/dev/hdc
/dev/hdc1 ---> / 20gb Primary Bootable
/dev/hdc2 ---> /home/neo 100gb Primary
/dev/hdd
/dev/hdd5 ---> 3gb swap Logical
/dev/hdd6(C:) ---> 37gb windows NTFS BootableCodice: Seleziona tutto
Warning: Unable to determine video adapter in use in the present system.
Warning: Video adapter does not support VESA BIOS extensions needed for
display of 256 colors. Boot loader will fall back to TEXT only operation.
Fatal: Partition entry not found.Codice: Seleziona tutto
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
lba32 # Allow booting past 1024th cylinder with a recent BIOS
# Append any additional kernel parameters:
append=" vt.default_utf8=1"
boot = /dev/hdc
# Boot BMP Image.
# Bitmap in BMP format: 640x480x8
bitmap = /boot/slack.bmp
# Menu colors (foreground, background, shadow, highlighted
# foreground, highlighted background, highlighted shadow):
bmp-colors = 255,0,255,0,255,0
# Location of the option table: location x, location y, number of
# columns, lines per column (max 15), "spill" (this is how many
# entries must be in the first column before the next begins to
# be used. We don't specify it here, as there's just one column.
bmp-table = 60,6,1,16
# Timer location x, timer location y, foreground color,
# background color, shadow color.
bmp-timer = 65,27,0,255
# Standard menu.
# Or, you can comment out the bitmap menu above and
# use a boot message with the standard menu:
#message = /boot/boot_message.txt
# Wait until the timeout to boot (if commented out, boot the
# first entry immediately):
prompt
# Timeout before the first entry boots.
# This is given in tenths of a second, so 600 for every minute:
timeout = 1200
# Override dangerous defaults that rewrite the partition table:
change-rules
reset
vga = 795
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# End LILO global section
# Windows bootable partition config begins
other = /dev/hdd6
label = Windows
table = /dev/hdd
# Windows bootable partition config ends
image = /boot/vmlinuz
root = /dev/hdc1
label = Linux
read-only
Vi prego di aiutarmi [-o< [-o< [-o<
