Driver NVIDIA e kernel 2.6.9
- Harp
- Nome Cognome: Franco Fiorin
- Slackware: 13.0
- Kernel: 2.6.29
- Desktop: KDE 4.2.4
Ciao, ho compilato il kernel 2.6.9, ma non riesco ad abilitare l´accelerazione grafica della scheda, mentre con il kernel 2.4.26 tutto è ok!
<BR>Vi posto il log.
<BR>nvidia-installer log file ´/var/log/nvidia-installer.log´
<BR>creation time: Mon Nov 1 20:39:15 2004
<BR>option status:
<BR> license pre-accepted : false
<BR> update : false
<BR> force update : false
<BR> expert : false
<BR> uninstall : false
<BR> driver info : false
<BR> no precompiled interface: false
<BR> no ncurses color : false
<BR> query latest driver ver : false
<BR> OpenGL header files : false
<BR> no questions : false
<BR> silent : false
<BR> X install prefix : /usr/X11R6
<BR> OpenGL install prefix : /usr
<BR> Installer install prefix: /usr
<BR> kernel source path : (not specified)
<BR> kernel install path : (not specified)
<BR> proc mount point : /proc
<BR> ui : (not specified)
<BR> tmpdir : /tmp
<BR> ftp site : <a href="ftp://download.nvidia.com" target="_blank" target="_new">ftp://download.nvidia.com</a>
<BR>Using: nvidia-installer ncurses user interface
<BR>-> License accepted.
<BR>-> No precompiled kernel interface was found to match your kernel; would you li
<BR> che the installer to attempt to download a kernel interface for your kernel f
<BR> rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
<BR>-> No precompiled kernel interface was found to match your kernel; this means
<BR> that the installer will need to compile a new kernel interface.
<BR>-> Kernel source path: ´/lib/modules/2.4.26/build´
<BR>-> Performing cc_version_check with CC="cc".
<BR>-> Performing rivafb check.
<BR>-> Performing rivafb module check.
<BR>WARNING: Your kernel was configured to include rivafb support as
<BR> a loadable kernel module.
<BR> The rivafb driver conflicts with the NVIDIA driver; the
<BR> NVIDIA kernel module will still be built and installed,
<BR> but be aware that the NVIDIA driver will not be able to
<BR> function properly if the rivafb module is loaded!
<BR>-> Cleaning kernel module build directory.
<BR> executing: ´cd ./usr/src/nv; make clean´...
<BR> rm -f nv.o os-agp.o os-interface.o os-registry.o nv-linux.o nv_compiler.h *
<BR> .d NVdriver nvidia.o
<BR>-> Building kernel module:
<BR> executing: ´cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.4.26/build SY
<BR> SOUT=/lib/modules/2.4.26/build´...
<BR> Your kernel was configured to include rivafb support as
<BR> *** Failed rivafb module sanity check, but continuing! ***
<BR> echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -n 1`\" > nv_compiler.h
<BR> cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wp
<BR> arentheses -Wpointer-arith -Wno-multichar -Werror -O -fno-common -UDEBUG -
<BR> U_DEBUG -DNDEBUG -MD -D__KERNEL__ -DMODULE -D_LOOSE_KERNEL_NAMES -DNTRM -D_G
<BR> NU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNV_MAJOR_VERSION=1
<BR> -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=6111 -DNV_UNIX -DNV_LINUX -DNV_INT
<BR> 64_OK -DNVCPU_X86 -DREMAP_PAGE_RANGE_4 -DNV_CHANGE_PAGE_ATTR_PRESENT
<BR> -I. -I/lib/modules/2.4.26/build/include -Wno-cast-qual -Wno-error nv.c
<BR> -I. -I/lib/modules/2.4.26/build/include -Wno-cast-qual -Wno-error os-agp.c
<BR> -I. -I/lib/modules/2.4.26/build/include -Wno-cast-qual -Wno-error os-interfa
<BR> ce.c
<BR> -I. -I/lib/modules/2.4.26/build/include -Wno-cast-qual -Wno-error os-registr
<BR> y.c
<BR> ld -r -o nv-linux.o nv.o os-agp.o os-interface.o os-registry.o
<BR> ld -r -o nvidia.o nv-linux.o nv-kernel.o
<BR>-> done.
<BR>-> Kernel module compilation complete.
<BR>-> Installing classic TLS OpenGL libraries.
<BR>-> Installing ´NVIDIA Accelerated Graphics Driver for Linux-x86´ (1.0-6111):
<BR> executing: ´./usr/src/nv/makedevices.sh´...
<BR> executing: ´/sbin/ldconfig´...
<BR> executing: ´/sbin/depmod -aq´...
<BR>-> done.
<BR>-> Driver file installation is complete.
<BR>-> Running post-install sanity check:
<BR>-> done.
