Stavo compilando lo slackbluild di GConf ed ecco che:
root@tux:/home/luca/GConf# ./GConf.SlackBuild
GConf-2.26.0/
GConf-2.26.0/TODO
GConf-2.26.0/AUTHORS
GConf-2.26.0/NEWS
GConf-2.26.0/ltmain.sh
GConf-2.26.0/tests/
GConf-2.26.0/tests/testchangeset.c
GConf-2.26.0/tests/testaddress.c
GConf-2.26.0/tests/testschemas.c
GConf-2.26.0/tests/testdirlist.c
GConf-2.26.0/tests/testlisteners.c
GConf-2.26.0/tests/testunique.c
GConf-2.26.0/tests/testbackend.c
GConf-2.26.0/tests/Makefile.in
GConf-2.26.0/tests/Makefile.am
GConf-2.26.0/tests/testgconf.c
GConf-2.26.0/tests/testpersistence.c
GConf-2.26.0/tests/testencode.c
GConf-2.26.0/examples/
GConf-2.26.0/examples/basic-gconf-app.schemas
GConf-2.26.0/examples/simple-view.c
GConf-2.26.0/examples/simple-controller.c
GConf-2.26.0/examples/basic-gconf-app.c
GConf-2.26.0/examples/Makefile.in
GConf-2.26.0/examples/Makefile.am
GConf-2.26.0/gconf/
GConf-2.26.0/gconf/gconf-backend.h
GConf-2.26.0/gconf/gconf-database.c
GConf-2.26.0/gconf/gconf-changeset.c
GConf-2.26.0/gconf/gconf-error.c
GConf-2.26.0/gconf/gconf-value.c
GConf-2.26.0/gconf/gconf-listeners.c
GConf-2.26.0/gconf/gconf-value.h
GConf-2.26.0/gconf/gconf.c
GConf-2.26.0/gconf/gconf-enum-types.c
GConf-2.26.0/gconf/gconf-client.c
GConf-2.26.0/gconf/gconf.h
GConf-2.26.0/gconf/gconftool.c
GConf-2.26.0/gconf/gconf-engine.h
GConf-2.26.0/gconf/GConfX.idl
GConf-2.26.0/gconf/gconf-locale.c
GConf-2.26.0/gconf/gconf-sources.h
GConf-2.26.0/gconf/gconf-enum-types.h
GConf-2.26.0/gconf/regenerate-enum-footer.sh
GConf-2.26.0/gconf/gconfd.c
GConf-2.26.0/gconf/gconf-listeners.h
GConf-2.26.0/gconf/gconfd.h
GConf-2.26.0/gconf/gconf-changeset.h
GConf-2.26.0/gconf/gconf-schema.h
GConf-2.26.0/gconf/gconf-database.h
GConf-2.26.0/gconf/gconf-internals.h
GConf-2.26.0/gconf/gconf-locale.h
GConf-2.26.0/gconf/gconf-error.h
GConf-2.26.0/gconf/gconf-backend.c
GConf-2.26.0/gconf/dllmain.c
GConf-2.26.0/gconf/gconf-sources.c
GConf-2.26.0/gconf/Makefile.in
GConf-2.26.0/gconf/gconf-client.h
GConf-2.26.0/gconf/Makefile.am
GConf-2.26.0/gconf/gconfmarshal.list
GConf-2.26.0/gconf/gconf-schema.c
GConf-2.26.0/gconf/gconf-internals.c
GConf-2.26.0/gconf/org.gnome.GConf.service.in
GConf-2.26.0/gconf/regenerate-enum-header.sh
GConf-2.26.0/gconf/gconf-sanity-check.c
GConf-2.26.0/gconf/default.path.in
GConf-2.26.0/depcomp
GConf-2.26.0/gtk-doc.make
GConf-2.26.0/mkinstalldirs
GConf-2.26.0/ChangeLog
GConf-2.26.0/gconf-2.m4.in
GConf-2.26.0/missing
GConf-2.26.0/config.sub
GConf-2.26.0/configure.in
GConf-2.26.0/defaults/
GConf-2.26.0/defaults/gconf-defaults-main.c
GConf-2.26.0/defaults/org.gnome.GConf.Defaults.service.in
GConf-2.26.0/defaults/org.gnome.GConf.Defaults.conf
GConf-2.26.0/defaults/gconf-defaults.xml
GConf-2.26.0/defaults/gconf-defaults-glue.h
GConf-2.26.0/defaults/Makefile.in
GConf-2.26.0/defaults/Makefile.am
GConf-2.26.0/defaults/org.gnome.gconf.defaults.policy.in
