00 MB
2008/04/03 17:07:43| cachemgrRegister: registered mem
2008/04/03 17:07:43| cbdataInit
2008/04/03 17:07:43| cachemgrRegister: registered cbdata
2008/04/03 17:07:43| cachemgrRegister: registered events
2008/04/03 17:07:43| authSchemeAdd: adding basic
2008/04/03 17:07:43| parse_line: authenticate_cache_garbage_interval 1 hour
2008/04/03 17:07:43| parse_line: authenticate_ttl 1 hour
2008/04/03 17:07:43| parse_line: authenticate_ip_ttl 0 seconds
2008/04/03 17:07:43| parse_line: dead_peer_timeout 10 seconds
2008/04/03 17:07:43| parse_line: cache_mem 8 MB
2008/04/03 17:07:43| parse_line: maximum_object_size_in_memory 8 KB
2008/04/03 17:07:43| parse_line: memory_replacement_policy lru
2008/04/03 17:07:43| parse_line: cache_replacement_policy lru
2008/04/03 17:07:43| parse_line: store_dir_select_algorithm least-load
2008/04/03 17:07:43| parse_line: max_open_disk_fds 0
2008/04/03 17:07:43| parse_line: minimum_object_size 0 KB
2008/04/03 17:07:43| parse_line: maximum_object_size 4096 KB
2008/04/03 17:07:43| parse_line: cache_swap_low 90
2008/04/03 17:07:43| parse_line: cache_swap_high 95
2008/04/03 17:07:43| parse_line: cache_log /var/log/squid/logs/cache.log
2008/04/03 17:07:43| parse_line: cache_store_log /var/log/squid/logs/store.log
2008/04/03 17:07:43| parse_line: logfile_rotate 10
2008/04/03 17:07:43| parse_line: emulate_httpd_log off
2008/04/03 17:07:43| parse_line: log_ip_on_direct on
2008/04/03 17:07:43| parse_line: mime_table /etc/squid/mime.conf
2008/04/03 17:07:43| parse_line: log_mime_hdrs off
2008/04/03 17:07:43| parse_line: pid_filename /var/log/squid/logs/squid.pid
2008/04/03 17:07:43| parse_line: debug_options ALL,1
2008/04/03 17:07:43| parse_line: log_fqdn off
2008/04/03 17:07:43| parse_line: client_netmask 255.255.255.255
2008/04/03 17:07:43| parse_line: strip_query_terms on
2008/04/03 17:07:43| parse_line: buffered_logs off
2008/04/03 17:07:43| parse_line: ftp_user Squid@
2008/04/03 17:07:43| parse_line: ftp_list_width 32
2008/04/03 17:07:43| parse_line: ftp_passive on
2008/04/03 17:07:43| parse_line: ftp_sanitycheck on
2008/04/03 17:07:43| parse_line: ftp_telnet_protocol on
2008/04/03 17:07:43| parse_line: diskd_program /usr/libexec/diskd-daemon
2008/04/03 17:07:43| parse_line: unlinkd_program /usr/libexec/unlinkd
2008/04/03 17:07:43| parse_line: url_rewrite_children 5
2008/04/03 17:07:43| parse_line: url_rewrite_concurrency 0
2008/04/03 17:07:43| parse_line: url_rewrite_host_header on
2008/04/03 17:07:43| parse_line: redirector_bypass off
2008/04/03 17:07:43| parse_line: location_rewrite_children 5
2008/04/03 17:07:43| parse_line: location_rewrite_concurrency 0
2008/04/03 17:07:43| parse_line: quick_abort_min 16 KB
2008/04/03 17:07:43| parse_line: quick_abort_max 16 KB
2008/04/03 17:07:43| parse_line: quick_abort_pct 95
2008/04/03 17:07:43| parse_line: read_ahead_gap 16 KB
2008/04/03 17:07:43| parse_line: negative_ttl 5 minutes
2008/04/03 17:07:43| parse_line: positive_dns_ttl 6 hours
2008/04/03 17:07:43| parse_line: negative_dns_ttl 1 minute
2008/04/03 17:07:43| parse_line: range_offset_limit 0 KB
2008/04/03 17:07:43| parse_line: minimum_expiry_time 60 seconds
2008/04/03 17:07:43| parse_line: store_avg_object_size 13 KB
2008/04/03 17:07:43| parse_line: store_objects_per_bucket 20
2008/04/03 17:07:43| parse_line: request_header_max_size 20 KB
2008/04/03 17:07:43| parse_line: reply_header_max_size 20 KB
2008/04/03 17:07:43| parse_line: request_body_max_size 0 KB
2008/04/03 17:07:43| parse_line: via on
