In file included from ../include/kiba-win.h:28,
from ../include/kiba.h:25,
from main.c:27:
../include/kiba-dock.h:310: error: expected declaration specifiers or '...' before 'KibaDrawableObject'
make[3]: *** [main.o] Error 1
make[3]: Leaving directory `/home/taras/kiba/kiba-dock/src'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/taras/kiba/kiba-dock/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/taras/kiba/kiba-dock'
make: *** [all] Error 2
Dunque, penso proprio che ci sia qualche anomalia nei codici, io in effetti li sto controllando questi codici, ma fino ad ora non riesco a trovare niente di starno, bah!!
L'unica cosa che mi rimane da fara, è postare questi codici qui sul topic:
********************************kiba-win.h***********************************************
* Copyright (C) 2006-2007 Daniel Bessler <danielb@kiba-dock.org>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA.
* Author : Daniel Bessler <danielb@kiba-dock.org>
#ifndef __KIBA_WIN_H__
#define __KIBA_WIN_H__
#include <gtk/gtk.h>
#include <gdk/gdk.h>
#include <cairo.h>
#include <kiba-dock.h>
#include <kiba-triangle.h>
#include <kiba-progress.h>
#include <kiba-types.h>
G_BEGIN_DECLS
#define KIBA_TYPE_WIN (kiba_win_get_type ())
#define KIBA_WIN(obj) (G_TYPE_CHECK_INSTANCE_CAST ((obj), KIBA_TYPE_WIN, KibaWin))
#define KIBA_WIN_CLASS(obj) (G_TYPE_CHECK_CLASS_CAST ((obj), KIBA_WIN, KibaWinClass))
#define KIBA_IS_WIN(obj) (G_TYPE_CHECK_INSTANCE_TYPE ((obj), KIBA_TYPE_WIN))
#define KIBA_IS_WIN_CLASS(obj) (G_TYPE_CHECK_CLASS_TYPE ((obj), KIBA_TYPE_WIN))
#define KIBA_WIN_GET_CLASS(obj) (G_TYPE_INSTANCE_GET_CLASS ((obj), KIBA_TYPE_WIN, KibaWinClass))
#define KIBA_WIN_CHILD(win) gtk_bin_get_child(GTK_BIN(win))
/* property macros */
#define KIBA_WIN_IS_ABOVE(win) GET_FLAG(win->probs, KIBA_WIN_ABOVE)
#define KIBA_WIN_IS_BELOW(win) GET_FLAG(win->probs, KIBA_WIN_BELOW)
typedef struct _KibaWin KibaWin;
typedef struct _KibaWinClass KibaWinClass;
* KibaDragReceiveFunc:
* @Param1: The drag and drop Context.
* @Param2: The group.
* @Param3: User data.
* Callback function to handle drag and drag receive events.
* Returns: TRUE on succes, otherwhise FALSE
typedef gboolean (*KibaDragReceiveFunc) (GdkDragContext*, const char*, gpointer);
* KibaDragDestFunc:
* @Param1: The drag and drop context.
* @Param4: The drag action return.
* @Param5: The drag Icon return.
* Callback function to check if a drag and drop receive is possible.
