[RISOLTO]rc.M modificato e tastiera,mouse non funzionanti
- madtux
- Kernel: 2.6.33.4-smp
- Desktop: xfce
Come da titolo ieri ho modificato il file rc.M.
Ho commentatoi alcuni servizi com mime-update ecc ecc
e al riavvio non parte la tastiera,ne il touch pad
si ferma al login grafico di kde.
Ho eliminato tutti i commenti messi,ma la situazione non cambia.
Qualcuno potrebbe darmi un rc.M funzionante della slackware 13??
Ultima modifica di madtux il mer 21 ott 2009, 20:19, modificato 1 volta in totale.
- tigerwalk
- Nome Cognome: Giuliano della Vecchia
- Slackware: 13.37-14.2
- Kernel: 3.10.17-tiger / 4.4.88-smp
- Desktop: kde4/xfce4
Re: rc.M modificato e tastiera,mouse non funzionanti
#!/bin/sh
# rc.M This file is executed by init(8) when the system is being
# initialized for one of the "multi user" run levels (i.e.
# levels 1 through 6). It usually does mounting of file
# systems et al.
# Version: @(#)/etc/rc.d/rc.M 2.23 Wed Feb 26 19:20:58 PST 2003
# Author: Fred N. van Kempen, <waltje@uwalt.nl.mugnet.org>
# Heavily modified by Patrick Volkerding <volkerdi@slackware.com>
# Tell the viewers what's going to happen.
echo "Going multiuser..."
# Update all the shared library links:
if [ -x /sbin/ldconfig ]; then
echo "Updating shared library links: /sbin/ldconfig &"
/sbin/ldconfig &
fi
# Screen blanks after 15 minutes idle time, and powers down in one hour
# if the kernel supports APM or ACPI power management:
/bin/setterm -blank 15 -powersave powerdown -powerdown 60
# Set the hostname.
if [ -r /etc/HOSTNAME ]; then
/bin/hostname $(cat /etc/HOSTNAME | cut -f1 -d .)
else
# fall back on this old default:
echo "darkstar.example.net" > /etc/HOSTNAME
/bin/hostname darkstar
fi
# Save the contents of 'dmesg':
/bin/dmesg -s 65536 > /var/log/dmesg
# Initialize PCMCIA devices:
# NOTE: This used to be started near the top of rc.S so that PCMCIA devices
# could be fsck'ed along with the other drives. This had some unfortunate
# side effects, however, since root isn't yet read-write, and /var might not
# even be mounted the .pid files can't be correctly written in /var/run and
# the pcmcia system can't be correctly shut down. If you want some PCMCIA
# partition to be mounted at boot (or when the card is inserted) then add
# the appropriate lines to /etc/pcmcia/scsi.opts.
# Note that the stuff in /etc/pcmcia/ is only for 2.4.x kernels using
# 16-bit PCMCIA cards (not 32-bit Cardbus cards!). For example, with a
# wireless card you might need to set options in /etc/pcmcia OR in
# /etc/rc.d/rc.wireless.conf, or even in /etc/rc.d/rc.inet1.conf (with
# extra options if needed for the encryption key, ESSID, etc.)
# Hopefully this situation will be unified in the future, but for now
# that's how it is...
if [ -x /etc/rc.d/rc.pcmcia ]; then
. /etc/rc.d/rc.pcmcia start
# The cards might need a little extra time here to initialize.
sleep 5
fi
# Start the system logger.
if [ -x /etc/rc.d/rc.syslog -a -x /usr/sbin/syslogd -a -d /var/log ]; then
. /etc/rc.d/rc.syslog start
fi
# Update the X font indexes:
if [ -x /usr/bin/fc-cache ]; then
echo "Updating X font indexes: /usr/bin/fc-cache -f &"