2008/04/03 17:07:43| parse_line: cache_vary on
2008/04/03 17:07:43| parse_line: collapsed_forwarding off
2008/04/03 17:07:43| parse_line: refresh_stale_hit 0 seconds
2008/04/03 17:07:43| parse_line: ie_refresh off
2008/04/03 17:07:43| parse_line: vary_ignore_expire off
2008/04/03 17:07:43| parse_line: request_entities off
2008/04/03 17:07:43| parse_line: relaxed_header_parser on
2008/04/03 17:07:43| parse_line: forward_timeout 4 minutes
2008/04/03 17:07:43| parse_line: connect_timeout 1 minute
2008/04/03 17:07:43| parse_line: peer_connect_timeout 30 seconds
2008/04/03 17:07:43| parse_line: read_timeout 15 minutes
2008/04/03 17:07:43| parse_line: request_timeout 5 minutes
2008/04/03 17:07:43| parse_line: persistent_request_timeout 2 minutes
2008/04/03 17:07:43| parse_line: client_lifetime 1 day
2008/04/03 17:07:43| parse_line: half_closed_clients on
2008/04/03 17:07:43| parse_line: pconn_timeout 1 minute
2008/04/03 17:07:43| parse_line: ident_timeout 10 seconds
2008/04/03 17:07:43| parse_line: shutdown_lifetime 30 seconds
2008/04/03 17:07:43| parse_line: cache_mgr webmaster
2008/04/03 17:07:43| parse_line: mail_program mail
2008/04/03 17:07:43| parse_line: cache_effective_user nobody
2008/04/03 17:07:43| parse_line: httpd_suppress_version_string off
2008/04/03 17:07:43| parse_line: umask 027
2008/04/03 17:07:43| parse_line: announce_period 0
2008/04/03 17:07:43| parse_line: announce_host tracker.ircache.net
2008/04/03 17:07:43| parse_line: announce_port 3131
2008/04/03 17:07:43| parse_line: httpd_accel_no_pmtu_disc off
2008/04/03 17:07:43| parse_line: wccp_router 0.0.0.0
2008/04/03 17:07:43| parse_line: wccp_version 4
2008/04/03 17:07:43| parse_line: wccp2_rebuild_wait on
2008/04/03 17:07:43| parse_line: wccp2_forwarding_method 1
2008/04/03 17:07:43| parse_line: wccp2_return_method 1
2008/04/03 17:07:43| parse_line: wccp2_assignment_method 1
2008/04/03 17:07:43| parse_line: wccp2_weight 10000
2008/04/03 17:07:43| parse_line: wccp_address 0.0.0.0
2008/04/03 17:07:43| parse_line: wccp2_address 0.0.0.0
2008/04/03 17:07:43| parse_line: client_persistent_connections on
2008/04/03 17:07:43| parse_line: server_persistent_connections on
2008/04/03 17:07:43| parse_line: persistent_connection_after_error off
2008/04/03 17:07:43| parse_line: detect_broken_pconn off
2008/04/03 17:07:43| parse_line: icp_port 3130
2008/04/03 17:07:43| parse_line: log_icp_queries on
2008/04/03 17:07:43| parse_line: udp_incoming_address 0.0.0.0
2008/04/03 17:07:43| parse_line: udp_outgoing_address 255.255.255.255
2008/04/03 17:07:43| parse_line: icp_hit_stale off
2008/04/03 17:07:43| parse_line: minimum_direct_hops 4
2008/04/03 17:07:43| parse_line: minimum_direct_rtt 400
2008/04/03 17:07:43| parse_line: netdb_low 900
2008/04/03 17:07:43| parse_line: netdb_high 1000
2008/04/03 17:07:43| parse_line: netdb_ping_period 5 minutes
2008/04/03 17:07:43| parse_line: query_icmp off
2008/04/03 17:07:43| parse_line: test_reachability off
2008/04/03 17:07:43| parse_line: icp_query_timeout 0
2008/04/03 17:07:43| parse_line: maximum_icp_query_timeout 2000
2008/04/03 17:07:43| parse_line: mcast_icp_query_timeout 2000
2008/04/03 17:07:43| parse_line: icon_directory /usr/share/squid/icons
2008/04/03 17:07:43| parse_line: global_internal_static on
2008/04/03 17:07:43| parse_line: short_icon_urls off
2008/04/03 17:07:43| parse_line: error_directory /usr/share/squid/errors/English
2008/04/03 17:07:43| parse_line: nonhierarchical_direct on
