Disk /dev/hdc: 4001 MB, 4001292288 bytes
255 heads, 63 sectors/track, 486 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hdc1 1 300 2409718+ 83 Linux
/dev/hdc2 301 484 1477980 83 Linux
/dev/hdc3 485 485 8032+ c W95 FAT32 (LBA)
/dev/hdc4 486 486 8032+ ef EFI (FAT-12/16/32)
Disk /dev/sda: 8252 MB, 8252293120 bytes
254 heads, 62 sectors/track, 1023 cylinders
Units = cylinders of 15748 * 512 = 8062976 bytes
This doesn't look like a partition table
Probably you selected the wrong device.
/dev/sda1 ? 191804 191836 253319 e4 SpeedStor
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(190, 120, 0) logical=(191803, 79, 51)
Partition 1 has different physical/logical endings:
phys=(544, 125, 44) logical=(191835, 123, 24)
Partition 1 does not end on cylinder boundary.
/dev/sda2 ? 63917 190154 993984023 98 Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
phys=(1010, 16, 43) logical=(63916, 208, 10)
Partition 2 has different physical/logical endings:
phys=(205, 205, 22) logical=(190153, 10, 55)
Partition 2 does not end on cylinder boundary.
/dev/sda3 ? 107736 229651 959953209 7d Unknown
Partition 3 has different physical/logical beginnings (non-Linux?):
phys=(252, 139, 46) logical=(107735, 241, 54)
Partition 3 has different physical/logical endings:
phys=(367, 195, 2) logical=(229650, 64, 25)
Partition 3 does not end on cylinder boundary.
/dev/sda4 ? 571 575 32768 0 Empty
Partition 4 has different physical/logical beginnings (non-Linux?):
phys=(0, 10, 0) logical=(570, 33, 27)
Partition 4 has different physical/logical endings:
phys=(0, 0, 0) logical=(574, 74, 28)
Partition 4 does not end on cylinder boundary.
Partition table entries are not in disk order
la tabella delle partizioni non è in ordine, hai 4 partizioni su sda e probabilmente il sistema non riesce a leggere il tipo di file system utilizzato. Può dari che la formattazione che hai utilizzato non sia stata eseguita bene.
Se non hai dati importanti, ti consiglio di cancellare e ricreare le partizioni con cfdisk ed fdisk (oppure con gparted utilizzando una live) e riprovare.
Ciao!
Leggendo il thread non ho capito se hai già provato a cancellare e ricreare la tabella delle partizioni, comunque visto che da Xandros riesci a leggere e scrivere la sd, fatti un backup se hai dati che non vuoi perdere e poi cancella la tabella delle partizioni con fdisk/cfdisk...
ti conviene fare prima questo tentativo, tanto più che fdisk/cfdisk non sono difficili da usare, ci sono riuscito io...
