Ragazzi ma come faccio a modificare il tempo di lilo quando accendo il computer??? ho provato a modificare la riga "timeout = 200" a "timeout = 50" in modo da passare da 2 minuti a 5 secondi...ma niente !!!
<BR>Se non premo invio con la partizione scelta devo aspettare sempre 2 min...
<BR>Questa è la mia configurazione del file lilo.conf
<BR># LILO configuration file
<BR># generated by ´liloconfig´
<BR>#
<BR># Start LILO global section
<BR>boot = /dev/hda
<BR>message = /boot/boot_message.txt
<BR>prompt
<BR>timeout = 50
<BR># Override dangerous defaults that rewrite the partition table:
<BR>change-rules
<BR> reset
<BR># VESA framebuffer console @ 1024x768x256
<BR>vga = 773
<BR># Normal VGA console
<BR># vga = normal
<BR># VESA framebuffer console @ 1024x768x64k
<BR># vga=791
<BR># VESA framebuffer console @ 1024x768x32k
<BR># vga=790
<BR># vga=773
<BR># VESA framebuffer console @ 800x600x64k
<BR># vga=788
<BR># VESA framebuffer console @ 800x600x32k
<BR># vga=787
<BR># VESA framebuffer console @ 800x600x256
<BR># vga=771
<BR># VESA framebuffer console @ 640x480x64k
<BR># vga=785
<BR># VESA framebuffer console @ 640x480x32k
<BR># vga=784
<BR># VESA framebuffer console @ 640x480x256
<BR># vga=769
<BR># End LILO global section
<BR># Windows bootable partition config begins
<BR>other = /dev/hda1
<BR> label = Windows
<BR> table = /dev/hda
<BR># Windows bootable partition config ends
<BR># Linux bootable partition config begins
<BR>image = /boot/vmlinuz
<BR> root = /dev/hdb1
<BR> label = Linux
<BR> read-only
<BR># Linux bootable partition config ends<br>
Lilo non cambia tempo
- People
- Slackware: 12.1
- Kernel: 2.6.
- Desktop: KDE
Dopo aver modificato il file di configurazione hai dato "lilo -v"... senza virgolette, naturalmante!
<BR>P.<br>
<BR>P.<br>