fi
# If we are returning from single-user mode we will need to restart
# udevd on systems that use udev:
if grep -wq sysfs /proc/mounts && grep -wq tmpfs /proc/filesystems ; then
if ! grep -wq nohotplug /proc/cmdline ; then
if [ -x /etc/rc.d/rc.udev ]; then
/bin/sh /etc/rc.d/rc.udev start
fi
fi
fi
# Initialize the networking hardware.
if [ -x /etc/rc.d/rc.inet1 ]; then
. /etc/rc.d/rc.inet1
fi
# Look for additional USB/SCSI/IEEE1394/etc devices on multiple LUNs:
if [ -x /etc/rc.d/rc.scanluns ]; then
. /etc/rc.d/rc.scanluns
fi
# Start networking daemons:
if [ -x /etc/rc.d/rc.inet2 ]; then
. /etc/rc.d/rc.inet2
fi
# Mount any additional filesystem types that haven't already been mounted:
mount -a -v 2> /dev/null | grep -v "already mounted"
# Start the Network Time Protocol daemon:
if [ -x /etc/rc.d/rc.ntpd ]; then
sh /etc/rc.d/rc.ntpd start
fi
# Remove stale locks and junk files (must be done after mount -a!)
/bin/rm -f /var/lock/* /var/spool/uucp/LCK..* /tmp/.X*lock /tmp/core /core 2> /dev/null
# Remove stale hunt sockets so the game can start.
if [ -r /tmp/hunt -o -r /tmp/hunt.stats ]; then
echo "Removing your stale hunt sockets from /tmp."
/bin/rm -f /tmp/hunt*
fi
# Ensure basic filesystem permissions sanity.
chmod 755 / 2> /dev/null
chmod 1777 /tmp /var/tmp
# Start APM or ACPI daemon.
# If APM is enabled in the kernel, start apmd:
if [ -e /proc/apm ]; then
if [ -x /usr/sbin/apmd ]; then
echo "Starting APM daemon: /usr/sbin/apmd"
/usr/sbin/apmd
fi
elif [ -x /etc/rc.d/rc.acpid ]; then # otherwise, start acpid:
. /etc/rc.d/rc.acpid start
fi
# Update any existing icon cache files:
if find /usr/share/icons 2> /dev/null | grep -q icon-theme.cache ; then
for theme_dir in /usr/share/icons/* ; do
if [ -r ${theme_dir}/icon-theme.cache ]; then
echo "Updating icon-theme.cache in ${theme_dir}..."
/usr/bin/gtk-update-icon-cache -t -f ${theme_dir} 1> /dev/null 2> /dev/null &
fi
done
# This would be a large file and probably shouldn't be there.
if [ -r /usr/share/icons/icon-theme.cache ]; then
echo "Deleting icon-theme.cache in /usr/share/icons..."
#/usr/bin/gtk-update-icon-cache -t -f /usr/share/icons 1> /dev/null 2> /dev/null &
rm -f /usr/share/icons/icon-theme.cache
fi
fi
# Update mime database:
if [ -x /usr/bin/update-mime-database -a -d /usr/share/mime ]; then
echo "Updating MIME database: /usr/bin/update-mime-database /usr/share/mime &"
