Abilitare lo scrolling del touchpad
parre
Slackware: 12.1
Messaggio da parre »
Salve ragazzi, ho installato da qualche settimana circa slackware sul mio portatile, un dell ispiron 1501, ho un solo piccolo problema, non riesco ad abilitare lo scrolling del touchpad, ho cercato in rete e anche qui, ma non ho trovato molto e per questo chiedo a voi che sicuramente sapete come venirne fuori, in compenso sono riuscito a sistemare lo scrolling del mouse grazie alla guida S4D.
Per maggiori informazioni vi posto il mio xorg.conf (si notano i tentativi :D)
# File generated by xf86config.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# NOTE:  This is a NEW IMPROVED version of XF86Config-fbdev that uses the vesa
# driver instead of the fbdev driver.  Thanks to Kenneth Fanyo who pointed
# this out to me. :)
# This XF86Config file is designed for use with the VESA framebuffer.
# This generic interface should work with nearly all video cards
# (although not every card will support every resolution).
# With the new driver, it should no longer be required to have frame buffer
# support in the kernel, or to run it on the console.
# Enjoy! :)
# -- volkerdi@slackware.com
# Module section -- this  section  is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"  	# Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
    SubSection  "extmod"
      Option    "omit xfree86-dga"   # don't initialise the DGA extension
    EndSubSection
# This loads the font modules
    Load        "type1"
    Load        "freetype"
    #Load        "speedo"
# This loads the GLX module
    Load       "glx"
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
    RgbPath	"/usr/share/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
    FontPath   "/usr/share/fonts/local/"
    FontPath   "/usr/share/fonts/misc/"
    FontPath   "/usr/share/fonts/OTF/"
    FontPath   "/usr/share/fonts/TTF/"
    FontPath   "/usr/share/fonts/Type1/"
    FontPath   "/usr/share/fonts/CID/"
    FontPath   "/usr/share/fonts/Speedo/"
    FontPath   "/usr/share/fonts/75dpi/:unscaled"
    FontPath   "/usr/share/fonts/100dpi/:unscaled"
    FontPath   "/usr/share/fonts/75dpi/"
    FontPath   "/usr/share/fonts/100dpi/"
    FontPath   "/usr/share/fonts/cyrillic/"
# ModulePath can be used to set a search path for the X server modules.
# The default path is shown here.
#    ModulePath "/usr/lib/xorg/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received.  This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#    Option     "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
# (where n is 1 through 12).  This allows clients to receive these key
# events.
#    Option     "DontVTSwitch"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#    Option     "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences.  This allows clients to receive these key events.
