bash-3.1$ emesene
No protocol specified
/usr/lib/python2.5/site-packages/gtk-2.0/gtk/__init__.py:72: GtkWarning: could not open display
warnings.warn(str(e), _gtk.Warning)
/usr/share/emesene-1.0/htmltextview.py:41: GtkWarning: gdk_screen_get_height_mm: assertion `GDK_IS_SCREEN (screen)' failed
if gtk.gdk.screen_height_mm():
/usr/share/emesene-1.0/MainWindow.py:51: Warning: invalid (NULL) pointer instance
gtk.Window.__init__(self)
/usr/share/emesene-1.0/MainWindow.py:51: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/MainWindow.py:192: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
self.scroll = gtk.ScrolledWindow()
/usr/share/emesene-1.0/MainMenu.py:38: Warning: invalid (NULL) pointer instance
fileMenu = gtk.Menu()
/usr/share/emesene-1.0/MainMenu.py:38: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/MainMenu.py:302: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
mi = gtk.ImageMenuItem(_(label))
/usr/share/emesene-1.0/MainMenu.py:302: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/MainMenu.py:302: Warning: value "TRUE" of type `gboolean' is invalid or out of range for property `visible' of type `gboolean'
/usr/share/emesene-1.0/MainMenu.py:54: Warning: invalid (NULL) pointer instance
optionsMenu = gtk.Menu()
/usr/share/emesene-1.0/MainMenu.py:54: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/MainMenu.py:58: Warning: invalid (NULL) pointer instance
helpMenu = gtk.Menu()
/usr/share/emesene-1.0/MainMenu.py:58: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/MainMenu.py:306: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
gtk.ICON_SIZE_MENU))
/usr/share/emesene-1.0/MainMenu.py:306: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/MainMenu.py:306: Warning: value "TRUE" of type `gboolean' is invalid or out of range for property `visible' of type `gboolean'
/usr/share/emesene-1.0/MainMenu.py:295: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
mi = gtk.ImageMenuItem(stock)
/usr/share/emesene-1.0/MainMenu.py:295: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/MainMenu.py:295: Warning: value "TRUE" of type `gboolean' is invalid or out of range for property `visible' of type `gboolean'
/usr/share/emesene-1.0/Login.py:59: Warning: invalid (NULL) pointer instance
self.tUser = gtk.combo_box_entry_new_text()
/usr/share/emesene-1.0/Login.py:59: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/Login.py:61: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
self.userCompletion = gtk.EntryCompletion()
/usr/share/emesene-1.0/Login.py:61: Warning: invalid (NULL) pointer instance
/usr/share/emesene-1.0/Login.py:61: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/Login.py:78: Warning: invalid (NULL) pointer instance
self.tStatus = gtk.ComboBox(self.statusListStore)
/usr/share/emesene-1.0/Login.py:78: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/Login.py:106: GtkWarning: gdk_pango_context_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
_(self.controller.status_ordered[2][ j]) ])
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_context_set_font_description: assertion `context != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_context_set_base_dir: assertion `context != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_context_set_language: assertion `context != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_new: assertion `context != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_single_paragraph_mode: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_ellipsize: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_width: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_wrap: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_alignment: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_attributes: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_get_pixel_extents: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Login.py:106: Warning: g_object_unref: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/Login.py:106: PangoWarning: pango_layout_set_text: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Login.py:147: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
self.bLogin = gtk.Button(_('_Login'), gtk.STOCK_CONNECT)
/usr/share/emesene-1.0/Login.py:147: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/Login.py:147: Warning: value "TRUE" of type `gboolean' is invalid or out of range for property `visible' of type `gboolean'
/usr/share/emesene-1.0/Login.py:170: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
self.cRemember.set_active(True)
/usr/share/emesene-1.0/Login.py:170: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/Login.py:220: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
self.tUser.grab_focus()
/usr/share/emesene-1.0/Login.py:220: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
self.mainWindow.realize()
/usr/share/emesene-1.0/Controller.py:133: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_pango_context_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_context_set_font_description: assertion `context != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_context_set_base_dir: assertion `context != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_context_set_language: assertion `context != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_new: assertion `context != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_text: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_attributes: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_alignment: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_ellipsize: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_single_paragraph_mode: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_width: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_get_extents: assertion `layout != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_get_pixel_extents: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Controller.py:133: Warning: g_object_unref: assertion `G_IS_OBJECT (object)' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_context_get_language: assertion `context != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_context_get_metrics: assertion `PANGO_IS_CONTEXT (context)' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_font_metrics_get_ascent: assertion `metrics != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_font_metrics_get_descent: assertion `metrics != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: PangoWarning: pango_layout_set_wrap: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width 2367621 and height -1055739
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width 2367621 and height -1055768
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width 2367621 and height -1055756
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -1189230 and height 21
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -1189253 and height 21
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -1189253 and height 0
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -1189253 and height 1
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_screen_get_default_colormap: assertion `GDK_IS_SCREEN (screen)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_colormap_get_visual: assertion `GDK_IS_COLORMAP (colormap)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_screen_get_root_window: assertion `GDK_IS_SCREEN (screen)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_new: assertion `GDK_IS_WINDOW (parent)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_enable_synchronized_configure: assertion `GDK_IS_WINDOW (window)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_set_user_data: assertion `window != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_style_attach: assertion `window != NULL' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_style_set_background: assertion `GTK_IS_STYLE (style)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_paint_flat_box: assertion `GTK_IS_STYLE (style)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_set_role: assertion `GDK_IS_WINDOW (window)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_set_accept_focus: assertion `GDK_IS_WINDOW (window)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_set_focus_on_map: assertion `GDK_IS_WINDOW (window)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gdk_window_set_modal_hint: assertion `GDK_IS_WINDOW (window)' failed
/usr/share/emesene-1.0/Controller.py:133: GtkWarning: gtk_window_realize_icon: assertion `widget->window != NULL' failed
/usr/share/emesene-1.0/TrayIcon.py:62: Warning: invalid (NULL) pointer instance
self.tray = gtk.StatusIcon()
/usr/share/emesene-1.0/TrayIcon.py:62: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: Screen for GtkWindow not set; you must always set
a screen for a GtkWindow before using the window
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_screen_get_default_colormap: assertion `GDK_IS_SCREEN (screen)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_colormap_get_visual: assertion `GDK_IS_COLORMAP (colormap)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_screen_get_root_window: assertion `GDK_IS_SCREEN (screen)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_window_new: assertion `GDK_IS_WINDOW (parent)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_screen_get_display: assertion `GDK_IS_SCREEN (screen)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_display_sync: assertion `GDK_IS_DISPLAY (display)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_drawable_get_display: assertion `GDK_IS_DRAWABLE (drawable)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdk_x11_get_xatom_by_name_for_display: assertion `GDK_IS_DISPLAY (display)' failed
/usr/share/emesene-1.0/TrayIcon.py:62: GtkWarning: gdkdrawable-x11.c:878 drawable is not a pixmap or window
/usr/bin/emesene: line 3: 9299 Segmentation fault ./emesene