/usr/bin/update-mime-database /usr/share/mime 1> /dev/null 2> /dev/null &
fi
# Start D-Bus:
if [ -x /etc/rc.d/rc.messagebus ]; then
sh /etc/rc.d/rc.messagebus start
fi
# Start HAL:
if [ -x /etc/rc.d/rc.hald ]; then
sh /etc/rc.d/rc.hald start
fi
# Start Bluetooth:
if [ -x /etc/rc.d/rc.bluetooth ]; then
sh /etc/rc.d/rc.bluetooth start
fi
# Start wicd:
if [ -x /etc/rc.d/rc.wicd ]; then
sh /etc/rc.d/rc.wicd start
fi
# These GTK+/pango files need to be kept up to date for
# proper input method, pixbuf loaders, and font support.
if [ -x /usr/bin/update-gtk-immodules ]; then
/usr/bin/update-gtk-immodules --verbose
fi
if [ -x /usr/bin/update-gdk-pixbuf-loaders ]; then
/usr/bin/update-gdk-pixbuf-loaders --verbose
fi
if [ -x /usr/bin/update-pango-querymodules ]; then
/usr/bin/update-pango-querymodules --verbose
fi
# Start dnsmasq, a simple DHCP/DNS server:
if [ -x /etc/rc.d/rc.dnsmasq ]; then
/etc/rc.d/rc.dnsmasq start
fi
# Start snmpd:
if [ -x /etc/rc.d/rc.snmpd ]; then
/etc/rc.d/rc.snmpd start
fi
# Start the print spooling system. This will usually be LPRng (lpd) or CUPS.
if [ -x /etc/rc.d/rc.cups ]; then
# Start CUPS:
/etc/rc.d/rc.cups start
elif [ -x /etc/rc.d/rc.lprng ]; then
# Start LPRng (lpd):
. /etc/rc.d/rc.lprng start
fi
# Start netatalk. (a file/print server for Macs using Appletalk)
if [ -x /etc/rc.d/rc.atalk ]; then
/etc/rc.d/rc.atalk
fi
# Start smartd, which monitors the status of S.M.A.R.T. compatible
# hard drives and reports any problems. Note some devices (which aren't
# smart, I guess ;) will hang if probed by smartd, so it's commented out
# by default.
#if [ -x /usr/sbin/smartd ]; then
# /usr/sbin/smartd
#fi
# If we're using udev, make /dev/cdrom and any other optical drive symlinks
# if some udev rule hasn't made them already:
if grep -wq sysfs /proc/mounts && grep -wq tmpfs /proc/filesystems; then
if [ -x /lib/udev/rc.optical-symlinks -a -x /etc/rc.d/rc.udev ]; then
/bin/sh /lib/udev/rc.optical-symlinks
fi
fi
fi
# Monitor the UPS with genpowerd.
# To use this, uncomment this section and edit your settings in
# /etc/genpowerd.conf (serial device, UPS type, etc). For more information,
# see "man genpowerd" or the extensive documentation in the
# /usr/doc/genpower-*/ directory.
# You'll also need to configure a similar block in /etc/rc.d/rc.6 if you want
# support for stopping the UPS's inverter after the machine halts.
#if [ -x /sbin/genpowerd ]; then
# echo "Starting genpowerd daemon..."
# /sbin/genpowerd
#fi
# Turn on process accounting. To enable process accounting, make sure the
# option for BSD process accounting is enabled in your kernel, and then
# create the file /var/log/pacct (touch /var/log/pacct). By default, process
# accounting is not enabled (since /var/log/pacct does not exist). This is
# because the log file can get VERY large.
if [ -x /sbin/accton -a -r /var/log/pacct ]; then
chmod 640 /var/log/pacct
/sbin/accton /var/log/pacct
fi
# Start crond (Dillon's crond):
# If you want cron to actually log activity to /var/log/cron, then change
# -l10 to -l8 to increase the logging level.
if [ -x /usr/sbin/crond ]; then
/usr/sbin/crond -l10 >>/var/log/cron 2>&1
fi
# Start atd (manages jobs scheduled with 'at'):
if [ -x /usr/sbin/atd ]; then
/usr/sbin/atd -b 15 -l 1
fi