#    Option     "DontZoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
#    Option     "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
#    Option     "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
#    Option     "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
#    Option     "AllowNonLocalModInDev"
# Set the basic blanking screen saver timeout.
#    Option      "blank time"    "10"    # 10 minutes
# Set the DPMS timeouts.  These are set here because they are global
# rather than screen-specific.  These settings alone don't enable DPMS.
# It is enabled per-screen (or per-monitor), and even then only when
# the driver supports it.
#    Option      "standby time"  "20"
#    Option      "suspend time"  "30"
#    Option      "off time"      "60"
# On some platform the server needs to estimate the sizes of PCI
# memory and pio ranges. This is done by assuming that PCI ranges
# don't overlap. Some broken BIOSes tend to set ranges of inactive
# devices wrong. Here one can adjust how aggressive the assumptions
# should be. Default is 0.
# Option   "EstimateSizesAggresively" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier	"Keyboard1"
    Driver	"kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
#    Option     "Protocol"      "Xqueue"
# Set the keyboard auto repeat parameters.  Not all platforms implement
# this.
#    Option     "AutoRepeat"    "500 5"
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
#    Option     "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#    Option     "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a European
# keyboard, you will probably want to use one of:
#    Option     "XkbModel"      "pc102"
#    Option     "XkbModel"      "pc105"
# If you have a Microsoft Natural keyboard, you can use:
#    Option     "XkbModel"      "microsoft"
# If you have a US "windows" keyboard you will want:
#    Option     "XkbModel"      "pc104"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#    Option     "XkbLayout"     "de"
# or:
#    Option     "XkbVariant"    "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#    Option     "XkbOptions"    "ctrl:swapcaps"
# These are the default XKB settings for X.Org
#    Option     "XkbRules"      "xorg"
#    Option     "XkbLayout"     "us"
#    Option     "XkbVariant"    ""
#    Option     "XkbOptions"    ""
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
    Identifier	"Mouse1"
    Driver	"mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
#    Option     "Protocol"      "Auto"
# The available mouse protocols types that you can set below are:
#    Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
#    Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
#    MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
#    ThinkingMouse ThinkingMousePS/2 Xqueue
    Option "Protocol"    "IMPS/2"
    Option "ZAxisMapping" "4 5"
    Option "Emulate3Buttons" "no"
# The mouse device.  The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
    Option "Device"      "/dev/mouse"
#   Option "Device"      "/dev/psaux"
#   Option "Device"      "/dev/ttyS0"
#   Option "Device"      "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
#    Option "BaudRate"		"9600"
#    Option "SampleRate"	"150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
#    Option "Emulate3Buttons"
#    Option "Emulate3Timeout"    "50"
# ChordMiddle is an option for some 3-button Logitech mice
#    Option "ChordMiddle"
EndSection
# Some examples of extended input devices
# Section "InputDevice"
#    Identifier "spaceball"
#    Driver     "magellan"
#    Option     "Device"        "/dev/cua0"
# EndSection
#    Identifier "spaceball2"
#    Driver     "spaceorb"
# EndSection
#    Identifier "touchscreen0"
#    Driver     "microtouch"
#    Option     "MinX"          "1412"
#    Option     "MaxX"          "15184"
#    Option     "MinY"          "15372"
#    Option     "MaxY"          "1230"
#    Option     "ScreenNumber"  "0"
#    Option     "ReportingMode" "Scaled"
#    Option     "ButtonNumber"  "1"
#    Option     "SendCoreEvents"
# EndSection
#    Identifier "touchscreen1"
#    Driver     "elo2300"
#    Option     "MinX"          "231"
#    Option     "MaxX"          "3868"
#    Option     "MinY"          "3858"
#    Option     "MaxY"          "272"
#    Option     "ButtonThreshold"       "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier  "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY.  REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
    HorizSync   31.5 - 50.0
#    HorizSync	30-64         # multisync
#    HorizSync	31.5, 35.2    # multiple fixed sync frequencies
#    HorizSync	15-25, 30-50  # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
    VertRefresh 40-90
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
    Identifier  "VESA Framebuffer"
    Driver      "vesa"
    #VideoRam    4096
    # Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier  "Screen 1"
    Device      "VESA Framebuffer"
    Monitor     "My Monitor"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
# "1024x768" is also a conservative usable default resolution.  If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
    Subsection "Display"
        Depth       8
        Modes "1024x768" "800x600" "640x480"
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
    EndSubsection
        Depth       32
    EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present.  Each describes
# the way multiple screens are organised.  A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option.  In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
    Identifier  "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens.  The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.  In this example, screen 2 is located to the
# right of screen 1.
    Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used.  Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "Module"
Load "synaptics"
EndSection
ah quasi dimenticavo ho installato i driver synaptic per intenderc questi http://repository.slacky.eu/slackware-1 ... /20080519/ .
Un grazie in anticipo a tutti.
parre
JohnnyMnemonic
Kernel: 3.5.5-thanatos
Re: Abilitare lo scrolling del touchpad
Messaggio da JohnnyMnemonic »
Allora,
Load "synaptics"
va messo insieme a tutti gli altri moduli caricati e non in fondo al file
E comunque ti manca tutta la parte di specifiche per il device, ti posterei il mio ma è diverso poichè ho un touchpad Alps, comunque se cerchi sul forum lo trovi sicuramente
Si notano tentativi, ma nessuno di configurare i synaptics.
