[RISOLTO] strano errore di compilazione
tom
Nome Cognome: Tommaso D'Anna
Kernel: 2.6.37.6
Messaggio da tom »
allora, ho scaricato da slackbuild.org il seguente slackbuild+sorgenti: http://slackbuilds.org/repository/13.0/ ... /libvdpau/
Lo slackbuild in versione originale è il seguente:
#!/bin/sh
# Slackware build script for libvdpau
# Copyright 2009 Heinz Wiesinger, Amsterdam, The Netherlands
# All rights reserved.
# Redistribution and use of this script, with or without modification, is
# permitted provided that the following conditions are met:
# 1. Redistributions of this script must retain the above copyright
#    notice, this list of conditions and the following disclaimer.
# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ''AS IS'' AND ANY EXPRESS OR IMPLIED
# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
# EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
# OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
# OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
# ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
PRGNAM=libvdpau
VERSION=0.2
ARCH=${ARCH:-i486}
BUILD=${BUILD:-1}
TAG=${TAG:-_SBo}
CWD=$(pwd)
TMP=${TMP:-/tmp/SBo}
PKG=$TMP/package-$PRGNAM
OUTPUT=${OUTPUT:-/tmp}
if [ "$ARCH" = "i486" ]; then
  SLKCFLAGS="-O2 -march=i486 -mtune=i686"
  LIBDIRSUFFIX=""
elif [ "$ARCH" = "i686" ]; then
  SLKCFLAGS="-O2 -march=i686 -mtune=i686"
  LIBDIRSUFFIX=""
  SLKCFLAGS="-O2 -fPIC"
  LIBDIRSUFFIX="64"
fi
set -e
rm -rf $PKG
mkdir -p $TMP $PKG $OUTPUT
cd $TMP
rm -rf $PRGNAM-$VERSION
tar xvf $CWD/$PRGNAM-$VERSION.tar.gz
cd $PRGNAM-$VERSION
chown -R root:root .
chmod -R u+w,go+r-w,a-s .
CFLAGS="$SLKCFLAGS" \
CXXFLAGS="$SLKCFLAGS" \
./configure \
  --prefix=/usr \
  --libdir=/usr/lib${LIBDIRSUFFIX} \
  --sysconfdir=/etc \
  --localstatedir=/var \
  --mandir=/usr/man \
  --disable-static \
  --build=$ARCH-slackware-linux
make
make install-strip DESTDIR=$PKG
find $PKG | xargs file | grep -e "executable" -e "shared object" | grep ELF \
  | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null || true
mkdir -p $PKG/usr/doc/$PRGNAM-$VERSION
cp -a AUTHORS ChangeLog COPYING INSTALL NEWS README \
cat $CWD/$PRGNAM.SlackBuild > $PKG/usr/doc/$PRGNAM-$VERSION/$PRGNAM.SlackBuild
mkdir -p $PKG/install
cd $PKG
/sbin/makepkg -l y -c n $OUTPUT/$PRGNAM-$VERSION-$ARCH-$BUILD$TAG.${PKGTYPE:-tgz}
ad esso ho apportato solo 2 modifiche: ARCH=${ARCH:-i486} è diventato ARCH=${ARCH:-x86_64}, e ${PKGTYPE:-tgz} è diventato ${PKGTYPE:-txz}
Poi ho dato chmod +x libvdpau.SlackBuild ed infine l'ho eseguito. Il risultato è questo:
root@Penelope:/home/tom_slack/Download/libvdpau# ./libvdpau.SlackBuild
libvdpau-0.2/
libvdpau-0.2/acinclude.m4
libvdpau-0.2/autogen.sh
libvdpau-0.2/src/
libvdpau-0.2/src/Makefile.am
libvdpau-0.2/src/Makefile.in
libvdpau-0.2/src/vdpau_wrapper.c
libvdpau-0.2/trace/
libvdpau-0.2/trace/vdpau_trace.cpp
libvdpau-0.2/trace/Makefile.am
libvdpau-0.2/trace/Makefile.in
libvdpau-0.2/include/
libvdpau-0.2/include/vdpau/
libvdpau-0.2/include/vdpau/vdpau_x11.h
libvdpau-0.2/include/vdpau/vdpau.h
libvdpau-0.2/INSTALL
libvdpau-0.2/depcomp
libvdpau-0.2/Makefile.am