# Slackware-Mini-Quota-HOWTO:
# To really activate quotas, you'll need to add 'usrquota' and/or 'grpquota' to
# the appropriate partitions as listed in /etc/fstab. Here's an example:
# /dev/hda2 /home ext3 defaults,usrquota 1 1
# You'll then need to setup initial quota files at the top of the partitions
# to support quota, like this:
# touch /home/aquota.user /home/aquota.group
# chmod 600 /home/aquota.user /home/aquota.group
# Then, reboot to activate the system.
# To edit user quotas, use 'edquota'. See 'man edquota'. Also, the
# official Quota Mini-HOWTO has lots of useful information. That can be found
# here: /usr/doc/Linux-HOWTOs/Quota
# Check quotas and then turn quota system on:
if grep -q quota /etc/fstab ; then
for quotafs in $(awk '/quota/ {print $2}' /etc/fstab) ; do
/bin/rm -f $quotafs/{a,}quota.{group,user}.new
done
if [ -x /sbin/quotacheck ]; then
echo "Checking filesystem quotas: /sbin/quotacheck -avugm"
fi
if [ -x /sbin/quotaon ]; then
echo "Activating filesystem quotas: /sbin/quotaon -avug"
/sbin/quotaon -avug
fi
fi
# Start the SASL authentication server. This provides SASL
# authentication services for sendmail:
if [ -x /etc/rc.d/rc.saslauthd ]; then
. /etc/rc.d/rc.saslauthd start
fi
# Start the sendmail daemon:
if [ -x /etc/rc.d/rc.sendmail ]; then
. /etc/rc.d/rc.sendmail start
fi
# Load ALSA (sound) defaults:
if [ -x /etc/rc.d/rc.alsa ]; then
. /etc/rc.d/rc.alsa
fi
# Load a custom screen font if the user has an rc.font script.
if [ -x /etc/rc.d/rc.font ]; then
. /etc/rc.d/rc.font
fi
# Load a custom keymap if the user has an rc.keymap script.
if [ -x /etc/rc.d/rc.keymap ]; then
. /etc/rc.d/rc.keymap
fi
# Start the MySQL database:
if [ -x /etc/rc.d/rc.mysqld ]; then
. /etc/rc.d/rc.mysqld start
fi
# Start Apache web server:
if [ -x /etc/rc.d/rc.httpd ]; then
. /etc/rc.d/rc.httpd start
fi
# Start OpenLDAP:
if [ -x /etc/rc.d/rc.openldap ]; then
. /etc/rc.d/rc.openldap start
fi
# Start Samba (a file/print server for Win95/NT machines).
# Samba can be started in /etc/inetd.conf instead.
if [ -x /etc/rc.d/rc.samba ]; then
. /etc/rc.d/rc.samba start
fi
# Start the GPM mouse server:
if [ -x /etc/rc.d/rc.gpm ]; then
. /etc/rc.d/rc.gpm start
fi
# If there are SystemV init scripts for this runlevel, run them.
if [ -x /etc/rc.d/rc.sysvinit ]; then
. /etc/rc.d/rc.sysvinit
fi
# Start the local setup procedure.
if [ -x /etc/rc.d/rc.local ]; then
. /etc/rc.d/rc.local
fi
# All done.
- targzeta
- Kernel: latest stable
- Desktop: IceWM
Puoi anche prenderlo direttamente dal pacchetto sysinit-scripts della Slackware sessa con:
P.S. Comunque ti allego quello della Slackware64-current
tar -xf sysvinit-scripts-1.2-noarch-30.txz -O --wildcards '*rc.M.new'> rc.MP.S. Comunque ti allego quello della Slackware64-current
rc.M.txt- (10.65 KiB) Scaricato 64 volte
- madtux
- Desktop: xfce
Porca miseria anche cambiando il file la tastiera sembra morta,stessa cosa il touchpad.
help me [-o< come posso rimediare???
- phobos3576
- Kernel: 2.6.37-smp
- Desktop: KDE 4.5.3
Edita il file /var/log/Xorg.0.log e controlla se ci sono righe che iniziano per (WW) e (EE); generalmente, i messaggi relativi al mouse e alla tastiera si trovano in fondo a quel file.
- madtux
- Desktop: xfce
Questo è il risultato del mio /var/log/Xorg.0.log
le righe interessate sono
come risolvere????
X.Org X Server 1.6.3
Release Date: 2009-7-31
Build Operating System: Slackware 13.0 Slackware Linux Project
Current Operating System: Linux (none) 2.6.29.6-smp #2 SMP Mon Aug 17 00:52:54 CDT 2009 i686
Build Date: 03 August 2009 06:51:50PM
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 20 20:40:38 2009
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(WW) The directory "/usr/share/fonts/local" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/CID" does not exist.