E' inutile installarli se non si caricano e si configurano
Prendi spunto da qui
http://web.telia.com/~u89404340/touchpad/xorg.conf
parre
Slackware: 12.1
ok l'unica cosa è che non ho idea di come configurarlo sono abbastanza niubbo, per il momento ho copiato pari pari :oops:
# SOFTWARE.
# XFree86 Project.
# this file.
# Enjoy! :)
Section "Module"
    Load  "synaptics"
    SubSection  "extmod"
    EndSubSection
    Load        "type1"
    Load        "freetype"
    #Load        "speedo"
    Load       "glx"
EndSection
Section "Files"
EndSection
# events.
#    Option     "DontZap"
#    Option     "DontZoom"
EndSection
# Input devices
    Driver	"kbd"
# this.
# or:
EndSection
    Identifier	"Mouse1"
    Driver	"mouse"
EndSection
  Driver  	"synaptics"
  Identifier  	"TouchPad"
  Option	"Protocol"	"auto-dev"
  Option	"LeftEdge"      "1700"
  Option	"RightEdge"     "5300"
  Option	"TopEdge"       "1700"
  Option	"BottomEdge"    "4200"
  Option	"FingerLow"	"25"
  Option	"FingerHigh"	"30"
  Option	"MaxTapTime"	"180"
  Option	"MaxTapMove"	"220"
  Option	"VertScrollDelta" "100"
  Option	"MinSpeed"	"0.09"
  Option	"MaxSpeed"	"0.18"
  Option	"AccelFactor"	"0.0015"
  Option	"SHMConfig"	"on"
EndSection
#    Driver     "magellan"
# EndSection
#    Driver     "spaceorb"
# EndSection
# EndSection
#    Driver     "elo2300"
# EndSection
# Monitor section
Section "Monitor"
    VertRefresh 40-90
EndSection
Section "Device"
    Driver      "vesa"
    #VideoRam    4096
EndSection
# Screen sections
# option.
Section "Screen"
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
        Depth       8
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
    EndSubsection
        Depth       32
    EndSubsection
EndSection
# is used alone.
    Screen "Screen 1"
# "SendCoreEvents".
EndSection
non va comunque lo scrolling sia orizontalmente che verticalmente.
    InputDevice "TouchPad" "CorePointer"
altrimenti lui legge la vecchia sezione
parre
Slackware: 12.1
dovrei aggiungerlo nella sezione "Section "ServerLayout" " ? scusami ma ci metto un po a capire, grazie comunque per la pazienza.
parre ha scritto:dovrei aggiungerlo nella sezione "Section "ServerLayout" " ? scusami ma ci metto un po a capire, grazie comunque per la pazienza.
devi metterlo al posto di
parre
Slackware: 12.1
Sostituendo non mi va più ne mouse ne touchpad(anche se mi sono accorto che in nano andava, quando ho dovuto resettare il file xorg.conf) boooo non ho idea di come venirne fuori.
# SOFTWARE.
# XFree86 Project.
# this file.
# Enjoy! :)
Section "Module"
    Load  "synaptics"
    SubSection  "extmod"
    EndSubSection
    Load        "type1"
    Load        "freetype"
    #Load        "speedo"
    Load       "glx"
EndSection
Section "Files"
EndSection
# events.
#    Option     "DontZap"
#    Option     "DontZoom"
EndSection
# Input devices
    Driver	"kbd"
# this.
# or:
EndSection
    Identifier	"Mouse1"
    Driver	"mouse"
EndSection
  Driver  	"synaptics"
EndSection
#    Driver     "magellan"
# EndSection
#    Driver     "spaceorb"
# EndSection
# EndSection
#    Driver     "elo2300"
# EndSection
# Monitor section
Section "Monitor"
    VertRefresh 40-90
EndSection
Section "Device"
    Driver      "vesa"