libvdpau-0.2/COPYING
libvdpau-0.2/ChangeLog
libvdpau-0.2/configure
libvdpau-0.2/Makefile.in
libvdpau-0.2/configure.ac
libvdpau-0.2/aclocal.m4
libvdpau-0.2/ltmain.sh
libvdpau-0.2/config.sub
libvdpau-0.2/config.h.in
libvdpau-0.2/install-sh
libvdpau-0.2/NEWS
libvdpau-0.2/README
libvdpau-0.2/AUTHORS
libvdpau-0.2/config.guess
libvdpau-0.2/missing
libvdpau-0.2/vdpau.pc.in
checking for a BSD-compatible install... /bin/ginstall -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking build system type... x86_64-slackware-linux-gnu
checking host system type... x86_64-slackware-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/x86_64-slackware-linux/bin/ld
checking if the linker (/usr/x86_64-slackware-linux/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/x86_64-slackware-linux/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking dependency style of g++... (cached) gcc3
checking how to run the C++ preprocessor... g++ -E
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/x86_64-slackware-linux/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for ld used by g++... /usr/x86_64-slackware-linux/bin/ld -m elf_x86_64
checking if the linker (/usr/x86_64-slackware-linux/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/x86_64-slackware-linux/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for X11... yes
checking for dlopen... no
checking for dlopen in -ldl... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating trace/Makefile
config.status: creating vdpau.pc
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
make  all-recursive
make[1]: Entering directory `/tmp/SBo/libvdpau-0.2'
Making all in src
make[2]: Entering directory `/tmp/SBo/libvdpau-0.2/src'
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I..    -I../include  -O2 -fPIC -MT vdpau_wrapper.lo -MD -MP -MF .deps/vdpau_wrapper.Tpo -c -o vdpau_wrapper.lo vdpau_wrapper.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I.. -I../include -O2 -fPIC -MT vdpau_wrapper.lo -MD -MP -MF .deps/vdpau_wrapper.Tpo -c vdpau_wrapper.c  -fPIC -DPIC -o .libs/vdpau_wrapper.o
mv -f .deps/vdpau_wrapper.Tpo .deps/vdpau_wrapper.Plo
/bin/sh ../libtool --tag=CC   --mode=link gcc -I../include  -O2 -fPIC -version-info 1:0:0 -no-undefined  -o libvdpau.la -rpath /usr/lib64 vdpau_wrapper.lo -ldl
libtool: link: gcc -shared  .libs/vdpau_wrapper.o   -ldl    -Wl,-soname -Wl,libvdpau.so.1 -o .libs/libvdpau.so.1.0.0
libtool: link: (cd ".libs" && rm -f "libvdpau.so.1" && ln -s "libvdpau.so.1.0.0" "libvdpau.so.1")
libtool: link: (cd ".libs" && rm -f "libvdpau.so" && ln -s "libvdpau.so.1.0.0" "libvdpau.so")
libtool: link: ( cd ".libs" && rm -f "libvdpau.la" && ln -s "../libvdpau.la" "libvdpau.la" )
make[2]: Leaving directory `/tmp/SBo/libvdpau-0.2/src'
Making all in trace
make[2]: Entering directory `/tmp/SBo/libvdpau-0.2/trace'
/bin/sh ../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I..    -I../include  -O2 -fPIC -MT vdpau_trace.lo -MD -MP -MF .deps/vdpau_trace.Tpo -c -o vdpau_trace.lo vdpau_trace.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I.. -I../include -O2 -fPIC -MT vdpau_trace.lo -MD -MP -MF .deps/vdpau_trace.Tpo -c vdpau_trace.cpp  -fPIC -DPIC -o .libs/vdpau_trace.o
