emesene
sombriks
emesene
Messaggio da sombriks »
hello,
http://www.slacky.eu/index.php?option=c ... &Itemid=65
many thanks for the packager, but the .desktop section about icon is incorrect.
I suggest to change the .desktop file in that way:
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=emesene
GenericName=MSN(tm) Client
GenericName[it]=Client MSN(tm)
Comment=Windows Live Messenger (tm) network multiplatform client
Comment[it]=Client multipiattaforma per la rete di Windows Live Messenger(tm)
Exec=emesene
Terminal=false
Categories=Application;Network;
then we create /usr/share/icons/Messenger.png copying the old one (/usr/share/emesene-1.0/smilies/default/Messenger.png is also inside the actual and oficial package, and it's defective; emesene-1.0.1 is the version to 12.1) to the new location.
again, many thanks to Michelino Chionchio;
michelino
Slackware: -current
Kernel: 2.6.29.6
Desktop: kde (current)
Re: emesene
Messaggio da michelino »
Thanks vary much for your report, as soon as possible (we are managing the slack upgrade), we'll make the change in the 12.2 emesene package.
Regards
shark1500
Kernel: 2.6.27.7-smp
Re: emesene
Messaggio da shark1500 »
For the next time please use pkgreports :-)