2008/04/03 17:07:43| parse_line: prefer_direct off
2008/04/03 17:07:43| parse_line: incoming_icp_average 6
2008/04/03 17:07:43| parse_line: incoming_http_average 4
2008/04/03 17:07:43| parse_line: incoming_dns_average 4
2008/04/03 17:07:43| parse_line: min_icp_poll_cnt 8
2008/04/03 17:07:43| parse_line: min_dns_poll_cnt 8
2008/04/03 17:07:43| parse_line: min_http_poll_cnt 8
2008/04/03 17:07:43| parse_line: tcp_recv_bufsize 0 bytes
2008/04/03 17:07:43| parse_line: check_hostnames on
2008/04/03 17:07:43| parse_line: allow_underscore on
2008/04/03 17:07:43| parse_line: dns_retransmit_interval 5 seconds
2008/04/03 17:07:43| parse_line: dns_timeout 2 minutes
2008/04/03 17:07:43| parse_line: dns_defnames off
2008/04/03 17:07:43| parse_line: hosts_file /etc/hosts
2008/04/03 17:07:43| parse_line: ignore_unknown_nameservers on
2008/04/03 17:07:43| parse_line: ipcache_size 1024
2008/04/03 17:07:43| parse_line: ipcache_low 90
2008/04/03 17:07:43| parse_line: ipcache_high 95
2008/04/03 17:07:43| parse_line: fqdncache_size 1024
2008/04/03 17:07:43| parse_line: memory_pools on
2008/04/03 17:07:43| parse_line: memory_pools_limit 5 MB
2008/04/03 17:07:43| parse_line: forwarded_for on
2008/04/03 17:07:43| parse_line: client_db on
2008/04/03 17:07:43| parse_line: reload_into_ims off
2008/04/03 17:07:43| parse_line: maximum_single_addr_tries 1
2008/04/03 17:07:43| parse_line: retry_on_error off
2008/04/03 17:07:43| parse_line: as_whois_server whois.ra.net
2008/04/03 17:07:43| parse_line: offline_mode off
2008/04/03 17:07:43| parse_line: uri_whitespace strip
2008/04/03 17:07:43| parse_line: balance_on_multiple_ip on
2008/04/03 17:07:43| parse_line: pipeline_prefetch off
2008/04/03 17:07:43| parse_line: high_response_time_warning 0
2008/04/03 17:07:43| parse_line: high_page_fault_warning 0
2008/04/03 17:07:43| parse_line: high_memory_warning 0 KB
2008/04/03 17:07:43| parse_line: sleep_after_fork 0
2008/04/03 17:07:43| Processing: 'acl all src 0.0.0.0/0.0.0.0'
2008/04/03 17:07:43| parse_line: acl all src 0.0.0.0/0.0.0.0
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'all'
2008/04/03 17:07:43| aclParseIpData: 0.0.0.0/0.0.0.0
2008/04/03 17:07:43| Processing: 'acl manager proto cache_object'
2008/04/03 17:07:43| parse_line: acl manager proto cache_object
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'manager'
2008/04/03 17:07:43| Processing: 'acl localhost src 127.0.0.1/255.255.255.255'
2008/04/03 17:07:43| parse_line: acl localhost src 127.0.0.1/255.255.255.255
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'localhost'
2008/04/03 17:07:43| aclParseIpData: 127.0.0.1/255.255.255.255
2008/04/03 17:07:43| Processing: 'acl to_localhost dst 127.0.0.0/8'
2008/04/03 17:07:43| parse_line: acl to_localhost dst 127.0.0.0/8
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'to_localhost'
2008/04/03 17:07:43| aclParseIpData: 127.0.0.0/8
2008/04/03 17:07:43| Processing: 'acl SSL_ports port 443'
2008/04/03 17:07:43| parse_line: acl SSL_ports port 443
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'SSL_ports'
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 80 # http'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 80 # http
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'Safe_ports'
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 21 # ftp'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 21 # ftp
2008/04/03 17:07:43| aclParseAclLine: Appending to 'Safe_ports'
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 443 # https'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 443 # https
