vi posto lo SlackBuild di emesene 1.5 per slackware 13
emsene.SlackBuild
#!/bin/sh
# http://www.emesene.org
#Packager ScorpionIT
CWD=`pwd`
TMP=${TMP:-/tmp/txz}
PKG=$TMP/package-emesene
NAME=emesene
VERSION=1.5
ARCH=${ARCH:-i486}
BUILD=scm
if [ ! -d $TMP ]; then
mkdir -p $TMP
fi
if [ ! -d $PKG ]; then
mkdir -p $PKG
fi
mkdir -p $PKG/usr/share
cd $PKG/usr/share
tar xvzf $CWD/$NAME-$VERSION.tar.gz
cd $NAME-$VERSION
chown -R root:root .
mkdir -p $PKG/usr/bin
cat << EOF > $PKG/usr/bin/emesene
#!/bin/sh
cd /usr/share/emesene-$VERSION/ && ./emesene
EOF
chmod 755 $PKG/usr/bin/emesene
mkdir -p $PKG/usr/share/icons/
cp -a $PKG/usr/share/emesene-$VERSION/emesene-logo.png $PKG/usr/share/icons/emesene.png
mkdir -p $PKG/usr/share/applications
cat << EOF > $PKG/usr/share/applications/$NAME.desktop
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=emesene
GenericName=MSN(tm) Client
GenericName[it]=Client MSN(tm)
Comment=Windows Live Messenger (tm) network multiplatform client
Comment[it]=Client multipiattaforma per la rete di Windows Live Messenger(tm)
Exec=emesene
Terminal=false
Categories=Application;Network;
EOF
mkdir -p $PKG/usr/doc/$NAME-$VERSION
mv $PKG/usr/share/$NAME-$VERSION/{COPYING,*GPL,PSF} $PKG/usr/doc/$NAME-$VERSION
mkdir -p $PKG/install
echo "if [ -x /usr/bin/update-desktop-database ]; then
/usr/bin/update-desktop-database 1> /dev/null &> /dev/null
fi" >> $PKG/install/doinst.sh
echo >> $PKG/install/doinst.sh
echo "if [ -x /usr/bin/gtk-update-icon-cache ]; then
/usr/bin/gtk-update-icon-cache -f -q /usr/share/icons/hicolor &> /dev/null
echo "cd /usr/share/emesene-1.5" >> $PKG/install/doinst.sh
echo "python setup.py build_ext -i &> /dev/null" >> $PKG/install/doinst.sh
cat $CWD/slack-desc > $PKG/usr/doc/$NAME-$VERSION/slack-desc
cat $CWD/$NAME.SlackBuild > $PKG/usr/doc/$NAME-$VERSION/$NAME.SlackBuild
cd $PKG
requiredbuilder -y -v -s $CWD $PKG
makepkg -l y -c n $CWD/$NAME-$VERSION-$ARCH-$BUILD.txz
if [ "$1" = "--cleanup" ]; then
rm -rf $TMP
fi
# HOW TO EDIT THIS FILE:
# The "handy ruler" below makes it easier to edit a package description. Line
# up the first '|' above the ':' following the base package name, and the '|'
# on the right side marks the last column you can put a character in. You must
# make exactly 11 lines for the formatting to be correct. It's also
# customary to leave one space after the ':'.
|-----handy-ruler----------------------------------------------------|
emesene: emesene
emesene:
emesene: emesene è un programma multipiattaforma di messaggistica istantanea
emesene: per la rete di Windows Live Messenger (tm).
emesene:
emesene:
emesene:
emesene:
emesene:
emesene: Packager ScorpionIT
emesene:
