NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: link up.
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
fglrx_pci 0000:02:00.0: irq 28 for MSI/MSI-X
[fglrx] Firegl kernel thread PID: 3073
eth0: no IPv6 routers present
[fglrx] Gart USWC size:631 M.
[fglrx] Gart cacheable size:249 M.
[fglrx] Reserved FB block: Shared offset:0, size:1000000
[fglrx] Reserved FB block: Unshared offset:fe03000, size:1fd000
[fglrx] Reserved FB block: Unshared offset:3fffb000, size:5000
[fglrx] ASIC hang happened
Pid: 3065, comm: X Tainted: P 2.6.29.6-tre #1
Call Trace:
[<f873fc99>] firegl_hardwareHangRecovery+0x19/0x30 [fglrx]
[<f87bca4b>] _ZN4Asic9WaitUntil15ResetASICIfHungEv+0xb/0x20 [fglrx]
[<f87bc9e7>] _ZN4Asic9WaitUntil15WaitForCompleteEv+0x97/0xf0 [fglrx]
[<f87c2766>] _ZN8AsicR60016ASICIdleInternalEN4Asic15idle_WaitMethodE+0x96/0x1f0 [fglrx]
[<f87b98bb>] _ZN7PM4Ring8PM4queueEPPj+0x3b/0xa0 [fglrx]
[<f87c2582>] _ZN8AsicR60010updateWptrEv+0x32/0x50 [fglrx]
[<f87b998d>] _ZN7PM4Ring9PM4submitEPPjb+0x6d/0x110 [fglrx]
[<f87bb0ff>] _ZN4Asic7PM4idleENS_15idle_WaitMethodE+0x6f/0x80 [fglrx]
[<f87b9806>] _ZN7PM4Ring8PM4allocEjPPj+0x56/0xc0 [fglrx]
[<f87bb0dc>] _ZN4Asic7PM4idleENS_15idle_WaitMethodE+0x4c/0x80 [fglrx]
[<f87bae18>] _ZN4Asic9assertPM4Eb+0xf8/0x260 [fglrx]
[<f87c3e83>] _ZN8AsicR6009assertPM4Eb+0x33/0x50 [fglrx]
[<f87969f9>] CMMQS_Initialize_WA+0x149/0x180 [fglrx]
[<f8761973>] firegl_cmmqs_init+0x6a3/0xd10 [fglrx]
[<c01064a0>] sys_modify_ldt+0xd0/0x150
[<f8760bfc>] firegl_cmmqs_createdriver+0x5c/0x170 [fglrx]
[<f875fb58>] firegl_trace+0x28/0x190 [fglrx]
[<f8760ba0>] firegl_cmmqs_createdriver+0x0/0x170 [fglrx]
[<f873aead>] firegl_ioctl+0x22d/0x2b0 [fglrx]
[<f87306f7>] ip_firegl_ioctl+0x17/0x20 [fglrx]
[<c019e278>] vfs_ioctl+0x78/0x90
[<c019e43b>] do_vfs_ioctl+0x7b/0x5b0
[<c0191992>] vfs_write+0x102/0x140
[<c019e9d6>] sys_ioctl+0x66/0x70
[<c010345a>] syscall_call+0x7/0xb
pubdev:0x1f890bee0, num of device:-125671808 , name:<NULL>, major 67, minor 0.
device 0 : 0xf8826680f600e000 .
Asic ID:0x9440, revision:0x2, MMIOReg:0x8f8960000.
FB phys addr: 0xc0000000, MC :0xf00000000, Total FB size :0x40000000.
gart table MC:0xf0fe03000, Physical:0xcfe03000, size:0x1fc000.
mc_node :FB, total 1 zones
MC start:0xf00000000, Physical:0xc0000000, size:0x10000000.
Mapped heap -- Offset:0x0, size:0xfe03000, reference count:1, mapping count:0,
Mapped heap -- Offset:0x0, size:0x1000000, reference count:1, mapping count:0,
Mapped heap -- Offset:0xfe03000, size:0x1fd000, reference count:1, mapping count:0,
mc_node :INV_FB, total 1 zones
MC start:0xf10000000, Physical:0xd0000000, size:0x30000000.
Mapped heap -- Offset:0x2fffb000, size:0x5000, reference count:1, mapping count:0,
mc_node :GART_USWC, total 2 zones
MC start:0x27cb0000, Physical:0x0, size:0x277d0000.
Mapped heap -- Offset:0x10000, size:0x2000000, reference count:1, mapping count:0,
mc_node :GART_CACHEABLE, total 3 zones
MC start:0x10400000, Physical:0x0, size:0x178b0000.
Mapped heap -- Offset:0x0, size:0x200000, reference count:1, mapping count:0,
Mapped heap -- Offset:0xef000, size:0x11000, reference count:1, mapping count:0,
Dump the trace queue.
End of dump