    #VideoRam    4096
EndSection
# Screen sections
# option.
Section "Screen"
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
        Depth       8
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
    EndSubsection
        Depth       32
    EndSubsection
EndSection
# is used alone.
    Screen "Screen 1"
# "SendCoreEvents".
 #  InputDevice "TouchPad" "CorePointer"
EndSection
per il momento ho comentato InputDevice "TouchPad" "CorePointer"
[quote="parre"]Sostituendo non mi va più ne mouse ne touchpad(anche se mi sono accorto che in nano andava, quando ho dovuto resettare il file xorg.conf) boooo non ho idea di come venirne fuori.
Devi mettere lo stesso identificativo della sezione del touchpad
  Driver     "synaptics"
Prova a ricopiare la sezione ServerLayout come nell'esempio che ti ho linkato
parre
Slackware: 12.1
Ok ora funziona sia muose e touchpad, ma continua a non andare lo scrolling, l'indentificativo è lo stesso.
Section "Module"
    Load  "synaptics"
    SubSection  "extmod"
    EndSubSection
    Load        "type1"
    Load        "freetype"
    #Load        "speedo"
    Load       "glx"
EndSection
Section "Files"
EndSection
# events.
#    Option     "DontZap"
#    Option     "DontZoom"
EndSection
# Input devices
    Driver	"kbd"
# this.
# or:
EndSection
    Identifier	"Mouse1"
    Driver	"mouse"
EndSection
  Driver  	"synaptics"
  Option	"CornerCoasting" 	"1"
  Option	"CoastingSpeed"		"3"
EndSection
#    Driver     "magellan"
# EndSection
#    Driver     "spaceorb"
# EndSection
# EndSection
#    Driver     "elo2300"
# EndSection
# Monitor section
Section "Monitor"
    VertRefresh 40-90
EndSection
Section "Device"
    Driver      "vesa"
    #VideoRam    4096
EndSection
# Screen sections
# option.
Section "Screen"
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
        Depth       8
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
    EndSubsection
        Depth       32
    EndSubsection
EndSection
# is used alone.
    Screen "Screen 1"
# "SendCoreEvents".
  #  InputDevice "Mouse1"   "CorePointer"
   InputDevice "TouchPad" "AlwaysCore"
EndSection
Roland
Slackware: current x86_64
Kernel: 3.2.13
Desktop: KDE 4.8.2
Messaggio da Roland »
se può essere d'aiuto, il 9° post di questa discussione ha risolto a me lo stesso problema http://www.linuxquestions.org/questions ... .1-644521/
parre
Slackware: 12.1
Uffi no nulla, neanche seguendo quel post sono riuscito a risolvere, probabilmente sbaglio io qualcosa o non so.
# SOFTWARE.
# XFree86 Project.
# this file.
# Enjoy! :)
Section "Module"
    Load  "synaptics"
    SubSection  "extmod"
    EndSubSection
    Load        "type1"
    Load        "freetype"
    #Load        "speedo"
    Load       "glx"
EndSection
Section "Files"
EndSection
# events.
#    Option     "DontZap"
#    Option     "DontZoom"
EndSection
# Input devices
    Driver	"kbd"
# this.
# or:
EndSection
    Identifier	"Mouse1"
    Driver	"mouse"
EndSection
  Driver  	"synaptics"
  Option        "SendCoreEvents" "true"
EndSection
#    Driver     "magellan"
# EndSection
#    Driver     "spaceorb"
# EndSection
# EndSection
#    Driver     "elo2300"
# EndSection
# Monitor section
Section "Monitor"
    VertRefresh 40-90
EndSection
Section "Device"
    Driver      "vesa"
    #VideoRam    4096
EndSection
# Screen sections
# option.
Section "Screen"
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
        Depth       8
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
    EndSubsection
        Depth       32
    EndSubsection
EndSection
# is used alone.
    Screen "Screen 1"
# "SendCoreEvents".
    InputDevice "TouchPad" "SendCoreEvents"
EndSection
non so più cosa fare. :(
E' una brutta besta il touchpad.