GConf-2.26.0/defaults/gconf-defaults.c
GConf-2.26.0/defaults/gconf-defaults.h
GConf-2.26.0/config.h.in
GConf-2.26.0/intltool-extract.in
GConf-2.26.0/README
GConf-2.26.0/backends/
GConf-2.26.0/backends/xml-dir.c
GConf-2.26.0/backends/xml-entry.c
GConf-2.26.0/backends/markup-tree.h
GConf-2.26.0/backends/markup-backend.c
GConf-2.26.0/backends/evoldap-backend.c
GConf-2.26.0/backends/xml-backend.c
GConf-2.26.0/backends/markup-tree.c
GConf-2.26.0/backends/xml-entry.h
GConf-2.26.0/backends/evoldap.conf
GConf-2.26.0/backends/xml-dir.h
GConf-2.26.0/backends/xml-test.c
GConf-2.26.0/backends/evoldap.schema
GConf-2.26.0/backends/xml-cache.h
GConf-2.26.0/backends/Makefile.in
GConf-2.26.0/backends/Makefile.am
GConf-2.26.0/backends/gconf-merge-tree.c
GConf-2.26.0/backends/README.evoldap
GConf-2.26.0/backends/xml-cache.c
GConf-2.26.0/po/
GConf-2.26.0/po/te.po
GConf-2.26.0/po/he.po
GConf-2.26.0/po/pt_BR.po
GConf-2.26.0/po/ms.po
GConf-2.26.0/po/ka.po
GConf-2.26.0/po/ko.po
GConf-2.26.0/po/sv.po
GConf-2.26.0/po/pt.po
GConf-2.26.0/po/is.po
GConf-2.26.0/po/it.po
GConf-2.26.0/po/am.po
GConf-2.26.0/po/bg.po
GConf-2.26.0/po/ku.po
GConf-2.26.0/po/xh.po
GConf-2.26.0/po/nl.po
GConf-2.26.0/po/ru.po
GConf-2.26.0/po/oc.po
GConf-2.26.0/po/mk.po
GConf-2.26.0/po/vi.po
GConf-2.26.0/po/fa.po
GConf-2.26.0/po/fr.po
GConf-2.26.0/po/ChangeLog
GConf-2.26.0/po/hi.po
GConf-2.26.0/po/pa.po
GConf-2.26.0/po/cy.po
GConf-2.26.0/po/hr.po
GConf-2.26.0/po/bs.po
GConf-2.26.0/po/de.po
GConf-2.26.0/po/LINGUAS
GConf-2.26.0/po/si.po
GConf-2.26.0/po/nn.po
GConf-2.26.0/po/POTFILES.skip
GConf-2.26.0/po/sl.po
GConf-2.26.0/po/POTFILES.in
GConf-2.26.0/po/uk.po
GConf-2.26.0/po/lt.po
GConf-2.26.0/po/ga.po
GConf-2.26.0/po/en_GB.po
GConf-2.26.0/po/mr.po
GConf-2.26.0/po/mg.po
GConf-2.26.0/po/ta.po
GConf-2.26.0/po/ro.po
GConf-2.26.0/po/be.po
GConf-2.26.0/po/el.po
GConf-2.26.0/po/ar.po
GConf-2.26.0/po/lv.po
GConf-2.26.0/po/tr.po
GConf-2.26.0/po/or.po
GConf-2.26.0/po/zh_TW.po
GConf-2.26.0/po/kn.po
GConf-2.26.0/po/sr.po
GConf-2.26.0/po/gu.po
GConf-2.26.0/po/zh_CN.po
GConf-2.26.0/po/ca.po
GConf-2.26.0/po/bn.po
GConf-2.26.0/po/nb.po
GConf-2.26.0/po/sr@latin.po
GConf-2.26.0/po/az.po
GConf-2.26.0/po/pl.po
GConf-2.26.0/po/Makefile.in.in
GConf-2.26.0/po/da.po
GConf-2.26.0/po/ml.po
GConf-2.26.0/po/rw.po
GConf-2.26.0/po/mn.po
GConf-2.26.0/po/bn_IN.po
GConf-2.26.0/po/hu.po
GConf-2.26.0/po/fi.po
GConf-2.26.0/po/sk.po
GConf-2.26.0/po/ne.po
GConf-2.26.0/po/eu.po
GConf-2.26.0/po/en_CA.po
GConf-2.26.0/po/es.po
GConf-2.26.0/po/sq.po
GConf-2.26.0/po/ja.po
GConf-2.26.0/po/zh_HK.po
GConf-2.26.0/po/gl.po
GConf-2.26.0/po/cs.po
GConf-2.26.0/po/dz.po
GConf-2.26.0/po/mai.po
GConf-2.26.0/po/et.po
GConf-2.26.0/po/as.po
GConf-2.26.0/po/th.po
GConf-2.26.0/po/yi.po
GConf-2.26.0/po/id.po
GConf-2.26.0/config.guess
GConf-2.26.0/gconf-zip.in
GConf-2.26.0/intltool-update.in
GConf-2.26.0/ABOUT-NLS
