DVD con mplayer
daniele50
Nome Cognome: Daniele Cinquanta
Slackware: Slackware64 14.1
Kernel: 3.10.17
Desktop: Xfce 4.10
DVD con mplayer
Messaggio da daniele50 »
Ciao,
sul mio pc se inserisco un dvd nel lettore e da shell do mplayer dvd://1 parte il primo capito del dvd e la she mi restituisce
daniele50@slacky:~$ mplayer dvd://1
MPlayer r29789-4.3.3 (C) 2000-2009 MPlayer Team
Playing dvd://1.
libdvdread: Using libdvdcss version 1.2.10 for DVD access
There are 9 titles on this DVD.
There are 1 angles in this DVD title.
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000013a
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00000690
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x000007a1
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x001fb158
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x001fb191
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x001fb346
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x001fb383
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x002127be
libdvdread: Found 4 VTS's
audio stream: 0 format: ac3 (5.1) language: it aid: 128.
audio stream: 1 format: ac3 (mono) language: it aid: 129.
audio stream: 2 format: ac3 (mono) language: en aid: 130.
number of audio channels on disk: 3.
subtitle ( sid ): 0 language: it
subtitle ( sid ): 1 language: en
number of subtitles on disk: 2
MPEG-PS file format detected.
VIDEO:  MPEG2  720x576  (aspect 2)  25.000 fps  9100.0 kbps (1137.5 kbyte/s)
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
Try appending the scale filter to your filter list,
e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed :(
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Unsupported PixelFormat -1
Selected video codec: [ffmpeg2] vfm: ffmpeg (FFmpeg MPEG-2)
Opening audio decoder: [liba52] AC3 decoding with liba52
Using SSE optimized IMDCT transform
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
AO: [oss] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO: [xv] 720x576 => 768x576 Planar YV12
[mpeg2video @ 0x89877a0]ac-tex damaged at 39 2
[mpeg2video @ 0x89877a0]Warning MVs not available
[mpeg2video @ 0x89877a0]concealing 1530 DC, 1530 AC, 1530 MV errors
No bind found for key 'c'.                         %  0%  0.7% 3 0
A:   9.0 V:   9.0 A-V:  0.005 ct:  0.094 227/227  8%  0%  0.7% 3 0
MPlayer interrupted by signal 2 in module: sleep_timer
A:   9.1 V:   9.1 A-V:  0.005 ct:  0.094 228/228  8%  0%  0.7% 3 0
Exiting... (Quit)
Exiting è uscito quando ho dato ctrl+c per fermare.
Se faccio la stessa cosa con il pc di mio fratello (current come il mio) il risultato è:
andrea@andrea:~$ mplayer dvd://1
Playing dvd://1.
libdvdread: Invalid title IFO (VTS_01_0.IFO).
Cannot open the IFO file for DVD title 1.
No stream find to handle url DVD://1
Exiting... (End of file)
Se provo a copiare il contenuto del dvd su hd ci mette circo 18 minuti però non sembra dare problemi (sono arrivato al 25%), quindi il dvd dovrebbe leggerlo correttamente.
Qualcuno ha idea di cosa possa essere?
algol
Slackware: 12.1
Kernel: 2.6.26.1
Desktop: xfce4.4.2
Re: DVD con mplayer
Messaggio da algol »
Con un altro player (smplayer, totem...) va tutto bene?
Kristos
Kernel: 2.6.37.6-smp
Distribuzione: PCLinuxOS
Re: DVD con mplayer
Messaggio da Kristos »
Aggiungerei anche VLC, se non funziona con questo allora c'è qualcosa sicuramente che deve essere sistemato.
daniele50
Kernel: 3.10.17
Desktop: Xfce 4.10
Re: DVD con mplayer
Avevo provato anche con altri player senza buoni risultati, ma questo prima dell'aggiornamento a current, quindi questa sera riprovo anche con VLC e vi faccio sapere cosa succede... graize per l'aiuto!