<BR>-> Sanity check passed.
<BR>-> Shared memory test passed.
<BR>-> Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86
<BR> (version: 1.0-6111) is now complete. Please update your XF86Config or
<BR> xorg.conf file as appropriate; see the file
<BR> /usr/share/doc/NVIDIA_GLX-1.0/README for details.
<BR><br>
<BR>option status:
<BR> update : false
<BR> expert : false
<BR> silent : false
<BR> tmpdir : /tmp
<BR> ce.c
<BR> y.c
<BR>-> done.
<BR>-> done.
<BR>-> done.
<BR><br>
<!-- BBCode Start --><A HREF="http://www.slacky.it/modules.php?mop=mo ... 83&forum=1" TARGET="_blank">Ciao</A><!-- BBCode End --><br>
- Harp
- Slackware: 13.0
- Kernel: 2.6.29
Avevo letto il tuo forum, ma pensavo si trattasse di un problema diverso.
<BR>Devo usare il driver patchato?
<BR>E´ possibile inoltre che il l´ultimo driver reso disponibile da Nvidia (mi sembra sia datato 4 agosto 2004) dia problemi anche con il kernel 2.4.24?
<BR>Ho dei nuovi messaggi di errore in Mplayer:
<BR>Can´t open input config file /home/franco/.mplayer/input.conf: No such file or directory
<BR>Can´t open input config file /etc/mplayer/input.conf: No such file or directory
<BR>Falling back on default (hardcoded) input config
<BR>[ws] sorry, your system is not supported XShape extension.
<BR>Xlib: extension "XFree86-VidModeExtension" missing on display ":0.0
<BR>e le icone animate sono mal definite.
<BR>Stupidaggini, che però preferirei non avere.
<BR><br>
<BR><br>
Bè guarda per il multimediale sono un incompetente con la I maiuscola, quindi per Mplayer non saprei che dirti a parte quello che leggo... cioè che non trova un file chiamato input.conf.
<BR>Per i Driver Nvidia, si! se hai intenzione di "giocare" con il kernel 2.6.9 devi usare i drivers patchati... anche se ho letto in giro pareri discordanti che consigliano di patchare il kernel più che i drivers, io personalmente mi fido più dello staff che sviluppa i kernel che di alcuni pseudo smanettoni ...insomma morale della favola i sorgenti del kernel li patcho solo con patch ufficiali o di collaboratori ufficiali tipo Alan Cox e compagni...
<BR>Poi a ognuno la scelta... se preferisci patchare il kernel piuttosto che i drivers sei liberissimo di farlo.. Linux è bello proprio per questo
<BR>Ciao Meritil
<BR>ps: Sul 2.4.26/27 i drivers Nvidia ufficiali vanno benissimo... sul 2.4.28, prossimo all´uscita, potrebbero avere gli stessi problemi che hanno col 2.6.9. <br>
<BR>Ciao Meritil
- Harp
- Slackware: 13.0
- Kernel: 2.6.29
Grazie per l´aiuto Meritil e scusa se ti scoccio ancora.
<BR>Ho scaricato il driver che hai indicato nel tuo thread, ma prima di farlo partire volevo essere sicuro che sia necessario.
<BR>ERROR: Unable to load the kernel module ´nvidia.ko´. This is most likely
<BR> because the kernel module was built using the wrong kernel source files.
<BR> Please make sure you have installed the kernel source files for your
<BR> kernel; on Red Hat Linux systems, for example, be sure you have the
<BR> ´kernel-source´ rpm installed. If you know the correct kernel source
<BR> files are installed, you may specify the kernel source path with the
<BR> ´--kernel-source-path´ commandline option.
<BR>-> Kernel module load error: insmod: error inserting ´./usr/src/nv/nvidia.ko´:
<BR>Questo errore è dovuto dal bug del driver?
<BR>Oppure basta inserire il path come suggerisce il messaggio?
<BR><BR><BR>[ Questo Messaggio è stato Modificato da: Harp00 il 03-11-2004 15:50 ]<br>
Controlla se per caso hai un modulo nvidia obsoleto già caricato.. se c´è rimuovilo con rmmod, poi modprobe nvidia.
<BR>Cmqe la procedura in questi casi è la seguente:
<BR>Disinstalla i driver nvidia precedenti.
<BR>Assicurati che il kernel 2.6.9 sia correttamente istallato e che esistano tutti i link ad esso.
<BR>poi scarica il driver dal link che ho fornito
<BR>scompatta
<BR>entra nella directory
<BR>./nvidia-istaller -na
<BR>e dovrebbe funzionare... cioè a me ha funzionato!
<BR>ps: Il driver del link è ESCLUSIVAMENTE per il kernel 2.6.9 vergine.
<BR><br>
<BR>scompatta
<BR><br>