GConf-2.26.0/doc/
GConf-2.26.0/doc/gconf/
GConf-2.26.0/doc/gconf/gconf-overrides.txt
GConf-2.26.0/doc/gconf/xml/
GConf-2.26.0/doc/gconf/xml/gconf-engine.xml
GConf-2.26.0/doc/gconf/xml/api-index-2.4.xml
GConf-2.26.0/doc/gconf/xml/gconf-backend.xml
GConf-2.26.0/doc/gconf/xml/gconf.xml
GConf-2.26.0/doc/gconf/xml/api-index-deprecated.xml
GConf-2.26.0/doc/gconf/xml/gconf-changeset.xml
GConf-2.26.0/doc/gconf/xml/gconf-internals.xml
GConf-2.26.0/doc/gconf/xml/api-index-full.xml
GConf-2.26.0/doc/gconf/xml/api-index-2.8.xml
GConf-2.26.0/doc/gconf/xml/gconf-value.xml
GConf-2.26.0/doc/gconf/xml/api-index-2.4..xml
GConf-2.26.0/doc/gconf/xml/gconf-error.xml
GConf-2.26.0/doc/gconf/xml/gconf-sources.xml
GConf-2.26.0/doc/gconf/xml/gconf-locale.xml
GConf-2.26.0/doc/gconf/xml/gconf-client.xml
GConf-2.26.0/doc/gconf/xml/gconf-schema.xml
GConf-2.26.0/doc/gconf/xml/gconf-listeners.xml
GConf-2.26.0/doc/gconf/gconf.types
GConf-2.26.0/doc/gconf/gconf-sections.txt
GConf-2.26.0/doc/gconf/tmpl/
GConf-2.26.0/doc/gconf/tmpl/gconf-orbit.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-locale.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-client.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-sources.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-backend.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-internals.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-unused.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-changeset.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-listeners.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-value.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-schema.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-engine.sgml
GConf-2.26.0/doc/gconf/tmpl/gconf-error.sgml
GConf-2.26.0/doc/gconf/Makefile.in
GConf-2.26.0/doc/gconf/Makefile.am
GConf-2.26.0/doc/gconf/gconf-docs.sgml
GConf-2.26.0/doc/gconf/html/
GConf-2.26.0/doc/gconf/html/style.css
GConf-2.26.0/doc/gconf/html/up.png
GConf-2.26.0/doc/gconf/html/gconf-gconf.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-schema.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-error.html
GConf-2.26.0/doc/gconf/html/left.png
GConf-2.26.0/doc/gconf/html/gconf.devhelp
GConf-2.26.0/doc/gconf/html/gconf.devhelp2
GConf-2.26.0/doc/gconf/html/right.png
GConf-2.26.0/doc/gconf/html/gconf-gconf-changeset.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-backend.html
GConf-2.26.0/doc/gconf/html/home.png
GConf-2.26.0/doc/gconf/html/gconf-gconf-listeners.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-internals.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-locale.html
GConf-2.26.0/doc/gconf/html/index.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-engine.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-value.html
GConf-2.26.0/doc/gconf/html/gconf-GConfClient.html