mv -f .deps/vdpau_trace.Tpo .deps/vdpau_trace.Plo
/bin/sh ../libtool --tag=CXX   --mode=link g++ -I../include  -O2 -fPIC -avoid-version -module -no-undefined  -o libvdpau_trace.la -rpath /usr/lib64 vdpau_trace.lo -ldl
libtool: link: g++ -shared -nostdlib /usr/lib64/gcc/x86_64-slackware-linux/4.3.3/../../../../lib64/crti.o /usr/lib64/gcc/x86_64-slackware-linux/4.3.3/crtbeginS.o  .libs/vdpau_trace.o   -Wl,-rpath -Wl,/usr/lib64/../lib64 -Wl,-rpath -Wl,/usr/lib64/../lib64 -ldl -L/usr/lib64/gcc/x86_64-slackware-linux/4.3.3 -L/usr/lib64/gcc/x86_64-slackware-linux/4.3.3/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib64/gcc/x86_64-slackware-linux/4.3.3/../../../../x86_64-slackware-linux/lib -L/usr/lib64/gcc/x86_64-slackware-linux/4.3.3/../../.. /usr/lib64/../lib64/libstdc++.so -lm -lc -lgcc_s /usr/lib64/gcc/x86_64-slackware-linux/4.3.3/crtendS.o /usr/lib64/gcc/x86_64-slackware-linux/4.3.3/../../../../lib64/crtn.o    -Wl,-soname -Wl,libvdpau_trace.so -o .libs/libvdpau_trace.so
libtool: link: ( cd ".libs" && rm -f "libvdpau_trace.la" && ln -s "../libvdpau_trace.la" "libvdpau_trace.la" )
make[2]: Leaving directory `/tmp/SBo/libvdpau-0.2/trace'
make[2]: Entering directory `/tmp/SBo/libvdpau-0.2'
make[2]: Leaving directory `/tmp/SBo/libvdpau-0.2'
make[1]: Leaving directory `/tmp/SBo/libvdpau-0.2'
make  INSTALL_PROGRAM="/bin/sh /tmp/SBo/libvdpau-0.2/install-sh -c -s" \
          install_sh_PROGRAM="/bin/sh /tmp/SBo/libvdpau-0.2/install-sh -c -s" INSTALL_STRIP_FLAG=-s \
          `test -z 'strip' || \
            echo "INSTALL_PROGRAM_ENV=STRIPPROG='strip'"` install
Making install in src
make[3]: Entering directory `/tmp/SBo/libvdpau-0.2/src'
test -z "/usr/lib64" || /bin/mkdir -p "/tmp/SBo/package-libvdpau/usr/lib64"
 /bin/sh ../libtool   --mode=install /bin/ginstall -c -s 'libvdpau.la' '/tmp/SBo/package-libvdpau/usr/lib64/libvdpau.la'
libtool: install: /bin/ginstall -c .libs/libvdpau.so.1.0.0 /tmp/SBo/package-libvdpau/usr/lib64/libvdpau.so.1.0.0
libtool: install: strip --strip-unneeded /tmp/SBo/package-libvdpau/usr/lib64/libvdpau.so.1.0.0
libtool: install: (cd /tmp/SBo/package-libvdpau/usr/lib64 && { ln -s -f libvdpau.so.1.0.0 libvdpau.so.1 || { rm -f libvdpau.so.1 && ln -s libvdpau.so.1.0.0 libvdpau.so.1; }; })
libtool: install: (cd /tmp/SBo/package-libvdpau/usr/lib64 && { ln -s -f libvdpau.so.1.0.0 libvdpau.so || { rm -f libvdpau.so && ln -s libvdpau.so.1.0.0 libvdpau.so; }; })
libtool: install: /bin/ginstall -c .libs/libvdpau.lai /tmp/SBo/package-libvdpau/usr/lib64/libvdpau.la
libtool: install: warning: remember to run `libtool --finish /usr/lib64'
test -z "/usr/include/vdpau" || /bin/mkdir -p "/tmp/SBo/package-libvdpau/usr/include/vdpau"
 /bin/ginstall -c -m 644 '../include/vdpau/vdpau.h' '/tmp/SBo/package-libvdpau/usr/include/vdpau/vdpau.h'
 /bin/ginstall -c -m 644 '../include/vdpau/vdpau_x11.h' '/tmp/SBo/package-libvdpau/usr/include/vdpau/vdpau_x11.h'
make[3]: Leaving directory `/tmp/SBo/libvdpau-0.2/src'
Making install in trace
make[3]: Entering directory `/tmp/SBo/libvdpau-0.2/trace'
