Qmmp OutputALSA: buffer underrun!
gohanz
Messaggio da gohanz »
Usando Qmmp ho notato nelle ultime versioni un problema con la riproduzione del sonoro. In pratica la riproduzione funziona a singhiozzo. La shell mi riporta un OutputALSA: buffer underrun! Mi confermate il problema?
qmmp
Output: plugin loaded - libalsa.so
Output: plugin loaded - libnull.so
Output: plugin loaded - liboss.so
OutputALSA: setupMixer()
OutputALSA: setupMixer() success
General: plugin loaded - libcovermanager.so
General: plugin loaded - libfileops.so
General: plugin loaded - libhal.so
General: plugin loaded - libhotkey.so
General: plugin loaded - libkdenotify.so
General: plugin loaded - liblyrics.so
General: plugin loaded - libmpris.so
General: plugin loaded - libnotifier.so
General: plugin loaded - libscrobbler.so
General: plugin loaded - libstatusicon.so
HalPlugin: device "/org/freedesktop/Hal/devices/volume_uuid_B7A0_3123" added (removable)
HalPlugin: device "/org/freedesktop/Hal/devices/volume_uuid_4813_69D2" added (removable)
HalPlugin: device "/org/freedesktop/Hal/devices/volume_part1_size_10215424" added (removable)
Skin: using :/default
Skin: cannot find region.txt. Transparency disabled
Visual: plugin loaded - libanalyzer.so
Visual: plugin loaded - libprojectm.so
Decoder: plugin loaded - libaac.so
Decoder: plugin loaded - libcdaudio.so
Decoder: plugin loaded - libcue.so
Decoder: plugin loaded - libffmpeg.so
Decoder: plugin loaded - libflac.so
Decoder: plugin loaded - libmad.so
Decoder: plugin loaded - libmodplug.so
Decoder: plugin loaded - libmpc.so
Decoder: plugin loaded - libsndfile.so
Decoder: plugin loaded - libvorbis.so
Decoder: plugin loaded - libwavpack.so
AbstractEngine: plugin loaded - libmplayer.so
InputSource: plugin loaded - libhttp.so
InputSource: plugin loaded - libmms.so
InputSource: using file transport
StateHandler: Current state: Buffering; previous state: Stopped
Effect: plugin loaded - libbs2b.so
Effect: plugin loaded - libladspa.so
Effect: plugin loaded - libsrconverter.so
ReplayGain: disabled
QmmpAudioEngine: selected decoder: mad
DecoderMAD: Fixed rate detected
DecoderMAD: Total time: 292580
OutputALSA: can pause: 0
Output: 48000 Hz, 2 ch, s16le
StateHandler: Current state: Playing; previous state: Buffering
DecoderMAD: 4598 bytes skipped
===== metadata ======
ARTIST = Deep Purple
TITLE = Call Of The Wild
ALBUM = Shades 1968-1998 Disc 4
COMMENT =
GENRE = Other
YEAR = 1999
TRACK = 1
== end of metadata ==
StateHandler: Current state: Stopped; previous state: Playing
DecoderMAD: deleting input_buf
OutputALSA: closing pcm_handle
Visual::~Visual()
Re: Qmmp OutputALSA: buffer underrun!
qmmp 0.4.0 compilato da poco su -current non mi da problemi
gohanz
Grazie Conraid, un sospetto che il problema sia il mio computer c'e'. Forse Qmmp richiede un pc piu' potente del mio. Ora il fatto che tu sia sulla current mi lascia un minimo di dubbio. Mi piacerebbe un riscontro da parte di qualcuno che usi la 13.0 base. Tra l'altro sto ripacchettizando Qmmp con la nuova versione.