414N
Kernel: 5.15.19
Re: DVD con mplayer
Messaggio da 414N »
Prova con questo comando:
mplayer -nocache dvdnav://
daniele50
Kernel: 3.10.17
Desktop: Xfce 4.10
Re: DVD con mplayer
Ecco cosa mi dice mplayer -nocache dvdnav://
andrea@andrea:~$ mplayer -nocache dvdnav://
Playing dvdnav://.
libdvdnav: Using dvdnav version MPlayer-custom
libdvdnav: DVD Title: Asterix e le 12 fatiche
libdvdnav: DVD Serial Number: bf07ece6
libdvdnav: DVD Title (Alternative): Asterix e le 12 fatiche
libdvdnav: Unable to find map file '/home/andrea/.dvdnav/Asterix e le 12 fatiche.map'
libdvdnav: DVD disk reports itself with Region mask 0x00fd0000. Regions: 2
libdvdread: Elapsed time 72
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_02_0.VOB (0x001fb158)
libdvdread: Elapsed time 1
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_02_1.VOB (0x001fb191)!!
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_03_1.VOB (0x001fb383)!!
libdvdread: Elapsed time 42
libdvdread: Elapsed time 115
libdvdnav: *** pgci_ut handle is NULL ***
libdvdnav: Language 'en' not found, using 'it' instead
libdvdnav: Menu Languages available: it
Remember to disable MPlayer's cache when playing dvdnav:// streams (adding -nocache to your command line)
DVDNAV, switched to title: 4
VIDEO:  MPEG2  720x576  (aspect 2)  25.000 fps  9000.0 kbps (1125.0 kbyte/s)
AUDIO: 48000 Hz, 2 ch, s16le, 224.0 kbit/14.58% (ratio: 28000->192000)
[mpeg2video @ 0x89877a0]ac-tex damaged at 42 1
[mpeg2video @ 0x89877a0]concealing 1575 DC, 1575 AC, 1575 MV errors
libdvdnav: Error when seeking ct:  0.050   2/  2 23%  2%  0.6% 10 0
libdvdnav: Error when seeking ct:  0.131   1/  1 25%  2%  0.6% 0 0
libdvdnav: Error when seeking ct:  0.121   1/  1 22%  2%  0.7% 0 0
dvdnav_stream, seeking to 2002944 failed: Request to seek behind end.
libdvdnav: Error when seeking ct:  0.052   1/  1 21%  2%  0.6% 0 0
A:   0.0 V:   2.4 A-V: -2.400 ct: -0.236   1/  1 20%  1%  0.0% 0 0
andrea@andrea:~$
Praticamente dopo un po' mi appare la schermata iniziale con 'inizio film', 'seleziona scene', ecc. ma né con il mouse né da tastiera riesco a selezionare 'inizia film'.
Comunque un po' di errori ci sono, se qualcuno riesce ad interpretarli...
Nel frattempo provo ad installare vlc...
daniele50
Kernel: 3.10.17
Desktop: Xfce 4.10
Re: DVD con mplayer
VLC mi fa partire il filmato, però le immagini vanno un po' scatti...
Se lo faccio partire da shell anche lui mi da gli stessi errori di mplayer:
idee?
Kristos
Re: DVD con mplayer
daniele50 ha scritto:VLC mi fa partire il filmato, però le immagini vanno un po' scatti...
Ma lo fà solo con quel dvd questo saltellamento delle immagini oppure lo fà con tutti quelli che fai girare?
C'è questo errore che non capisco:
Sembra che vada in conflitto con qualcosa, inoltre lo scattare delle immagini potrebbe essere dovuto alla scheda video non ben configurata, magari il RenderAccel che non è proprio ben definito in xorg.conf. (butto lì le mie impressioni leggendo output degli errori e la tua descrizione).
daniele50
Kernel: 3.10.17
Desktop: Xfce 4.10
Re: DVD con mplayer
La scheda video è una NVIDIA 8400, quindi l'ho configurata installando i driver nvidia 190.xx.
Altre modifiche non ne ho fatte (come faccio quando ho un scheda nvidia).
Questa sera provo con altyri dvd...
daniele50
Kernel: 3.10.17
Desktop: Xfce 4.10
Re: DVD con mplayer
Ho provato un altro DVD con VLC e non da errori!
Strano, perché il primo DVD (quello che da errori sul computer di mio fratello) sul mio computer non da errori, quindi pensavo che non fosse il supporto.
Probabilmente il leddote DVD del computer di mio fratello non è il massimo...
Comunque anche sul secondo DVD il filmato va leggermente a scatti:
la CPU rimane intorno al 40/50%, swap non ne fa e con free vedo che su 1gb di ram ne usa 600mb.
Probabilmente la scheda video (che se non erro è una nvidia 8400 512mb) non ce la fa...