GConf-2.26.0/doc/gconf/html/gconf-gconf-sources.html
GConf-2.26.0/doc/gconf/html/index.sgml
GConf-2.26.0/doc/gconf/html/ch01.html
GConf-2.26.0/doc/gconf-1.0.dtd
GConf-2.26.0/doc/FAQ.txt
GConf-2.26.0/doc/gconftool-2.1
GConf-2.26.0/doc/Makefile.in
GConf-2.26.0/doc/Makefile.am
GConf-2.26.0/Makefile.in
GConf-2.26.0/Makefile.am
GConf-2.26.0/aclocal.m4
GConf-2.26.0/gconf-2.0.pc.in
GConf-2.26.0/INSTALL
GConf-2.26.0/install-sh
GConf-2.26.0/intltool-merge.in
GConf-2.26.0/COPYING
checking for a BSD-compatible install... /bin/ginstall -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking build system type... x86_64-slackware-linux-gnu
checking host system type... x86_64-slackware-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name...
configure: error: in `/tmp/SBo/GConf-2.26.0':
configure: error: C compiler cannot create executables
See `config.log' for more details.
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by GConf configure 2.26.0, which was
generated by GNU Autoconf 2.63. Invocation command line was
$ ./configure
## Platform. ##
hostname = tux
uname -m = x86_64
uname -r = 2.6.32.7
uname -s = Linux
uname -v = #2 SMP Fri Jan 29 22:53:20 CST 2010
/usr/bin/uname -p = Intel(R) Pentium(R) 4 CPU 3.00GHz
/bin/uname -X = unknown
/bin/arch = x86_64
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /sbin
PATH: /usr/sbin
PATH: /bin
PATH: /usr/bin
## Core tests. ##
configure:2227: checking for a BSD-compatible install
configure:2295: result: /bin/ginstall -c
configure:2306: checking whether build environment is sane
configure:2349: result: yes
configure:2374: checking for a thread-safe mkdir -p
configure:2413: result: /bin/mkdir -p
configure:2426: checking for gawk
configure:2442: found /bin/gawk
configure:2453: result: gawk
configure:2464: checking whether make sets $(MAKE)
configure:2486: result: yes
configure:2671: checking whether to enable maintainer-specific portions of Makefiles
configure:2680: result: no
configure:2700: checking build system type
configure:2718: result: x86_64-unknown-linux-gnu
configure:2740: checking host system type
configure:2755: result: x86_64-unknown-linux-gnu
configure:2856: checking for gcc
configure:2872: found /usr/bin/gcc
configure:2883: result: gcc
configure:3115: checking for C compiler version
configure:3123: gcc --version >&5
gcc (GCC) 4.4.3
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3127: $? = 0
configure:3134: gcc -v >&5
Reading specs from /usr/lib64/gcc/x86_64-slackware-linux/4.4.3/specs
Target: x86_64-slackware-linux
Configured with: ../gcc-4.4.3/configure --prefix=/usr --libdir=/usr/lib64 --enable-shared --enable-bootstrap --enable-languages=ada,c,c++,fortran,java,objc --enable-threads=posix --enable-checking=release --with-system-zlib --with-python-dir=/lib64/python2.6/site-packages --disable-libunwind-exceptions --enable-__cxa_atexit --enable-libssp --with-gnu-ld --verbose --disable-multilib --target=x86_64-slackware-linux --build=x86_64-slackware-linux --host=x86_64-slackware-linux