Io ho dovuto prendere una versione in svn e invertire le opzioni che richiamano il CorePointer, altrimenti mi funzionava il touchpad, ma non il mouse quando lo inserivo. Poi ho aggiornato ad una nuova versione dei driver, ed ho messo nuove opzioni, altrimenti idem come prima. Insomma, giocaci un po'
Ora che sono nel notebook ti posto il mio xorg.conf, guarda se può esserti di aiuto
Naturalmente guarda i log (/var/log/Xorg.0.log) per vedere se "pesca" il device giusto.
Io come vedi ho messo auto-dev e lo cerca da solo e nei logo ho
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) evaluating device (TouchPad)
(II) XINPUT: Adding extended input device "TouchPad" (type: MOUSE)
(II) evaluating device (Mouse0)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(--) TouchPad auto-dev sets device to /dev/input/event5
(**) Option "Device" "/dev/input/event5"
(--) TouchPad touchpad found
questo è il mio xorg.conf
    Identifier     "X.org Configured"
    Screen      0  "Screen0" 0 0
    InputDevice    "Mouse0" "CorePointer"
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
    FontPath     "/usr/local/fonts/Fonts"
    FontPath     "/usr/local/fonts/ttf"
    FontPath     "/usr/share/fonts/TTF"
    FontPath     "/usr/share/fonts/OTF"
    FontPath     "/usr/share/fonts/Type1"
    FontPath     "/usr/share/fonts/misc"
EndSection
Section "Module"
    Load  "GLcore"
    Load  "dbe"
    Load  "dri"
    Load  "extmod"
    Load  "glx"
    Load  "record"
    Load  "xtrap"
    Load  "freetype"
    Load  "type1"
    Load  "evdev"
    Load  "synaptics"
EndSection
    Identifier  "Keyboard0"
    Driver      "kbd"
    Option      "XkbLayout" "it"
 EndSection
    Identifier  "Mouse0"
    Driver      "mouse"
    Option          "Protocol" "auto"
    Option          "Device" "/dev/input/mice"
    Option          "ZAxisMapping" "4 5 6 7"
EndSection
    Driver      "synaptics"
    Option      "SendCoreEvents" "on"
EndSection
Section "Monitor"
    Identifier   "Monitor0"
    VendorName   "LPL"
    ModelName    "bd00"
    DisplaySize  331 207
    Option       "DPMS"
    HorizSync    30.0 - 62.0
    VertRefresh  43.0 - 60.0
EndSection
Section "Device"
    Identifier  "Card0"
    Driver      "intel"
    VendorName  "Intel Corporation"
    BoardName   "Mobile Integrated Graphics Controller"
    BusID       "PCI:0:2:0"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Card0"
    Monitor    "Monitor0"
   SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
EndSection
Section "DRI"
    Mode 0666
EndSection
Section "Extensions"
    Option "XEVIE" "Enable"
EndSection
p.s.
lo scrolling orizzontale non ce l'ho
Roland
Kernel: 3.2.13
Desktop: KDE 4.8.2
Credo tu debba aggiustare la section serverlayout e le section inputdevice del tuo xorg.conf, ti posto le mie da cui puoi prendere spunto ;)
EndSection
    Driver         "kbd"
    Option         "AutoRepeat" "500 30"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "IMPS/2"	# IntelliMouse PS/2
