ho compilato il kernel 2.6.27.10 su slack 12.2 con le varie opzioni msi ecc. attivate. ho fatto il tutto ho scaricato i drivere dal sito della amd della mia scheda video, ho prvato a creare driver e moduli ed ecco il risultato:
# sh ati-driver-installer-9-3-x86.x86_64.run --buildpkg Slackware/All
Created directory fglrx-install.mn1Oax
Verifying archive integrity... All good.
Uncompressing ATI Proprietary Linux Driver-8.593..
ATI Technologies Linux Driver Installer/Packager
Generating package: Slackware/All
ATI SlackBuild Versione 1.3.9
di: Emanuele Tomasi <tomasiATcli.di.unipi.it>
Ezio Ghibaudo <ekxiusATgmail.com>
Federico Rota <federico.rota01ATgmail.com>
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o *.ko *.GCC* .??* *.symvers
make -C /lib/modules/2.6.27.10/build SUBDIRS=/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/linux-2.6.27.10'
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
In file included from /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:169:
/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.h:164:1: warning: "PM_EVENT_SUSPEND" redefined
In file included from include/asm/apic.h:4,
from include/asm/smp.h:13,
from include/linux/smp.h:28,
from include/linux/topology.h:33,
from include/linux/mmzone.h:683,
from include/linux/gfp.h:4,
from include/linux/kmod.h:22,
from include/linux/module.h:13,
from /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:91:
include/linux/pm.h:267:1: warning: this is the location of the previous definition
/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function 'KCL_MEM_VM_GetRegionPhysAddrStr':
/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3223: warning: return makes pointer from integer without a cast
/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3224: warning: return makes pointer from integer without a cast
/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3225: warning: return makes pointer from integer without a cast
/home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3227: warning: return makes pointer from integer without a cast
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_io.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_pci.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_str.o
CC [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/kcl_wait.o
LD [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/fglrx.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/fglrx.mod.o
LD [M] /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx/build_mod/2.6.x/fglrx.ko
make[1]: Leaving directory `/usr/src/linux-2.6.27.10'
build succeeded with return value 0
duplicating results into driver repository...
done.
You must change your working directory to /home/sentenza/slackbuild/fglrx-install.mn1Oax/common/lib/modules/fglrx
and then call ./make_install.sh in order to install the built module.
ERROR: Can't make output package in current directory.
mv: impossibile fare stat di `fglrx-module-8.593-x86-1_kernel_2.6.27.10.tgz': No such file or directory
packages/Slackware/make_x.sh: line 66: usr/X11R6/lib: is a directory
mv: impossibile fare stat di `fglrx-x710-8.593-x86-1.tgz': No such file or directory
Removing temporary directory: fglrx-install.mn1Oax
sinceramente non riesco ad arrivare al problema confido in voi grazie come sempre del vostro prezioso aiuto.
Ultima modifica di Crow il mer 10 giu 2009, 19:11, modificato 1 volta in totale.
ps= questi driver ati fanno piangere NVIDIA forever
EDIT2:
Nella pagina dove scarichi i nuovi driver, dovrebbe esserci a destra in "Helpful links" un collegamento a "Previous Drivers & Software"
Che ti dovrebbe riportare a qualcosa come: http://support.amd.com/us/gpudownload/l ... linux.aspx
ciao a tutti il problema non lo risolto, ho anche compilato il kernel 2.6.28.10 e ho anche scaricato versioni nuove e vecchie dei driver ati ma il problema persiste.
make -C /lib/modules/2.6.28.10/build SUBDIRS=/home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/linux-2.6.28.10'
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
/home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function 'KCL_MEM_VM_GetRegionPhysAddrStr':
/home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3223: warning: return makes pointer from integer without a cast
/home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3224: warning: return makes pointer from integer without a cast
/home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3225: warning: return makes pointer from integer without a cast
/home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3227: warning: return makes pointer from integer without a cast
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_io.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_pci.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_str.o
CC [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/kcl_wait.o
LD [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/fglrx.o
MODPOST 1 modules
CC /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/fglrx.mod.o
LD [M] /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx/build_mod/2.6.x/fglrx.ko
make[1]: Leaving directory `/usr/src/linux-2.6.28.10'
done.
You must change your working directory to /home/sentenza/slackbuild/fglrx-install.6NHJGK/common/lib/modules/fglrx
mv: impossibile fare stat di `fglrx-module-8.582-x86-1_kernel_2.6.28.10.tgz': No such file or directory
Removing temporary directory: fglrx-install.6NHJGK
mv: impossibile fare stat di `fglrx-x710-8.582-x86-1.tgz': No such file or directory
Removing temporary directory: fglrx-install.MIX8rM
Ultima modifica di Crow il mar 9 giu 2009, 17:06, modificato 1 volta in totale.
L'errore è nello SlackBuild. Pat ha aggiunto un sanity check nell'ultima versione di makepkg che impedisce la creazione del pacchetto nella directory corrente. L'errore è il seguente:
Non capisco come mai l'abbia aggiunto. Comunque il problema ora l'ho risolto e nei prossimi driver dovrebbe essere tutto a posto. Dammi un attimo per vedere di fartelo risolvere anche con i driver che hai tu.
sh ati-driver-installer-9-3-x86.x86_64.run --extract casa
cd casa/packages/Slackware/
patch < /tmp/patch_ATI.txt
cd ../../
ati-installer.sh 8.593 --buildpkg
cd ..
i due pacchetti dovrebbero stare nella directory corrente.
grazie per la tua disponibilità spina gentilissimo, allora fin qui sh ati-driver-installer-9-3-x86.x86_64.run --extract casa
tutto ok ma questo
in che directory mi reco per lanciarlo
qui
Reversed (or previously applied) patch detected! Assume -R? [n]
che devo rispondere
edit:
ok scusami spina sono io deficiente alla fine ci sono riuscito, pacchetti creati mo installo configuro xorg.conf e vediamo che succede grazie mille sei stato gentilissimo.