Thread model: posix
gcc version 4.4.3 (GCC)
configure:3138: $? = 0
configure:3145: gcc -V >&5
gcc: '-V' option must have argument
configure:3149: $? = 1
configure:3172: checking for C compiler default output file name
configure:3194: gcc -march=native -O2 -pipe Wl,-O1 -Wl,--as-needed conftest.c >&5
gcc: Wl,-O1: No such file or directory
configure:3198: $? = 1
configure:3236: result:
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "GConf"
| #define PACKAGE_TARNAME "GConf"
| #define PACKAGE_VERSION "2.26.0"
| #define PACKAGE_STRING "GConf 2.26.0"
| #define PACKAGE_BUGREPORT "http://bugzilla.gnome.org/enter_bug.cgi?product=GConf"
| #define PACKAGE "GConf"
| #define VERSION "2.26.0"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:3242: error: in `/home/luca/GConf/GConf-2.26.0':
configure:3245: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=set
ac_cv_env_CFLAGS_value='-march=native -O2 -pipe'
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=set
ac_cv_env_CXXFLAGS_value='-march=native -O2 -pipe'
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_DEFAULTS_CFLAGS_set=
ac_cv_env_DEFAULTS_CFLAGS_value=
ac_cv_env_DEFAULTS_LIBS_set=
ac_cv_env_DEFAULTS_LIBS_value=
ac_cv_env_DEPENDENT_CFLAGS_set=
ac_cv_env_DEPENDENT_CFLAGS_value=
ac_cv_env_DEPENDENT_LIBS_set=
ac_cv_env_DEPENDENT_LIBS_value=
ac_cv_env_DEPENDENT_WITH_GTK_CFLAGS_set=
ac_cv_env_DEPENDENT_WITH_GTK_CFLAGS_value=
ac_cv_env_DEPENDENT_WITH_GTK_LIBS_set=
ac_cv_env_DEPENDENT_WITH_GTK_LIBS_value=
ac_cv_env_DEPENDENT_WITH_XML_AND_GTK_CFLAGS_set=
ac_cv_env_DEPENDENT_WITH_XML_AND_GTK_CFLAGS_value=
ac_cv_env_DEPENDENT_WITH_XML_AND_GTK_LIBS_set=
ac_cv_env_DEPENDENT_WITH_XML_AND_GTK_LIBS_value=
ac_cv_env_DEPENDENT_WITH_XML_CFLAGS_set=
ac_cv_env_DEPENDENT_WITH_XML_CFLAGS_value=
ac_cv_env_DEPENDENT_WITH_XML_LIBS_set=
ac_cv_env_DEPENDENT_WITH_XML_LIBS_value=
ac_cv_env_LDFLAGS_set=set
ac_cv_env_LDFLAGS_value='Wl,-O1 -Wl,--as-needed'
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_path_install='/bin/ginstall -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
## Output variables. ##
ACLOCAL='${SHELL} /home/luca/GConf/GConf-2.26.0/missing --run aclocal-1.10'
ALL_LINGUAS=''
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /home/luca/GConf/GConf-2.26.0/missing --run tar'
AR=''
AS=''
AUTOCONF='${SHELL} /home/luca/GConf/GConf-2.26.0/missing --run autoconf'
AUTOHEADER='${SHELL} /home/luca/GConf/GConf-2.26.0/missing --run autoheader'
AUTOMAKE='${SHELL} /home/luca/GConf/GConf-2.26.0/missing --run automake-1.10'
AWK='gawk'
CATALOGS=''
CATOBJEXT=''
CC='gcc'
CCDEPMODE=''
CFLAGS='-march=native -O2 -pipe'
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS='-march=native -O2 -pipe'
CYGPATH_W='echo'
DATADIRNAME=''
