Ho seguito pari passo la guida si wikislacky installando bluez prima da reposity, e successivamente compilandomeli a mano, ma ho sempre lo stesso problema:
quando vado per fare modprobe bluez | bluetooth ecco cosa avviene:
bash-3.1# modprobe bluez | bluetooth
bash: bluetooth: command not found
FATAL: Module bluez not found.
bash-3.1# Codice: Seleziona tutto
bash-3.1# modprobe bluetooth
bash-3.1# lsmod
Module Size Used by
rfcomm 32020 0
sco 8964 0
l2cap 18820 3 rfcomm
bridge 46744 0
vboxdrv 53280 0
snd_seq_dummy 2692 0
snd_seq_oss 28032 0
snd_seq_midi_event 5888 1 snd_seq_oss
snd_seq 42832 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_pcm_oss 36256 0
snd_mixer_oss 13952 1 snd_pcm_oss
ipv6 220580 12
smbfs 57208 5
pcmcia 31268 0
pcmcia_core 31632 1 pcmcia
lp 9156 0
fuse 40468 1
nvidia 7813696 34
fan 3332 0
tuner 39840 0
tea5767 5124 1 tuner
tda8290 10628 1 tuner
tuner_simple 8328 1 tuner
mt20xx 11400 1 tuner
tea5761 4356 1 tuner
parport_pc 23588 1
parport 29896 2 lp,parport_pc
thermal 12572 0
button 6032 0
processor 21680 1 thermal
rtc_cmos 6688 0
rtc_core 13976 1 rtc_cmos
rtc_lib 2560 1 rtc_core
saa7134 119888 0
compat_ioctl32 1152 1 saa7134
snd_cmipci 30208 1
videobuf_dma_sg 10884 1 saa7134
videobuf_core 14340 2 saa7134,videobuf_dma_sg
ir_kbd_i2c 7440 1 saa7134
via_rhine 20104 0
8139too 20992 0
ir_common 30212 2 saa7134,ir_kbd_i2c
mii 4480 2 via_rhine,8139too
videodev 25856 1 saa7134
gameport 9864 1 snd_cmipci
v4l2_common 15232 3 tuner,saa7134,videodev
snd_pcm 65544 2 snd_pcm_oss,snd_cmipci
snd_page_alloc 7560 1 snd_pcm
snd_opl3_lib 8064 1 snd_cmipci
snd_timer 17540 3 snd_seq,snd_pcm,snd_opl3_lib
snd_hwdep 6660 1 snd_opl3_lib
snd_mpu401_uart 6144 1 snd_cmipci
v4l1_compat 13700 2 saa7134,videodev
snd_rawmidi 17952 1 snd_mpu401_uart
via_agp 8064 1
i2c_viapro 7188 0
serio_raw 4996 0
snd_seq_device 6412 5 snd_seq_dummy,snd_seq_oss,snd_seq,snd_opl3_lib,snd_rawmidi
agpgart 26416 2 nvidia,via_agp
hci_usb 12188 0
shpchp 28692 0
snd 42852 14 snd_seq_oss,snd_seq,snd_pcm_oss,snd_mixer_oss,snd_cmipci,snd_pcm,snd_opl3_lib,snd_timer,snd_hwdep,snd_mpu401_uart,snd_rawmidi,snd_seq_device
psmouse 36112 0
evdev 8576 5
bluetooth 47364 4 rfcomm,sco,l2cap,hci_usb
soundcore 5472 1 snd
sg 25376 0
kinputwizart
kinputwizard: [DBusMessage* KBluetooth::DBusSignal::newMessage(const QString&)] : path: /org/bluez/input mInterfacE: org.bluez.input.Manager method: ListDevices
kinputwizard: libkbluetooth: getStringList(): Method "ListDevices" with signature "" on interface "org.bluez.input.Manager" doesn't exist
kinputwizard:
bash-3.1# kinputwizard: [DBusMessage* KBluetooth::DBusSignal::newMessage(const QString&)] : org.bluez path: mInterfacE: org.bluez.Adapter method: IsPeriodicDiscovery
process 10456: arguments to dbus_message_new_method_call() were incorrect, assertion "_dbus_check_is_valid_path (path)" failed in file dbus-message.c line 1074.
This is normally a bug in some application using the D-Bus library.
D-Bus not built with -rdynamic so unable to print a backtrace
KCrash: Application 'kinputwizard' crashing...
bash-3.1# lsusb
Bus 001 Device 001: ID 0000:0000
Bus 005 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
bash-3.1# uname -r
2.6.24.5
