mplayer segfault
venerdi_12
Nome Cognome: Luciano Fattore
Kernel: 3.0
Desktop: kde-4.7.0
Distribuzione: archlinux
mplayer segfault
Messaggio da venerdi_12 »
Ciao a tutti.
Prima riuscivo a fare il dump di alcuni programmi RAI tramite
mplayer -dumpstream
Per un po' di tempo non ho provato, ma poi qualche giorno fa ho riprovato con questo indirizzo
mplayer -dumpstream http://www.radio.rai.it//radio2/alleotto/ilparadisointerra//archivio_2007/audio/ilparadisointerra2007_04_09.ram
e il risultato è stato
MPlayer SVN-r29169-4.2.4 (C) 2000-2009 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing http://www.radio.rai.it//radio2/alleotto/ilparadisointerra//archivio_2007/audio/ilparadisointerra2007_04_09.ram.
Resolving www.radio.rai.it for AF_INET6...
Couldn't resolve name for AF_INET6: www.radio.rai.it
Resolving www.radio.rai.it for AF_INET...
Connecting to server www.radio.rai.it[212.162.68.25]: 80...
Cache size set to 320 KBytes
Core dumped ;)
Exiting... (End of file)
Senza l'opzione dumpstream il risultato è
Cache fill:  0.00% (0 bytes)
Found plugin: libxmms-flac.so (Reference FLAC Player v1.2.1).
Found plugin: libwav.so (Wave Player 1.2.11).
Found plugin: libvorbis.so (Ogg Vorbis Player 1.2.11).
Found plugin: libtonegen.so (Tone Generator 1.2.11).
Found plugin: libcdaudio.so (CD Audio Player 1.2.11).
Found plugin: libmpg123.so (MPEG Layer 1/2/3 Player 1.2.11).
Found plugin: libla.so (La plugin v0.4).
Found plugin: libmp4.so (MP4 & MPEG2/4-AAC audio player - 1.2.x).
Closing plugin: /usr/lib/xmms/Input/libmp4.so.
Closing plugin: /usr/lib/xmms/Input/libla.so.
MPlayer interrupted by signal 11 in module: demux_open
- MPlayer crashed by bad usage of CPU/FPU/RAM.
  Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
  disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
Segmentation fault
Prima di mettermi a compilare ex novo mpalyer (ora uso l'ultimo di slacky) volevo sapere se era un problema solo mio.
tigerwalk
Slackware: 13.37-14.2
Desktop: kde4/xfce4
Re: mplayer segfault
Messaggio da tigerwalk »
$ mplayer  http://www.radio.rai.it//radio2/alleotto/ilparadisointerra//archivio_2007/audio/ilparadisointerra2007_04_09.ram
MPlayer UNKNOWN-4.2.4 (C) 2000-2009 MPlayer Team
Cache fill:  0.03% (92 bytes)
Core dumped ;)
MPlayer-r29301-i486-1alien.tgz
phobos3576
Kernel: 2.6.37-smp
Desktop: KDE 4.5.3
Messaggio da phobos3576 »
Con -dumpstream il risultato è lo stesso di venerdi_12; senza -dumpstream non succede nulla, però non si verifica il Segmentation Fault.
VLC e RealPlayer eseguono correttamente lo stream audio.
sixjan
Slackware: 14.1
Kernel: 3.10.17-smp
Desktop: Xfce 4.10
Messaggio da sixjan »
Ciao. Stesso errore con mplayer compilato da me. Però, se non vuoi ricompilare c'è una facile soluzione:
wget http://www.radio.rai.it//radio2/alleotto/ilparadisointerra//archivio_2007/audio/ilparadisointerra2007_04_09.ram
cat ilparadisointerra2007_04_09.ram
rtsp://mm3.rai.it/clip1/radio2/torino/alle8/ilparadisointerra/ilparadisointerra2007_04_09.ra
mplayer -dumpstream rtsp://mm3.rai.it/clip1/radio2/torino/alle8/ilparadisointerra/ilparadisointerra2007_04_09.ra
venerdi_12
Kernel: 3.0
Desktop: kde-4.7.0
Eh eh, sarebbe stato troppo facile.
È stata una delle prime cose che ho fatto.
Il risultato è
Playing rtsp://mm3.rai.it/clip1/radio2/torino/alle8/ilparadisointerra/ilparadisointerra2007_04_09.ra.
Cannot dump this stream - no file descriptor available.
Exiting... (Fatal error)
sixjan
Slackware: 14.1
Kernel: 3.10.17-smp
Desktop: Xfce 4.10
E ti pareva... :?
Mi sa che a 'sto punto ti tocca la compilazione. Ciao.