DEFAULTS_CFLAGS=''
DEFAULTS_LIBS=''
DEFS=''
DEPDIR=''
DEPENDENT_CFLAGS=''
DEPENDENT_LIBS=''
DEPENDENT_WITH_GTK_CFLAGS=''
DEPENDENT_WITH_GTK_LIBS=''
DEPENDENT_WITH_XML_AND_GTK_CFLAGS=''
DEPENDENT_WITH_XML_AND_GTK_LIBS=''
DEPENDENT_WITH_XML_CFLAGS=''
DEPENDENT_WITH_XML_LIBS=''
DLLTOOL=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ENABLE_DEFAULTS_SERVICE_FALSE=''
ENABLE_DEFAULTS_SERVICE_TRUE=''
ENABLE_GTK_DOC_FALSE=''
ENABLE_GTK_DOC_TRUE=''
EXEEXT=''
FGREP=''
GCONF_AGE=''
GCONF_CURRENT=''
GCONF_REVISION=''
GETTEXT_PACKAGE=''
GLIB_GENMARSHAL=''
GMOFILES=''
GMSGFMT=''
GREP=''
GTKDOC_CHECK=''
GTK_DOC_USE_LIBTOOL_FALSE=''
GTK_DOC_USE_LIBTOOL_TRUE=''
GTK_FALSE=''
GTK_TRUE=''
HTML_DIR=''
INDENT=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
INSTOBJEXT=''
INTLLIBS=''
INTLTOOL_CAVES_RULE=''
INTLTOOL_DESKTOP_RULE=''
INTLTOOL_DIRECTORY_RULE=''
INTLTOOL_EXTRACT=''
INTLTOOL_KBD_RULE=''
INTLTOOL_KEYS_RULE=''
INTLTOOL_MERGE=''
INTLTOOL_OAF_RULE=''
INTLTOOL_PERL=''
INTLTOOL_POLICY_RULE=''
INTLTOOL_PONG_RULE=''
INTLTOOL_PROP_RULE=''
INTLTOOL_SCHEMAS_RULE=''
INTLTOOL_SERVER_RULE=''
INTLTOOL_SERVICE_RULE=''
INTLTOOL_SHEET_RULE=''
INTLTOOL_SOUNDLIST_RULE=''
INTLTOOL_THEME_RULE=''
INTLTOOL_UI_RULE=''
INTLTOOL_UPDATE=''
INTLTOOL_XAM_RULE=''
INTLTOOL_XML_NOMERGE_RULE=''
INTLTOOL_XML_RULE=''
LD=''
LDAP_CFLAGS=''
LDAP_LIBS=''
LDAP_SUPPORT_FALSE=''
LDAP_SUPPORT_TRUE=''
LDFLAGS='Wl,-O1 -Wl,--as-needed'
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIPO=''
LN_S=''
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAJOR_VERSION=''
MAKEINFO='${SHELL} /home/luca/GConf/GConf-2.26.0/missing --run makeinfo'
MKDIR_P='/bin/mkdir -p'
MKINSTALLDIRS=''
MSGFMT=''
MSGFMT_OPTS=''
MSGMERGE=''
NM=''
NMEDIT=''
OBJDUMP=''
OBJEXT=''
ORBIT_IDL=''
OS_WIN32_FALSE=''
OS_WIN32_TRUE='#'
OTOOL64=''
OTOOL=''
PACKAGE='GConf'
PACKAGE_BUGREPORT='http://bugzilla.gnome.org/enter_bug.cgi?product=GConf'
PACKAGE_NAME='GConf'
PACKAGE_STRING='GConf 2.26.0'
PACKAGE_TARNAME='GConf'
PACKAGE_VERSION='2.26.0'
PATH_SEPARATOR=':'
PERL=''
PKG_CONFIG=''
POFILES=''
POLKIT_POLICY_FILE_VALIDATE=''
POSUB=''
PO_IN_DATADIR_FALSE=''
PO_IN_DATADIR_TRUE=''
PTHREADS_FALSE=''
PTHREADS_TRUE=''
RANLIB=''
REBUILD=''
SED=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
USE_NLS=''
VERSION='2.26.0'
XGETTEXT=''
absolute_top_srcdir=''
ac_ct_CC='gcc'
ac_ct_CXX=''
ac_ct_DUMPBIN=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include=''
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='$(SHELL) /home/luca/GConf/GConf-2.26.0/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
lt_ECHO='echo'
mandir='${datarootdir}/man'
mkdir_p='/bin/mkdir -p'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
sysconfsubdir=''
sysgconfdir=''
target_alias=''
## confdefs.h. ##
configure: exit 77
Vi posto anche il /etc/profile, non sò potrebbe essere d'aiuto per voi per aiutare me
