Salve, sto cercando di installare mIsdn per poter usare internet ,ho installato il kernel 2.6.27.9 abilitanto misdn come da guida
su internet ho trovato varie guide
http://rcum.uni-mb.si/~uvp00845b/
http://www.misdn.org/index.php/MISDN_v2_Installation
Quando tento di installare Misdn la compilazione si blocca, posto di seguito il risultato.
root@darkstar:/usr/src/mISDN-CVS-2007-06-01# make
if cvs status Makefile | grep "Sticky Tag" | grep none > /dev/null ; then \
echo 1_1_2-$(date +"20%y_%m_%d" | sed -e "s/\//_/g") > VERSION ; \
else \
echo 1_1_2 > VERSION ; \
fi
Unknown host cvs.isdn4linux.de.
cp /usr/src/mISDN-CVS-2007-06-01/drivers/isdn/hardware/mISDN/Makefile.v2.6 /usr/src/mISDN-CVS-2007-06-01/drivers/isdn/hardware/mISDN/Makefile
export MINCLUDES=/usr/src/mISDN-CVS-2007-06-01/include ; export MISDNVERSION=1_1_2; make -C /lib/modules/2.6.27.9-smp/build SUBDIRS=/usr/src/mISDN-CVS-2007-06-01/drivers/isdn/hardware/mISDN modules CONFIG_MISDN_DRV=m CONFIG_MISDN_DSP=m CONFIG_MISDN_HFCMULTI=m CONFIG_MISDN_HFCPCI=m CONFIG_MISDN_HFCUSB=m CONFIG_MISDN_XHFC=m CONFIG_MISDN_HFCMINI=m CONFIG_MISDN_W6692=m CONFIG_MISDN_SPEEDFAX=m CONFIG_MISDN_AVM_FRITZ=m CONFIG_MISDN_NETJET=m
make[1]: Entering directory `/usr/src/linux-2.6.27.9'
scripts/Makefile.build:46: *** CFLAGS was changed in "/usr/src/mISDN-CVS-2007-06-01/drivers/isdn/hardware/mISDN/Makefile". Fix it to use EXTRA_CFLAGS. Stop.
make[1]: *** [_module_/usr/src/mISDN-CVS-2007-06-01/drivers/isdn/hardware/mISDN] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.27.9'
make: *** [all] Error 2
Qualcuno può aiutarmi grazie.
problemi installazione mISDN
- stan
- Slackware: 12.1
- Kernel: 2.6.xx
- Desktop: Kde3
Re: problemi installazione mISDN
Non conosco il russo ma...
http://www.linux.org.ru/view-message.jsp?msgid=2491461
export KBUILD_NOPEDANTIC=1
make
make