(**) FontPath set to:
/usr/share/fonts/TTF,
/usr/share/fonts/OTF,
/usr/share/fonts/Type1,
/usr/share/fonts/misc,
/usr/share/fonts/75dpi,
/usr/share/fonts/100dpi,
/usr/share/fonts/cyrillic,
built-ins
(**) ModulePath set to "/usr/lib/xorg/modules"
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x1de0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(--) using VT number 7
(--) PCI:*(0:0:2:0) 8086:27a2:1025:0090 rev 3, Mem @ 0xd0200000/524288, 0xc0000000/268435456, 0xd0300000/262144, I/O @ 0x00005088/8
(--) PCI: (0:0:2:1) 8086:27a6:1025:0090 rev 3, Mem @ 0xd0280000/524288
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) No APM support in BIOS or kernel
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers//intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 2.8.0
ABI class: X.Org Video Driver, version 5.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, IGD_GM, IGD_G, 965G, G35,
965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
Mobile Intel® GM45 Express Chipset,
Intel Integrated Graphics Device, G45/G43, Q45/Q43, G41, IGDNG_D,
IGDNG_M
(II) Primary Device is: PCI 00@00:02:0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[4] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[5] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[6] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[7] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[8] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[9] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[10] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 0.1.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
drmOpenDevice: node name is /dev/dri/card0
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns -1
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
(EE) intel(0): [drm] Failed to open DRM device for : No such file or directory
(EE) intel(0): Failed to become DRM master.
(**) intel(0): Depth 24, (--) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel(R) 945GM
(--) intel(0): Chipset: "945GM"
(--) intel(0): Linear framebuffer at 0xC0000000
(--) intel(0): IO registers at addr 0xD0200000 size 524288
(WW) intel(0): libpciaccess reported 0 rom size, guessing 64kB
(II) intel(0): No SDVO device is found in VBT
(II) intel(0): 2 display pipes available.
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) intel(0): Output VGA using monitor section Monitor0
(II) intel(0): Output LVDS has no monitor section
(II) intel(0): I2C bus "LVDSDDC_C" initialized.
(II) intel(0): Attempting to determine panel fixed mode.
(II) intel(0): I2C device "LVDSDDC_C:E-EDID segment register" registered at address 0x60.
(II) intel(0): I2C device "LVDSDDC_C:ddc2" registered at address 0xA0.
(II) intel(0): EDID vendor "AUO", prod id 10100
(II) intel(0): Output TV has no monitor section
(II) intel(0): Output VGA disconnected
(II) intel(0): Output LVDS connected
(II) intel(0): Output TV disconnected
(II) intel(0): Using exact sizes for initial modes
(II) intel(0): Output LVDS using initial mode 1280x800
(II) intel(0): detected 256 kB GTT.
(II) intel(0): detected 7932 kB stolen memory.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
(==) intel(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) intel(0): Comparing regs from server start up to After PreInit
(WW) intel(0): Register 0x61200 (PP_STATUS) changed from 0xc0000008 to 0xd000000a
(WW) intel(0): PP_STATUS before: on, ready, sequencing idle
(WW) intel(0): PP_STATUS after: on, ready, sequencing on