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 70 # gopher'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 70 # gopher
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 210 # wais'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 210 # wais
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 1025-65535 # unregistered ports'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 1025-65535 # unregistered ports
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 280 # http-mgmt'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 280 # http-mgmt
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 488 # gss-http'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 488 # gss-http
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 591 # filemaker'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 591 # filemaker
2008/04/03 17:07:43| Processing: 'acl Safe_ports port 777 # multiling http'
2008/04/03 17:07:43| parse_line: acl Safe_ports port 777 # multiling http
2008/04/03 17:07:43| Processing: 'acl CONNECT method CONNECT'
2008/04/03 17:07:43| parse_line: acl CONNECT method CONNECT
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'CONNECT'
2008/04/03 17:07:43| Processing: 'http_access allow manager localhost'
2008/04/03 17:07:43| parse_line: http_access allow manager localhost
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'manager'
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'localhost'
2008/04/03 17:07:43| Processing: 'http_access deny manager'
2008/04/03 17:07:43| parse_line: http_access deny manager
2008/04/03 17:07:43| Processing: 'http_access deny !Safe_ports'
2008/04/03 17:07:43| parse_line: http_access deny !Safe_ports
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'Safe_ports'
2008/04/03 17:07:43| Processing: 'http_access deny CONNECT !SSL_ports'
2008/04/03 17:07:43| parse_line: http_access deny CONNECT !SSL_ports
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'CONNECT'
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'SSL_ports'
2008/04/03 17:07:43| Processing: 'acl our_networks src 192.168.1.0/24 '
2008/04/03 17:07:43| parse_line: acl our_networks src 192.168.1.0/24
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'our_networks'
2008/04/03 17:07:43| aclParseIpData: 192.168.1.0/24
2008/04/03 17:07:43| Processing: 'http_access allow our_networks'
2008/04/03 17:07:43| parse_line: http_access allow our_networks
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'our_networks'
2008/04/03 17:07:43| Processing: 'http_access deny all'
2008/04/03 17:07:43| parse_line: http_access deny all
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'all'
2008/04/03 17:07:43| Processing: 'icp_access allow all'
2008/04/03 17:07:43| parse_line: icp_access allow all
2008/04/03 17:07:43| Processing: 'http_port 192.168.1.148:3128'
2008/04/03 17:07:43| parse_line: http_port 192.168.1.148:3128
2008/04/03 17:07:43| Processing: 'hierarchy_stoplist cgi-bin ?'
2008/04/03 17:07:43| parse_line: hierarchy_stoplist cgi-bin ?
2008/04/03 17:07:43| Processing: 'access_log /var/log/squid/logs/access.log squid'
2008/04/03 17:07:43| parse_line: access_log /var/log/squid/logs/access.log squid
2008/04/03 17:07:43| Log definition name 'squid' file '/var/log/squid/logs/access.log'
2008/04/03 17:07:43| Processing: 'acl QUERY urlpath_regex cgi-bin \?'
2008/04/03 17:07:43| parse_line: acl QUERY urlpath_regex cgi-bin \?