# /etc/profile: This file contains system-wide defaults used by
# all Bourne (and related) shells.
# Set the values for some environment variables:
export MINICOM="-c on"
export MANPATH=/usr/local/man:/usr/man
export HOSTNAME="`cat /etc/HOSTNAME`"
export LESSOPEN="|lesspipe.sh %s"
export LESS="-M"
#export CFLAGS="-march=native -O2 -pipe"
#export CXXFLAGS="${CFLAGS}"
# If the user doesn't have a .inputrc, use the one in /etc.
if [ ! -r "$HOME/.inputrc" ]; then
export INPUTRC=/etc/inputrc
fi
# Set the default system $PATH:
PATH="/usr/local/bin:/usr/bin:/bin:/usr/games"
# For root users, ensure that /usr/local/sbin, /usr/sbin, and /sbin are in
# the $PATH. Some means of connection don't add these by default (sshd comes
# to mind).
if [ "`id -u`" = "0" ]; then
echo $PATH | grep /usr/local/sbin 1> /dev/null 2> /dev/null
if [ ! $? = 0 ]; then
PATH=/usr/local/sbin:/usr/sbin:/sbin:$PATH
fi
fi
# I had problems with the backspace key using 'eval tset' instead of 'TERM=',
# but you might want to try it anyway instead of the section below it. I
# think with the right /etc/termcap it would work.
# eval `tset -sQ "$TERM"`
# Set TERM to linux for unknown type or unset variable:
if [ "$TERM" = "" -o "$TERM" = "unknown" ]; then
TERM=linux
fi
# Set ksh93 visual editing mode:
if [ "$SHELL" = "/bin/ksh" ]; then
VISUAL=emacs
# VISUAL=gmacs
# VISUAL=vi
fi
# Set a default shell prompt:
#PS1='`hostname`:`pwd`# '
if [ "$SHELL" = "/bin/pdksh" ]; then
PS1='! $ '
elif [ "$SHELL" = "/bin/ksh" ]; then
PS1='! ${PWD/#$HOME/~}$ '
elif [ "$SHELL" = "/bin/zsh" ]; then
PS1='%n@%m:%~%# '
elif [ "$SHELL" = "/bin/ash" ]; then
PS1='$ '
else
PS1='\u@\h:\w\$ '
fi
PS2='> '
export PATH DISPLAY LESS TERM PS1 PS2
# Default umask. A umask of 022 prevents new files from being created group
# and world writable.
umask 022
# Notify user of incoming mail. This can be overridden in the user's
# local startup file (~/.bash.login or whatever, depending on the shell)
if [ -x /usr/bin/biff ]; then
biff y 2> /dev/null
fi
# Append any additional sh scripts found in /etc/profile.d/:
for profile_script in /etc/profile.d/*.sh ; do
if [ -x $profile_script ]; then
. $profile_script
fi
done
unset profile_script
# For non-root users, add the current directory to the search path:
if [ ! "`id -u`" = "0" ]; then
PATH="$PATH:."
fi