(WW) intel(0): Register 0x71024 (PIPEBSTAT) changed from 0x00000202 to 0x80000242
(WW) intel(0): PIPEBSTAT before: status: VSYNC_INT_STATUS VBLANK_INT_STATUS
(WW) intel(0): PIPEBSTAT after: status: FIFO_UNDERRUN VSYNC_INT_STATUS LBLC_EVENT_STATUS VBLANK_INT_STATUS
(WW) intel(0): Register 0x68000 (TV_CTL) changed from 0x10000000 to 0x000c0000
(WW) intel(0): Register 0x68010 (TV_CSC_Y) changed from 0x00000000 to 0x0332012d
(WW) intel(0): Register 0x68014 (TV_CSC_Y2) changed from 0x00000000 to 0x07d30104
(WW) intel(0): Register 0x68018 (TV_CSC_U) changed from 0x00000000 to 0x0733052d
(WW) intel(0): Register 0x6801c (TV_CSC_U2) changed from 0x00000000 to 0x05c70200
(WW) intel(0): Register 0x68020 (TV_CSC_V) changed from 0x00000000 to 0x0340030c
(WW) intel(0): Register 0x68024 (TV_CSC_V2) changed from 0x00000000 to 0x06d00200
(WW) intel(0): Register 0x6802c (TV_CLR_LEVEL) changed from 0x00000000 to 0x010b00e1
(WW) intel(0): Register 0x68030 (TV_H_CTL_1) changed from 0x00000000 to 0x00400359
(WW) intel(0): Register 0x68034 (TV_H_CTL_2) changed from 0x00000000 to 0x80480022
(WW) intel(0): Register 0x68038 (TV_H_CTL_3) changed from 0x00000000 to 0x007c0344
(WW) intel(0): Register 0x6803c (TV_V_CTL_1) changed from 0x00000000 to 0x00f01415
(WW) intel(0): Register 0x68040 (TV_V_CTL_2) changed from 0x00000000 to 0x00060607
(WW) intel(0): Register 0x68044 (TV_V_CTL_3) changed from 0x00000000 to 0x80120001
(WW) intel(0): Register 0x68048 (TV_V_CTL_4) changed from 0x00000000 to 0x000900f0
(WW) intel(0): Register 0x6804c (TV_V_CTL_5) changed from 0x00000000 to 0x000a00f0
(WW) intel(0): Register 0x68050 (TV_V_CTL_6) changed from 0x00000000 to 0x000900f0
(WW) intel(0): Register 0x68054 (TV_V_CTL_7) changed from 0x00000000 to 0x000a00f0
(WW) intel(0): Register 0x68060 (TV_SC_CTL_1) changed from 0x00000000 to 0xc1710087
(WW) intel(0): Register 0x68064 (TV_SC_CTL_2) changed from 0x00000000 to 0x6b405140
(WW) intel(0): Register 0x68070 (TV_WIN_POS) changed from 0x00000000 to 0x00360024
(WW) intel(0): Register 0x68074 (TV_WIN_SIZE) changed from 0x00000000 to 0x02640198
(WW) intel(0): Register 0x68080 (TV_FILTER_CTL_1) changed from 0x00000000 to 0x800010bb
(WW) intel(0): Register 0x68084 (TV_FILTER_CTL_2) changed from 0x00000000 to 0x00028283
(WW) intel(0): Register 0x68088 (TV_FILTER_CTL_3) changed from 0x00000000 to 0x00014141
(WW) intel(0): Register 0x68100 (TV_H_LUMA_0) changed from 0x00000000 to 0xb1403000
(WW) intel(0): Register 0x681ec (TV_H_LUMA_59) changed from 0x00000000 to 0x0000b060
(WW) intel(0): Register 0x68200 (TV_H_CHROMA_0) changed from 0x00000000 to 0xb1403000
(WW) intel(0): Register 0x682ec (TV_H_CHROMA_59) changed from 0x00000000 to 0x0000b060
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[4] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[5] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[6] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[9] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[10] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) intel(0): Kernel reported 238592 total, 1 used
(II) intel(0): I830CheckAvailableMemory: 954364 kB available
(WW) intel(0): DRI2: failed to open drm device
(**) intel(0): Framebuffer compression enabled
(**) intel(0): Tiling enabled
(**) intel(0): SwapBuffers wait enabled
(EE) intel(0): Failed to initialize kernel memory manager
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): Attempting memory allocation with tiled buffers.
(II) intel(0): Tiled allocation successful.
