hplip non parte
Zav0k
Kernel: 2.6.37.3-smp
Desktop: Kde 4.4.5
hplip non parte
Messaggio da Zav0k »
Salve a tutti, ho aggiornato la mia slack alla versione current e sto trovando qualche difficoltà :? .
Vi spiego le prove che ho fatto:
- ho lanciato il comando
root@krasus:/home/theZeus# hp-setup
HP Linux Imaging and Printing System (ver. 3.9.4b)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-9 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
error: Unable to load Qt4 support. Is it installed?
Perchè mi chiede se ho le qt4? :-k
Le qt4 le ho alla versione 4.5.1, ho provato ha reinstallarle ed anche a fare il downgrade alla versione 4.5.0.....ma niente.
- ho provato con:
root@krasus:/home/theZeus# hp-check
Dependency/Version Check Utility ver. 14.3
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the HPLIP supplied tarball (.tar.gz or .run) to determine if the proper
dependencies are installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode will check both of the above cases (both compile- and run-time dependencies).
Saving output in log file: hp-check.log
Initializing. Please wait...
| SYSTEM INFO |
Basic system information:
Linux krasus 2.6.29.1-smp #2 SMP Fri Apr 3 01:59:53 CDT 2009 i686 Intel(R) Core(TM)2 Duo CPU     E8500  @ 3.16GHz GenuineIntel GNU/Linux
Distribution:
unknown 0.0
HPOJ running?
No, HPOJ is not running (OK).
Checking Python version...
OK, version 2.6.2 installed
Checking PyQt 4.x version...
Traceback (most recent call last):
  File "/usr/bin/hp-check", line 297, in <module>
    from PyQt4 import QtCore
ImportError: No module named sip
Ma anche sip ce l'ho installato alla versione 4.7.9 e Pyqt4 alla 4.4.4. :cry:
Non riesco a capire dove sto sbagliando, a qualcuno di voi è mai capitato???
tigerwalk
Slackware: 13.37-14.2
Desktop: kde4/xfce4
Re: hplip non parte
Messaggio da tigerwalk »
Zav0k ha scritto:Salve a tutti, ho aggiornato la mia slack alla versione current e sto trovando qualche difficoltà :? .
- ho provato con:
| SYSTEM INFO |
Distribution:
unknown 0.0
HPOJ running?
guarda il post seguente:
viewtopic.php?f=2&t=27359&p=241296#p241296
vedi se hai installato i pacchetti per la compatibilità con applicazioni kde/qt
Zav0k
Desktop: Kde 4.4.5
Re: hplip non parte
tigerwalk ha scritto: guarda il post seguente:
Ho controllato i pacchetti sono tutti aggiornati. :(