 /bin/sh ../libtool   --mode=install /bin/ginstall -c -s 'libvdpau_trace.la' '/tmp/SBo/package-libvdpau/usr/lib64/libvdpau_trace.la'
libtool: install: /bin/ginstall -c .libs/libvdpau_trace.so /tmp/SBo/package-libvdpau/usr/lib64/libvdpau_trace.so
libtool: install: strip --strip-unneeded /tmp/SBo/package-libvdpau/usr/lib64/libvdpau_trace.so
libtool: install: /bin/ginstall -c .libs/libvdpau_trace.lai /tmp/SBo/package-libvdpau/usr/lib64/libvdpau_trace.la
make[3]: Leaving directory `/tmp/SBo/libvdpau-0.2/trace'
make[3]: Entering directory `/tmp/SBo/libvdpau-0.2'
make[3]: Nothing to be done for `install-exec-am'.
test -z "/usr/lib64/pkgconfig" || /bin/mkdir -p "/tmp/SBo/package-libvdpau/usr/lib64/pkgconfig"
 /bin/ginstall -c -m 644 'vdpau.pc' '/tmp/SBo/package-libvdpau/usr/lib64/pkgconfig/vdpau.pc'
make[3]: Leaving directory `/tmp/SBo/libvdpau-0.2'
Usage: makepkg package_name.tgz
       (or: package_name.tbz, package_name.tlz, package_name.txz)
Makes a Slackware compatible package containing the contents of the current
and all subdirectories.  If symbolic links exist, they will be removed and
an installation script will be made to recreate them later. This script will
be called "install/doinst.sh". You may add any of your own ash-compatible
shell scripts to this file and rebuild the package if you wish.
options:  -l, --linkadd y|n (moves symlinks into doinst.sh: recommended)
          -p, --prepend (prepend rather than append symlinks to an existing
                         doinst.sh.  Useful to link libraries needed by
                         programs in the doinst.sh script)
          -c, --chown y|n (resets all permissions to root:root 755
                           - not generally recommended)
If these options are not set, makepkg will prompt as appropriate.
./libvdpau.SlackBuild: line 85: /tmp/libvdpau-0.2-x86_64-1_SBo.txz: No such file or directory
Ci sono 2 cose stranissime:
1) se rimodifico nello slackbuild txz in tgz il risultato non cambia mi dà lo stesso messaggio di errore
2) se invece ELIMINO la directory di lavoro, e poi riscompatto il tar.gz (con lo slackbuild dentro), gli infilo i sorgenti e modifico nello slackbuild nuovo SOLTANTO i486 con X86_64, ottenendo pertanto lo stesso IDENTICO slackbuild del punto 1, la compilazione allora va a buon fine.
Perchè?
PS: Slackware64 appena installata, che sia un bug che è stato risolto con gli aggiornamenti di sicurezza?
Ultima modifica di tom il mar 19 gen 2010, 15:46, modificato 1 volta in totale.
tom
Kernel: 2.6.37.6
Re: strano errore di compilazione
Messaggio da tom »
3) ho scaricato lo slackbuild da qui: http://people.salixos.org/tasodan/x86_6 ... vdpau/src/
ed è già in formato txz e, come potete vedere, a parte qualche piccolissimo dettaglio, è identico a quell'altro. Ma la compilazione va.
Insomma in poche parole se scarico uno slackbuild e lo compilo senza modificare l'estensione del pacchetto che ne verrà fuori (che sia tgz o txz) la compilazione va a buon fine, se invece modifico l'estensione del pacchetto (da tgz a txz) non va più, neanche se poi ritorno indietro sui miei passi (di nuovo da txz a tgz).
