gslapt errore nelle dipendenze
joma
Messaggio da joma »
Salve
ho notato che che gslapt mi segnala delle dipendenze mancati ed esclude alcuni pacchetti dal aggiornamento.
La mia slackware e la 12.1
le fonti per i pacchetti sono:
SOURCE=http://slacky.uglyplace.org/repository/slackware-12.1/
SOURCE=http://slackware.osuosl.org/slackware-12.1/
Segue una specie di log.:
# slapt-get --upgrade
Reading Package Lists... Done
Excluding amarok, use --ignore-dep to override
Excluding aqbanking, use --ignore-dep to override
Excluding cyrus-sasl, use --ignore-dep to override
Excluding gambas, use --ignore-dep to override
Excluding googleearth, use --ignore-dep to override
Excluding gst-plugins-bad, use --ignore-dep to override
Excluding gtk-sharp, use --ignore-dep to override
Excluding gwenhywfar, use --ignore-dep to override
Excluding k3b, use --ignore-dep to override
Excluding kodicefiscale, use --ignore-dep to override
Excluding libchipcard, use --ignore-dep to override
Excluding mplayerplug-in, use --ignore-dep to override
Excluding pulseaudio, use --ignore-dep to override
Excluding scribus, use --ignore-dep to override
Excluding wine, use --ignore-dep to override
The following packages have unmet dependencies:
amarok: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
gwenhywfar: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
cyrus-sasl: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
gambas: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
googleearth: Depends: freetype >= 2.3.7-i486-2
gst-plugins-bad: Depends: mjpegtools >= 1.9.0rc4-i486-2sl
gtk-sharp: Depends: monodoc-2.0-i686-2as
transcode: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
kodicefiscale: Depends: freetype >= 2.3.7-i486-2
mplayerplug-in: Depends: freetype >= 2.3.7-i486-2
pavucontrol: Depends: tdb >= 1.1.2~git20080615_1-i486-1as
scribus: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
wine: Depends: openssl >= 0.9.8i-i486-2_slack12.2 | openssl-solibs >= 0.9.8i-i486-2_slack12.2
The following packages have been EXCLUDED:
amarok aqbanking cyrus-sasl gambas googleearth gst-plugins-bad gtk-sharp
gwenhywfar k3b kodicefiscale libchipcard mplayerplug-in pulseaudio scribus
wine
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
Vito
Nome Cognome: Vito
Desktop: MacOS
Re: gslapt errore nelle dipendenze
Messaggio da Vito »
È un problema di slapt-get!Ha dei problemi con i nomi dei pacchetti....
joma
Messaggio da joma »
allora posso usare la optione --ignore-dep in slapt-get, senza combinare casini?
Vito
Nome Cognome: Vito
Desktop: MacOS
Messaggio da Vito »
per i pacchetti di slacky io lo faccio e non ho mai avuto problemi!
Poi metti caso ti manca una dipendenza..scarichi il pacchetto manualmente. \:D/
