Qualità CD musicali (Pink Floyd - Relics e cdparanoia)
anycolouryoulike
Kernel: 2.6.34.8
Desktop: KDE 3.5.10
CD nuovo e originale:
$ cdparanoia -B
cdparanoia III release 10pre0 (August 29, 2006)
(C) 2006 Monty <monty@xiph.org> and Xiph.Org
Report bugs to paranoia@xiph.org
http://www.xiph.org/paranoia/
Ripping from sector       0 (track  1 [0:00.00])
          to sector  222224 (track 11 [3:21.59])
outputting to track01.cdda.wav
 (== PROGRESS == [                             !| 013264 00 ] == :^D * ==)
outputting to track02.cdda.wav
 (== PROGRESS == [------------------------+-++++| 056996 00 ] == :^D * ==)
outputting to track03.cdda.wav
 (== PROGRESS == [++++++++++++++++++++++++++VV+V| 070031 00 ] == :^D * ==)
outputting to track04.cdda.wav
 (== PROGRESS == [VVVV++ +   +++  +++++++++++++!| 090219 00 ] == :^D * ==)
outputting to track05.cdda.wav
 (== PROGRESS == [V++++                        !| 106201 00 ] == :^D * ==)
outputting to track06.cdda.wav
 (== PROGRESS == [------------------------------| 118001 00 ] == :^D * ==)
outputting to track07.cdda.wav
 (== PROGRESS == [++ ++++++++++++++++++++++V++++| 143949 00 ] == :^D * ==)
outputting to track08.cdda.wav
 (== PROGRESS == [VVVVVVVVVVVVVVVVVVV+++++++++++| 167801 00 ] == :^D * ==)
outputting to track09.cdda.wav
 (== PROGRESS == [+++++++++++++++++V+++++++++VVV| 183219 00 ] == :^D * ==)
outputting to track10.cdda.wav
 (== PROGRESS == [+   ++ ++++++++++++++++++++++!| 207089 00 ] == :^D * ==)
outputting to track11.cdda.wav
 (== PROGRESS == [V+++++++++++++VVV++++V+VV++++V| 222224 00 ] == :^D * ==)
Done.
Sono normali tutti questi errori o è il CD difettoso?
JohnnyMnemonic
Kernel: 3.5.5-thanatos
Re: Qualità CD musicali (Pink Floyd - Relics e cdparanoia)
Messaggio da JohnnyMnemonic »
Secondo il man di cdparanoia non proprio
PROGRESS BAR SYMBOLS
<space>
No corrections needed
- Jitter correction required
+ Unreported loss of streaming/other error in read
! Errors found after stage 1 correction; the drive is making the same error through
multiple re-reads, and cdparanoia is having trouble detecting them.
e SCSI/ATAPI transport error (corrected)
V Uncorrected error/skip
anycolouryoulike
Kernel: 2.6.34.8
Desktop: KDE 3.5.10
Dite che me lo posso far cambiare?
O magari si tratta di un difetto di registrazione dell'album?
Ci vorrebbe un altro CD per verificarlo.
Comunque, tanto per fare un confronto, questo è un disco di Zappa:
$ cdparanoia -B
          to sector  272244 (track 15 [12:17.17])
 (== PROGRESS == [                              | 015709 00 ] == :^D * ==)
 (== PROGRESS == [                              | 027359 00 ] == :^D * ==)
 (== PROGRESS == [                              | 043379 00 ] == :^D * ==)
 (== PROGRESS == [                              | 059929 00 ] == :^D * ==)
 (== PROGRESS == [                              | 072346 00 ] == :^D * ==)
 (== PROGRESS == [                              | 082344 00 ] == :^D * ==)
 (== PROGRESS == [                              | 095346 00 ] == :^D * ==)
 (== PROGRESS == [                              | 110256 00 ] == :^D * ==)
 (== PROGRESS == [                              | 123441 00 ] == :^D * ==)
 (== PROGRESS == [                              | 135356 00 ] == :^D * ==)
 (== PROGRESS == [                              | 151716 00 ] == :^D * ==)
outputting to track12.cdda.wav
 (== PROGRESS == [                              | 177969 00 ] == :^D * ==)
outputting to track13.cdda.wav
 (== PROGRESS == [                              | 199209 00 ] == :^D * ==)
outputting to track14.cdda.wav
 (== PROGRESS == [                              | 216951 00 ] == :^D * ==)
outputting to track15.cdda.wav
 (== PROGRESS == [                              | 272244 00 ] == :^D * ==)
Done.
Stesso PC, stesso lettore.
metrofox
Kernel: 3.4.4-ck3
Desktop: FluxBox-1.3.1
Messaggio da metrofox »
Appena ritorno da casa provo il CD originale di The dark side of the moon, vediamo che mi esce fuori ;)
LaZyBoY
Messaggio da LaZyBoY »
per rippare in modo sicuro su linux prova rubyripper: http://code.google.com/p/rubyripper/downloads/list
Qui avevo postato le istruzioni per la configurazione: viewtopic.php?f=2&t=25649&p=210911#p210911
robbybby
Slackware: 13.1 / 64 bit
Kernel: 3.3.x
Desktop: KDE 4.4.5
Messaggio da robbybby »
Generalmente gli errori vengono fuori sui cd protetti (quelli col simbolo del pirata, in genere).
Non devono venir fuori se il cd e' conforme al red book, ma i cd protetti NON rispettano il red book.
Se c'e' il logo cd/audio allora, in teoria e' conforme al red book, ma solo in teoria.
Se il cd e' protetto gli errori te li tieni: oppure ti fai una copia privata di backup, masterizzata secondo i sacri crismi, e vivi felice con quella (e il cd originale lo tieni in fondo a un cassetto).
PS: i cd di musica pop/rock/leggera venduti in europa sono quasi tutti protetti. Se acquisti in USA, un po' meno.
anycolouryoulike
Kernel: 2.6.34.8
Desktop: KDE 3.5.10
Il simbolo del pirata non c'è, invece c'è il marchio compact disc digital audio.
È un disco della EMI made in Holland.
Ma se faccio una copia ottengo un disco senza errori?
Quali sono le differenze tra Rubyripper cdparanoia ed EAC?
Grazie a tutti per le dritte!
metrofox ha scritto:Appena ritorno da casa provo il CD originale di The dark side of the moon, vediamo che mi esce fuori ;)
Intendevo un altro CD dello stesso album...
Grazie lo stesso comunque!
metrofox
Kernel: 3.4.4-ck3
Ho fatto il rip di the dark side of the moon e me lo ha fatto perfetto senza un minimo errore,adesso non ho l'album Relics e non so come aiutarti, però spero molto nel tuo rip ;) Prova anche con l'altro estrattore...
anycolouryoulike
Kernel: 2.6.34.8
Desktop: KDE 3.5.10
metrofox ha scritto:Ho fatto il rip di the dark side of the moon e me lo ha fatto perfetto senza un minimo errore,adesso non ho l'album Relics e non so come aiutarti, però spero molto nel tuo rip ;) Prova anche con l'altro estrattore...
Uno di questi giorni provo a pacchettizzarlo...