# Mouse-speed setting for PS/2 mouse.
# Emulate3Buttons is an option for 2-button mice
EndSection
    Driver         "synaptics"
    Option         "LeftEdge" "120"
    Option         "RightEdge" "830"
    Option         "TopEdge" "120"
    Option         "BottomEdge" "650"
    Option         "FingerLow" "14"
    Option         "FingerHigh" "15"
    Option         "MaxTapTime" "130"
    Option         "MaxTapMove" "5"
    Option         "EmulateMidButtonTime" "75"
    Option         "VertScrollDelta" "20"
    Option         "HorizScrollDelta" "40"
    Option         "MinSpeed" "0.4"
    Option         "MaxSpeed" "0.95"
    Option         "AccelFactor" "0.025"
    Option         "EdgeMotionMinSpeed" "200"
    Option         "EdgeMotionMaxSpeed" "200"
    Option         "UpDownScrolling" "1"
    Option         "CircularScrolling" "1"
    Option         "CircScrollDelta" "0.1"
    Option         "CircScrollTrigger" "7"
    Option         "TapButton1" "1"
    Option         "TapButton2" "2"
    Option         "TapButton3" "3"
    Option         "LockedDrops" "1"
EndSection
...arrivato tardi...conraid ha già provveduto :)
Prova a postare (e in futuro fai sempre così) l'output di:
grep -v '#' /etc/X11/xorg.conf
così non vediamo i commenti, io non ci capisco niente leggendo il tuo xorg.conf.
Detto questo, che non è un monito ma un suggerimento, eccoti il mio xorg.conf, anche io ho un dell e, anche io uso i driver synaptics.
        Screen         "Screen 1" 0 0
        InputDevice    "Keyboard"   "CoreKeyboard"
        InputDevice    "Touchpad"   "CorePointer"                      #<----------
EndSection
Section "Module"
        SubSection "extmod"
        EndSubSection
        Load  "type1"
        Load  "freetype"
        Load  "dri"
        Load  "glx"
EndSection
Section "Files"
        ModulePath   "/usr/lib64/xorg/modules/"
        RgbPath      "/usr/share/X11/rgb.txt"
        FontPath     "/usr/share/fonts/util/"
EndSection
        Option      "AIGLX" "off"
EndSection
        Identifier  "Keyboard"
        Driver      "kbd"
EndSection
Section "InputDevice"                                                 # <-----------------
        Identifier  "Touchpad"                                        # <----------------
        Driver      "synaptics"                                       # <----------------
        Option      "Device" "/dev/psaux"                             # <-----------------
        Option      "Protocol" "auto-dev"                             # <-----------------
        Option      "LeftEdge" "1700"                                 # <-----------------
        Option      "RightEdge" "5300"                                # <-----------------
        Option      "TopEdge" "1700"                                  # <-----------------
        Option      "BottomEdge" "4200"                               # <-----------------
        Option      "FingerLow" "25"                                  # <-----------------
        Option      "FingerHigh" "30"                                 # <-----------------
        Option      "VertScrollDelta" "100"                           # <-----------------
        Option      "MinSpeed" "0.09"                                 # <-----------------
        Option      "MaxSpeed" "0.18"                                 # <-----------------
        Option      "AccelFactor" "0.0015"                            # <-----------------
        Option      "SHMConfig" "on"                                  # <-----------------
EndSection                                                            # <-----------------
Section "Monitor"
        ModelName    "LCD Panel 1280x800"
        VertRefresh  40.0 - 90.0
        Option      "dpms"
EndSection
Section "Device"
        Identifier  "ATI Mobility Radeon X1400"
        Driver      "fglrx"
        Option      "UseInternalAGPGART" "no"
        Option      "Centermode" "off"
        Option      "PseudoColorVisuals" "off"
        Option      "OpenGLOverlay" "off"
        Option      "VideoOverlay" "off"
EndSection
Section "Screen"
        Device     "ATI Mobility Radeon X1400"
        DefaultDepth     24
                Viewport   0 0
                Depth     24
                Modes    "1280x800" "1024x768" "800x600" "640x480"
        EndSubSection
EndSection
Section "DRI"
        Group        0
        Mode         0666
EndSection
quelle con '# <-----------------' sono le righe che dovrebbero interessarti. Comunque puoi usare il
man 5 synaptics
per altre info.
Spina