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'QUERY'
2008/04/03 17:07:43| Processing: 'cache deny QUERY'
2008/04/03 17:07:43| parse_line: cache deny QUERY
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'QUERY'
2008/04/03 17:07:43| Processing: 'refresh_pattern ^ftp: 1440 20% 10080'
2008/04/03 17:07:43| parse_line: refresh_pattern ^ftp: 1440 20% 10080
2008/04/03 17:07:43| Processing: 'refresh_pattern ^gopher: 1440 0% 1440'
2008/04/03 17:07:43| parse_line: refresh_pattern ^gopher: 1440 0% 1440
2008/04/03 17:07:43| Processing: 'refresh_pattern . 0 20% 4320'
2008/04/03 17:07:43| parse_line: refresh_pattern . 0 20% 4320
2008/04/03 17:07:43| Processing: 'acl apache rep_header Server ^Apache'
2008/04/03 17:07:43| parse_line: acl apache rep_header Server ^Apache
2008/04/03 17:07:43| aclParseAclLine: Creating ACL 'apache'
2008/04/03 17:07:43| Processing: 'broken_vary_encoding allow apache'
2008/04/03 17:07:43| parse_line: broken_vary_encoding allow apache
2008/04/03 17:07:43| aclParseAccessLine: looking for ACL name 'apache'
2008/04/03 17:07:43| Processing: 'cache_mgr unicondor'
2008/04/03 17:07:43| parse_line: cache_mgr unicondor
2008/04/03 17:07:43| Processing: 'coredump_dir /var/log/squid/cache'
2008/04/03 17:07:43| parse_line: coredump_dir /var/log/squid/cache
2008/04/03 17:07:43| parse_line: http_reply_access allow all
2008/04/03 17:07:43| parse_line: ident_lookup_access deny all
2008/04/03 17:07:43| parse_line: reply_body_max_size 0 allow all
2008/04/03 17:07:43| parse_line: cache_dir ufs /var/log/squid/cache 100 16 256
2008/04/03 17:07:43| parse_line: wccp2_service standard 0
2008/04/03 17:07:43| wccp2_add_service_list: added service id 0
2008/04/03 17:07:43| parse_line: dns_testnames netscape.com internic.net nlanr.net microsoft.com
2008/04/03 17:07:43| WARNING: failed to resolve 192.168.1.148 to a fully qualified hostname
2008/04/03 17:07:43| getMyHostname: 'darkstar' resolved into 'darkstar.example.net'
2008/04/03 17:07:43| cachemgrRegister: registered config
2008/04/03 17:07:43| fd_open FD 4 epoll ctl
2008/04/03 17:07:43| fd_open FD 0 stdin
2008/04/03 17:07:43| fd_open FD 1 stdout
2008/04/03 17:07:43| fd_open FD 2 stderr
2008/04/03 17:07:43| leave_suid: PID 5158 called
2008/04/03 17:07:43| leave_suid: PID 5158 giving up root, becoming 'nobody'
Aborted
2008/04/03 17:07:43| Starting Squid Cache version 2.6.STABLE17 for i486-slackware-linux-gnu...
2008/04/03 17:07:43| Process ID 5158
2008/04/03 17:07:43| With 1024 file descriptors available
2008/04/03 17:07:43| Using epoll for the IO loop
2008/04/03 17:07:43| Performing DNS Tests...
2008/04/03 17:07:43| Successful DNS name lookup tests...
2008/04/03 17:07:43| DNS Socket created at 0.0.0.0, port 32815, FD 6
2008/04/03 17:07:43| Adding domain labs.ing.unisannio.it from /etc/resolv.conf
2008/04/03 17:07:43| Adding nameserver 212.216.112.112 from /etc/resolv.conf
2008/04/03 17:07:43| Unlinkd pipe opened on FD 11
2008/04/03 17:07:43| Swap maxSize 102400 KB, estimated 7876 objects
2008/04/03 17:07:43| Target number of buckets: 393
2008/04/03 17:07:43| Using 8192 Store buckets
2008/04/03 17:07:43| Max Mem size: 8192 KB
2008/04/03 17:07:43| Max Swap size: 102400 KB
2008/04/03 17:07:43| /var/log/squid/cache/00: (2) No such file or directory
FATAL: Failed to verify one of the swap directories, Check cache.log
for details. Run 'squid -z' to create swap directories
if needed, or if running Squid for the first time.
Squid Cache (Version 2.6.STABLE17): Terminated abnormally.
CPU Usage: 0.008 seconds = 0.004 user + 0.004 sys
Maximum Resident Size: 0 KB
Page faults with physical i/o: 0
Vi ringrazio in anticipo per le risposte...