(II) intel(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(II) UXA(0): Driver registered support for the following operations:
(II) solid
(II) copy
(II) composite (RENDER acceleration)
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(WW) intel(0): drmSetMaster failed: Bad file descriptor
(II) intel(0): adjusting plane->pipe mappings to allow for framebuffer compression
(II) intel(0): xf86BindGARTMemory: bind key 0 at 0x007bf000 (pgoffset 1983)
(II) intel(0): xf86BindGARTMemory: bind key 1 at 0x00e2b000 (pgoffset 3627)
(II) intel(0): xf86BindGARTMemory: bind key 2 at 0x01000000 (pgoffset 4096)
(II) intel(0): Fixed memory allocation layout:
(II) intel(0): 0x00000000-0x0001ffff: ring buffer (128 kB)
(II) intel(0): 0x00020000-0x0061ffff: compressed frame buffer (6144 kB, 0x000000003f820000 physical
(II) intel(0): 0x00620000-0x00620fff: compressed ll buffer (4 kB, 0x000000003fe20000 physical
(II) intel(0): 0x00621000-0x0062afff: HW cursors (40 kB, 0x000000003fe21000 physical
(II) intel(0): 0x0062b000-0x00e2afff: fake bufmgr (8192 kB)
(II) intel(0): 0x007bf000: end of stolen memory
(II) intel(0): 0x00e2b000-0x00e2bfff: overlay registers (4 kB, 0x00000000353b8000 physical
(II) intel(0): 0x01000000-0x017fffff: front buffer (8192 kB) X tiled
(II) intel(0): 0x10000000: end of aperture
(II) intel(0): BO memory allocation layout:
(II) intel(0): Selecting standard 18 bit TMDS pixel format.
(II) intel(0): Output configuration:
(II) intel(0): Pipe A is off
(II) intel(0): Display plane B is now disabled and connected to pipe A.
(II) intel(0): Pipe B is on
(II) intel(0): Display plane A is now enabled and connected to pipe B.
(II) intel(0): Output VGA is connected to pipe none
(II) intel(0): Output LVDS is connected to pipe B
(II) intel(0): Output TV is connected to pipe none
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(II) intel(0): DPMS enabled
(==) intel(0): Intel XvMC decoder disabled
(II) intel(0): Set up textured video
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: Failed
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/xorg/modules/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) intel(0): Setting screen physical size to 331 x 207
- phobos3576
Quei messaggi sono normali quando imposti il mouse e la tastiera da xorg.conf.
Potresti provare a creare un xorg.conf minimale, contenente solo le impostazioni relative al monitor e alla scheda video (prima, salva l'originale da qualche parte); tutto il resto lo dovrebbe fare HAL in automatico.
Hai provato a riavviare il PC?
Magari HAL è momentaneamente andato in tilt e richiede un riavvio del computer.
- brainvision
- Nome Cognome: Leonardo Totaro
- Slackware: x86_64-current
- Kernel: 3.7.1
- Desktop: xfce 4.10
Codice:
(WW) Disabling Keyboard0Scusate, non vorrei sbagliarmi clamorosamente, ma a me risulta che Allow empty devices vuol dire che non sta considerando quelli impostati su xorg.conf ma i devices riconosciuti da HAL.. Se invece volessimo specificarli, in xorg.conf bisogna aggiungere anche l'opzionephobos3576 ha scritto:Quei messaggi sono normali quando imposti il mouse e la tastiera da xorg.conf.
Allow empty devices "false"Mi sto sbagliando??
- ulisse89
- Nome Cognome: Riccardo
- Slackware: 13.0
- Kernel: 2.6.29.6
- Desktop: Xfce
Secondo me devi controllare nel file rc.M se hai disabilitato il demone hald all'avvio. Se l'hai fatto riabilitalo e riavvia. Dopo potrebbe funzionare.
- madtux
- Desktop: xfce
@ulisse89
hal non è disabilitato ma partendo in Single mode,se lo faccio partire si blocca e non ricordo che errore da.
@brainvision
proverò a fare come hai detto tu appena possbile,speriamo
@brainvision
- zoros
- Nome Cognome: Fabio`Zorba`
- Kernel: 5.15.19smp
- Desktop: Trinity R14.0.11
io metterei alla fine di rc.M un echo per capire se lo script gira completamente (perché può essere che qualcosa lo ha killato prima di eseguire tutte le istruzioni):
fi
echo " rc.S ########## Alla donne ############ "
# All done.
- madtux
- Desktop: xfce
Re: [RISOLTO]rc.M modificato e tastiera,mouse non funzionanti
ho risolto con xorgsetup e fatto ripartire hal
