Monodevelop 1.0 non parte [RISOLTO]
easy77
Messaggio da easy77 »
Riporto l'ultima parte dell'output.
Slackware 12.0 pulita, kernel 2.6.21.5-smp #2 SMP
Mono 1.9 (da slacky)
Credo che il problema sia che manca l'assembly gtk-sharp 2.12, quindi forse serve un aggiornamento anche degli assemblies di mono...
** (./MonoDevelop.exe:13018): WARNING **: Could not load file or assembly 'gtk-sharp, Version=2.12.0.0, Culture=neutral, PublicKeyToken=35e10195dab3c99f' or one of its dependencies.
at (wrapper runtime-invoke) System.Object.runtime_invoke_string (object,intptr,intptr,intptr) <0xffffffff>
at System.Exception.ToString () <0xffffffff>
at System.Exception.ToString () <0x000f7>
at System.IO.FileNotFoundException.ToString () <0xffffffff>
at System.IO.FileNotFoundException.ToString () <0x000df>
at MonoDevelop.Core.LoggingService.LogFatalError (string,System.Exception) <0x00038>
at MonoDevelop.Startup.SharpDevelopMain.Main (string[]) <0x000ea>
at (wrapper runtime-invoke) MonoDevelop.Startup.SharpDevelopMain.runtime_invoke_int_string[] (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
/usr/lib/libmono.so.0 [0xb7db1782]
/lib/libc.so.6(abort+0x108) [0xb7af84f8]
/usr/lib/libmono.so.0 [0xb7d452a6]
Debug info from gdb:
(no debugging symbols found)
Using host libthread_db library "/lib/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1213417760 (LWP 8497)]
[New Thread -1222091888 (LWP 8527)]
[New Thread -1216255088 (LWP 8526)]
0xb7b95ef7 in ?? () from /lib/libc.so.6
3 Thread -1216255088 (LWP 8526) 0xb7c4240c in ?? ()
from /lib/libpthread.so.0
2 Thread -1222091888 (LWP 8527) 0xb7c3f3b1 in pthread_cond_wait@@GLIBC_2.3.2
() from /lib/libpthread.so.0
1 Thread -1213417760 (LWP 8497) 0xb7b95ef7 in ?? () from /lib/libc.so.6
Thread 3 (Thread -1216255088 (LWP 8526)):
#0 0xb7c4240c in ?? () from /lib/libpthread.so.0
#1 0xb7ea63de in ?? () from /usr/lib/libmono.so.0
#2 0xb7816388 in ?? ()
#3 0x00000000 in ?? ()
Thread 2 (Thread -1222091888 (LWP 8527)):
#0 0xb7c3f3b1 in pthread_cond_wait@@GLIBC_2.3.2 () from /lib/libpthread.so.0
#1 0xb7ea9171 in ?? () from /usr/lib/libmono.so.0
#2 0xb777f1dc in ?? ()
#3 0xb777f1c4 in ?? ()
#4 0xb6c72fdf in ?? ()
#5 0x00128250 in ?? ()
#6 0x0000214f in ?? ()
#7 0x00026f78 in ?? ()
#8 0x00000001 in ?? ()
#9 0xb7285160 in ?? ()
#10 0xb7c3e62c in __pthread_mutex_unlock_usercnt () from /lib/libpthread.so.0
#11 0x00000011 in ?? ()
Thread 1 (Thread -1213417760 (LWP 8497)):
#0 0xb7b95ef7 in ?? () from /lib/libc.so.6
#1 0xb7cc1bc4 in g_spawn_sync () from /usr/lib/libglib-2.0.so.0
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Ultima modifica di easy77 il mer 16 apr 2008, 11:05, modificato 3 volte in totale.
gohanz
Re: Monodevelop 1.0 non parte
Messaggio da gohanz »
Monodevelop 1.0 funziona su GSlacky 2.22.0.
easy77
Sorry :oops:
easy77
Ho aggiornato gslacky alla 2.22, reinstallato monodevelop, ma ora mi da la seguente eccezione, evidentemente sto sbagliando ancora qualcosa:
System.TypeInitializationException: An exception was thrown by the type initializer for MonoDevelop.Core.Gui.Services ---> System.InvalidOperationException: Extension node not found in path: /MonoDevelop/Core/PlatformService
at Mono.Addins.ExtensionContext.GetExtensionObjects (System.String path, System.Type arrayElementType, Boolean reuseCachedInstance) [0x00000]
at Mono.Addins.ExtensionContext.GetExtensionObjects (System.String path) [0x00000]
at Mono.Addins.AddinManager.GetExtensionObjects (System.String path) [0x00000]
at MonoDevelop.Core.Gui.Services..cctor () [0x00000] --- End of inner exception stack trace ---
at MonoDevelop.Ide.Gui.IdeApp.Initialize (IProgressMonitor monitor) [0x00000]
at MonoDevelop.Ide.Gui.IdeStartup.Run (System.String[] args) [0x00000]
Grazie!
gohanz
Controlla la versione di mono-addins. GSlacky 2.22.0 ha installato di default l'ultima versione di mono-addins la 0.3.1.Però ho visto che sul server è presente una versione "vecchia" dello stesso pacchetto. Non vorrei che il problema fosse quello. Con GSlacky 2.22.0 Monodevelop non richiede più la dipendenza accessoria di mono-addins, perchè installati di default.
easy77
gohanz ha scritto:Controlla la versione di mono-addins. GSlacky 2.22.0 ha installato di default l'ultima versione di mono-addins la 0.3.1.Però ho visto che sul server è presente una versione "vecchia" dello stesso pacchetto. Non vorrei che il problema fosse quello. Con GSlacky 2.22.0 Monodevelop non richiede più la dipendenza accessoria di mono-addins, perchè installati di default.
Niente da fare, ho provato con entrambe, cioè la 0.3.1 di GSlacky e la 0.3 del server, con lo stesso risultato.
Forse che la 0.3.1 nonostante la versione non sia effettivamente aggiornata?
gohanz
Sul mio pc gira correttamente. Prova, a questo punto, a ricompilare usando lo o SlackBuild. Le dipendenze sono tutte installate di default.
easy77
Sistemato.
Penso che il problema è stato originato dal fatto che ho installato la GSlacky 2.22 (è la prima volta che la uso) senza rimuovere prima l'altra, e qualcosa dev'essere andato storto...
Ora le ho rimosse entrambe, aggiornato i pacchetti slackware con slackpkg e reinstallata la sola 2.22, tutto a posto.
Grazie e scusate
gohanz
Re: Monodevelop 1.0 non parte [RISOLTO]
:thumbright:
