gigiobagiano
Messaggi: 530 Iscritto il: dom 11 mar 2007, 12:58
Nome Cognome: Filippo
Kernel: vanilla-4.4.38
Distribuzione: SalixOS
Messaggio
da gigiobagiano » sab 5 set 2009, 14:43
Premessa: non sono un packager e neanche un esperto
Prendendo come modello uno slackbuild di alien ho fatto questo per bespin, da prendere con le pinze...
#!/bin/sh
# Filippo Graziola filippo.graziola@gmail.com
NAME=bespin
DIRNAME=cloudcity
VERSION=svn
ARCH=${ARCH:-x86_64}
NUMJOBS=${NUMJOBS:-" -j7 "}
BUILD=${BUILD:-1fg}
SVNSOURCE=https://cloudcity.svn.sourceforge.net/svnroot/cloudcity
DOCS="COPYING COPYNG.LIB INSTALL README"
if [ "$ARCH" = "i486" ]; then
SLKCFLAGS="-O2 -march=i486 -mtune=i686"
LIBDIRSUFFIX=""
elif [ "$ARCH" = "s390" ]; then
SLKCFLAGS="-O2"
LIBDIRSUFFIX=""
SLKCFLAGS="-O2 -fPIC"
LIBDIRSUFFIX="64"
fi
CWD=$(pwd)
TMP=${TMP:-/tmp}
PKG=$TMP/package-bespin
# Avoid a version number in .la files:
if [ -d /usr/lib${LIBDIRSUFFIX}/qt ]; then
QTDIR=/usr/lib${LIBDIRSUFFIX}/qt
fi
rm -rf $PKG
mkdir -p $TMP $PKG
cd $TMP
rm -rf $DIRNAME
#Downloading from svn
svn co $SVNSOURCE
cd $DIRNAME
chown -R root:root .
find . \
\( -perm 777 -o -perm 775 -o -perm 711 -o -perm 555 -o -perm 511 \) \
-exec chmod 755 {} \; -o \
\( -perm 666 -o -perm 664 -o -perm 600 -o -perm 444 -o -perm 440 -o -perm 400 \) \
-exec chmod 644 {} \;
export QTSCRIPTS=/usr/lib${LIBDIRSUFFIX}/qt4/plugins/script
mkdir -p build
cd build
cmake ../ \
-DCMAKE_C_FLAGS:STRING="$SLKCFLAGS" \
-DCMAKE_CXX_FLAGS:STRING="$SLKCFLAGS" \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX=/usr \
-DMAN_INSTALL_DIR=/usr/man \
-DSYSCONF_INSTALL_DIR=/etc/kde \
-DENABLE_ARGB:STRING="OFF" \
-DLIB_SUFFIX=${LIBDIRSUFFIX} \
make $NUMJOBS || make || exit 1
make install DESTDIR=$PKG || exit 1
cd ..
if [ -d $PKG/usr/man ]; then
gzip -9 $PKG/usr/man/man?/*
fi
( cd $PKG
find . | xargs file | grep "executable" | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
find . | xargs file | grep "shared object" | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
#COPYNG DOCS and INSTALL SCRIPTS
mkdir -p $PKG/usr/doc/$NAME-$VERSION
cp -a $DOCS $PKG/usr/doc/$NAME-$VERSION
cat $CWD/bespin.SlackBuild > $PKG/install/bespin.SlackBuild
mkdir -p $PKG/install
zcat $CWD/doinst.sh.gz > $PKG/install/doinst.sh
cd $PKG
/sbin/makepkg -l y -c n $CWD/$NAME-$VERSION-$ARCH-$BUILD.txz
slack-desc.txt
(673 Byte) Scaricato 81 volte
doinst.sh.gz
(118 Byte) Scaricato 77 volte
Ultima modifica di
gigiobagiano il mer 30 set 2009, 16:26, modificato 1 volta in totale.
gigiobagiano
Messaggio
da gigiobagiano » lun 7 set 2009, 15:52
Aggiungo lo slackbuild per Nitrogen (kwin deco):
#!/bin/sh
NAME=nitrogen
VERSION=3.0.1
DIRNAME=kde4-windeco-nitrogen-$VERSION-Source
BUILD=${BUILD:-1fg}
SOURCE=http://www.kde-look.org/CONTENT/content-files/99551-$DIRNAME.tar.gz
DOCS="COPYING INSTALL README"
LIBDIRSUFFIX=""
SLKCFLAGS="-O2"
LIBDIRSUFFIX=""
LIBDIRSUFFIX="64"
fi
CWD=$(pwd)
TMP=${TMP:-/tmp}
PKG=$TMP/package-nitrogen
fi
#Downloading
if [ ! -e *-$DIRNAME.tar.gz ]; then
wget -c $SOURCE
fi
rm -rf $PKG
mkdir -p $TMP $PKG
cd $TMP
rm -rf $DIRNAME
tar xvf $CWD/*-$DIRNAME.tar.gz
cd $DIRNAME
find . \
mkdir -p build
cd build
cmake ../ \
cd ..
fi
( cd $PKG
cat $CWD/$NAME.SlackBuild > $PKG/install/$NAME.SlackBuild
cd $PKG
gigiobagiano
Messaggio
da gigiobagiano » mer 30 set 2009, 16:25
Aggiungo slackbuild per hdaps_monitor (necessita di tp_smapi e hdapsd altrimenti il sistema non controlla i movimenti del disco):
#!/bin/sh
NAME=hdaps_monitor
VERSION=0.3
BUILD=${BUILD:-1fg}
SOURCE=http://www.kde-look.org/CONTENT/content-files/103481-$NAME-$VERSION.tar.gz
if [ ! -e $CWD/*-$NAME-$VERSION.tar.gz ]; then
wget $SOURCE
fi
LIBDIRSUFFIX=""
SLKCFLAGS="-O2"
LIBDIRSUFFIX=""
LIBDIRSUFFIX="64"
fi
CWD=$(pwd)
TMP=${TMP:-/tmp}
PKG=$TMP/package-$NAME
fi
rm -rf $PKG
mkdir -p $TMP $PKG
cd $TMP
rm -rf $NAME
tar xvf $CWD/*-$NAME-$VERSION.tar.gz || exit 1
cd $NAME-$VERSION
find . \
mkdir -p build
cd build
cmake ../ \
cd ../../
fi
# no docs for this package
( cd $PKG
cd $PKG
if [ "$1" = "--cleanup" ]; then
if [ "$TMP" != "/" ]; then
rm -rf $TMP
fi
fi