* If multiple KibaDragReceiveFunc's can handle the drag,
* a menu is created to allow the user choosing the drag action
typedef void (*KibaDragDestFunc) (GdkDragContext*, const char*, gpointer, char**, char**);
typedef void (*KibaWinAllocateChildrenFunc) (KibaWin*, gpointer);
typedef enum {
KIBA_WIN_BELOW = 0, /**< keep the window below */
KIBA_WIN_ABOVE /**< keep the window above */
}KibaWinProbs;
struct _KibaWin {
GtkWindow window;
KibaWinProbs probs; /**< The window propertys */
KibaWinAllocateChildrenFunc allocate_children;
gpointer allocate_data;
KibaTriangle *triangle; /**< the KibaTriangle instance */
KibaProgress *progress; /**< the KibaProgress instance */
struct _KibaWinClass {
GtkWindowClass parent_class;
/* signals */
void (* dock_hidden) (KibaWin *win,
KibaDock *dock);
void (* dock_unhidden) (KibaWin *win,
KibaDock *dock);
GtkWidget* kiba_win_new (void);
cairo_t* kiba_win_cairo_create (KibaWin *win);
void kiba_win_invalidate_area (GtkWidget *widget,
GdkRectangle area);
gboolean kiba_win_set_children_allocate_func (KibaWin *win,
KibaWinAllocateChildrenFunc fun,
gpointer data);
gboolean kiba_win_unset_children_allocate_func (KibaWin *win,
KibaWinAllocateChildrenFunc fun);
void kiba_win_set_flag (KibaWin *win,
KibaWinProbs prob);
void kiba_win_unset_flag (KibaWin *win,
KibaWinProbs prob);
void kiba_win_add_drag_func (KibaWin *win,
KibaDragReceiveFunc receive_func,
KibaDragDestFunc dest_func,
gpointer user_data);
void kiba_win_remove_drag_func (KibaWin *win,
KibaDragReceiveFunc receive_func);
G_END_DECLS
#endifCodice: Seleziona tutto
*************************************kiba.h*******************************************
/* Copyright (C) 2006-2007 Daniel Bessler <danielb@kiba-dock.org>
#ifndef __KIBA_H__
#define __KIBA_H__
#include <kiba-win.h>
#include <kiba-plugin.h>
#include <kiba-object.h>
#include <kiba-prefs.h>
#include <kiba-title.h>
#include <kiba-tooltip.h>
G_BEGIN_DECLS
#define KIBA_TYPE (kiba_get_type ())
#define KIBA(obj) (G_TYPE_CHECK_INSTANCE_CAST ((obj), KIBA_TYPE, Kiba))
#define KIBA_CLASS(obj) (G_TYPE_CHECK_CLASS_CAST ((obj), KIBA, KibaClass))
#define KIBA_IS(obj) (G_TYPE_CHECK_INSTANCE_TYPE ((obj), KIBA_TYPE))
#define KIBA_IS_CLASS(obj) (G_TYPE_CHECK_CLASS_TYPE ((obj), KIBA_TYPE))
#define KIBA_GET_CLASS(obj) (G_TYPE_INSTANCE_GET_CLASS ((obj), KIBA_TYPE, KibaClass))
typedef struct _Kiba Kiba;
typedef struct _KibaClass KibaClass;
Kiba* kiba_get();
gboolean kiba_add_plugin_object (Kiba *kiba,
KibaPlugin *plugin,
KibaObject *object);
KibaPrefsFile* kiba_get_plugin_config_file (Kiba *kiba,
KibaPlugin *plugin);
KibaPrefsFile* kiba_get_dock_config_file (Kiba *kiba,
KibaDock *dock);
KibaWin* kiba_get_plugin_win (Kiba *kiba,
KibaWin* kiba_get_win (Kiba *kiba);
KibaTitle* kiba_get_title (Kiba *kiba);
KibaTooltip* kiba_get_tooltip (Kiba *kiba);
GList* kiba_get_docks(Kiba *kiba);
void kiba_add_config_file (Kiba *kiba,
const char *configFile);
void kiba_remove_config_file (Kiba *kiba,
void kiba_quit (Kiba *kiba);
G_END_DECLS
******************************************main.c****************************************************/
* Copyright (C) 2007 Daniel Bessler <danielb@kiba-dock.org>
#include "../config.h"
#include <stdlib.h>
#include <string.h>
#include <locale.h>
#include "kiba.h"
#include "kiba-plugin-loader.h"
#include "kiba-macros.h"
#include "kiba-screen.h"
#include "kiba-debug.h"
#include "kiba-prefs.h"
#include "kiba-prefs-schema.h"
#include "kiba-globals.h"
#include "kiba-surface-factory.h"
#include "prefs-dbus.h"
#include "prefs-private.h"
#include "surface-factory-private.h"
#ifdef USE_LIBSN
#include "startup-notification.h"
#endif
#ifdef USE_KDE
const char *file_manager_global = "konqueror";
#else
#ifdef USE_XFCE
const char *file_manager_global = "thunar";
#else
const char *file_manager_global = "nautilus --no-desktop";
#endif
#endif
int main (int argc, char *argv[]) {
Kiba *kiba;
KibaPluginLoader *loader;
#ifdef USE_LIBSN
KibaSn *sn;
#endif
char *pluginPath = NULL;
char *dockPluginPath, *globalPluginPath;
gint i;
#ifdef ENABLE_NLS
bindtextdomain (PACKAGE, DATADIR"/locale");
textdomain (PACKAGE);
bind_textdomain_codeset (PACKAGE, "UTF-8");
#endif
setlocale (LC_NUMERIC, "C"); /* use decimal point instead of comma */
setlocale (LC_CTYPE, "");
setlocale (LC_MESSAGES, "");
/* parsing command line parameters */
for (i = 0; i < argc; i++) {
if (g_strrstr (argv[i], "--help") != NULL ||
g_strrstr (argv[i], "-h") != NULL) {
fprintf (stderr, "Usage: kiba-dock [--verbose] [--plugin-path plugin_path] ...\n");
return EXIT_SUCCESS;
/* enables debugging */
else if (g_strrstr (argv[i], "--verbose") != NULL ||
g_strrstr (argv[i], "-v") != NULL)
kiba_debug_init ();
else if (i < argc + 1) {
if (g_strrstr (argv[i], "--plugin-path") != NULL) {
pluginPath = argv[i+1];
if (!g_file_test (pluginPath, G_FILE_TEST_EXISTS)) {
fprintf (stderr, "Invalid Directory in --plugin-path argument: '%s'\n", pluginPath);
pluginPath = NULL;
#ifdef HAVE_SVG
DEBUG_INFO("Kiba was build with SVG support\n");
#else
DEBUG_INFO("Kiba was build without SVG support\n");
#endif
#ifdef USE_GLITZ
DEBUG_INFO("Kiba was build with GLITZ support\n");
#else
DEBUG_INFO("Kiba was build without GLITZ support\n");
#ifdef HAVE_GLITZ
#ifndef CAIRO_HAS_GLITZ_SURFACE
DEBUG_MISC("Your current cairo installation does not have glitz Support.\n");
DEBUG_MISC("Cairo does not include glitz support by default.\n"
"To use glitz in kiba you must recompile cairo with '--enable-glitz'.\n");
#endif
#endif
#endif
#ifdef USE_SDL
DEBUG_INFO("Kiba was build with SDL support\n");
#else
DEBUG_INFO("Kiba was build without SDL support\n");
#endif
if (!pluginPath)
pluginPath = LIBDIR "/kiba-dock";
if (!g_file_test (pluginPath, G_FILE_TEST_IS_DIR)) {
DEBUG_ERROR (
"Failed to locate Plugins at '%s'\n"
"Please install the Plugins at '" LIBDIR "/kiba-dock' "
"or use the '--plugin-path' command line parameter.\n",
pluginPath);
return EXIT_FAILURE;
DEBUG_MISC("Initialling Gtk+ Library\n");
//TODO: is this already needed for the thumbnail-factory thread?
// g_thread_init (NULL);
// gdk_threads_init ();
// gdk_threads_enter ();
gtk_disable_setlocale();
gtk_init (&argc, &argv);
#ifdef HAVE_SVG
DEBUG_MISC("Initiall RSVG Library\n");
rsvg_init ();
#endif
/* show tips dialog */
// kiba_dialog_tips ();
/* make the plugins at pluginPath loadable */
loader = kiba_plugin_loader_get();
globalPluginPath = g_strdup_printf ("%s/global_plugins", pluginPath);
if (!kiba_plugin_loader_initiall_plugins_at_path (loader, KIBA_PLUGIN_GLOBAL, globalPluginPath)) {
g_object_unref (G_OBJECT(loader));
g_free(globalPluginPath);
dockPluginPath = g_strdup_printf ("%s/dock_plugins", pluginPath);
if (!kiba_plugin_loader_initiall_plugins_at_path (loader, KIBA_PLUGIN_DOCK, dockPluginPath)) {
g_free(dockPluginPath);
/* set up the preferences database */
kiba_prefs_get ();
/* set up the dbus interface */
prefs_dbus_get();
#ifdef USE_LIBSN
sn = kiba_sn_get ();
#endif
/* creating the docks */
kiba = kiba_get();
/* enter the GTK mainloop */
gtk_main();
// gdk_threads_leave ();
DEBUG_MISC("Destroying docks..\n");
g_object_unref (G_OBJECT(kiba));
DEBUG_MISC("Cleaning up..\n");
#ifdef USE_LIBSN
g_object_unref(G_OBJECT(sn));
#endif
prefs_dbus_fini ();
kiba_screen_destroy (kiba_screen_get());
kiba_prefs_fini ();
kiba_surface_factory_destroy();
DEBUG_MISC("Cleaned up!\n");
#ifdef HAVE_SVG
rsvg_term ();
#endif
}Mi raccomando, fatemi sapere, perchè sto prprio disperato, non lo so proprio in che altro modo devo installare questo programma, e vi ringrazio di nuovo per l'aiuto !!