Tutto ciò mi sa di assurdo...come mai succede?
mcosta
Nome Cognome: Massimo Costa
Kernel: 2.6.29.6
Desktop: KDE 4.2.4
Messaggio da mcosta »
L'errore che hai descritto sembra un problema di invocazione di makepkg quindi io farei un echo della linea di comando.
comunque per la cronaca la sintassi
${ARCH:-i686}
sta ad indicare che se la variabile ARCH non è definita gli assegna il valore i486.
Quindi invece di modificare lo Sackbuild puoi definire le variabili ARCH e PKGTYPE fuori dallo script e poi lanciarlo.
IO faccio così
#export ARCH=x86_64
#export PKGTYPE=txz
#./xxxx.Slackbuild
Vic Steele
Nome Cognome: Luigi Caiazza
Slackware: current x86_64
Kernel: 3.0.0
Desktop: Fluxbox / KDE 4.7.0
Distribuzione: Fedora 15
Messaggio da Vic Steele »
Per me è una cosa ancora più semplice: modifichi con nano e con la finestra della console in piccolo?
Perché ti manda un a capo automatico quando la finestra è troppo piccola per contenere la riga, una vera porcheria :D .
Assumi il fatto che l'ultima riga (quella del makepkg) sia una sola linea e non due.
414N
Kernel: 5.15.19
Messaggio da 414N »
Tanto per essere pignoli, questo non è un problema di compilazione. Se guardi il listato di compilazione che hai riportato, tutto procede liscio (persino l'installazione successiva alla compilazione) mentre la procedura fallisce quando viene invocato il comando makepkg, e la shell ti restituisce un errore sulla riga 85, dicendo che il file del pacchetto che vuoi costruire non esiste.
Molto probabilmente, come ha già scritto Vic Steele, questo è dovuto ad un "a capo" di troppo, che ha spezzato la riga di invocazione di makepkg richiamandolo senza un parametro fondamentale (il path del pacchetto da creare) e, in seguito, tentando di lanciare il file del pacchetto ancora inesistente ergo -> EPIC FAIL :) .
tom
Kernel: 2.6.37.6
Messaggio da tom »
ma noooo....ma dai è assurdo!!!! Ora non sono con il mio computer ma sto notando questa cosa e praticamente sono sicuro che il problema sia quello che avete inquadrato :geniale:
Ma questa porcheria di aggiungere automaticamente un "a capo" per far entrare la riga nella finestra della shell più che essere un problema di nano ho l'impressione che sia un bug (a mio parere pure gravissimo) di konsole, visto che fino a qualche giorno fa usavo salix (derivata di slack che usa xfce), e con il terminale di xfce ciò non succedeva.
La versione di kde che ho è quella nativa di slackware 13.0, cioè la 4.2.4. Che voi sappiate attualmente c'è ancora questo bug con le versioni più aggiornate di kde (4.3.4 - 4.4.rc1; potete controllare aprendo un qualsiasi documento), o e stato risolto?
414N
Kernel: 5.15.19
Messaggio da 414N »
tasodan ha scritto: Ma questa porcheria di aggiungere automaticamente un "a capo" per far entrare la riga nella finestra della shell più che essere un problema di nano ho l'impressione che sia un bug (a mio parere pure gravissimo) di konsole, visto che fino a qualche giorno fa usavo salix (derivata di slack che usa xfce), e con il terminale di xfce ciò non succedeva.
Io con vim in konsole non ho mai avuto di questi problemi...
Mario Vanoni
Nome Cognome: Mario Vanoni
Kernel: 3.0.4 statico
Desktop: fluxbox/seamonkey
Messaggio da Mario Vanoni »
Non uso vim, ma nvi di Berkeley:
sia su un xterm piccolo di 80 righe, che a livello tty/sh,
se scrivo 1000 caratteri, poi un a capo (Return/Enter/Invio),
la riga e` sempre lunga 1000 caratteri!
tom
Kernel: 2.6.37.6
Messaggio da tom »
Come avevate bene inquadrato, il problema era proprio quello. Risolto :D
