Slackware 32&64 in un singolo DVD
EDIT: ho ripreso il progetto in mano ed ho aggiornato e pubblicato lo script e caricato la iso creata (vedi ultimo post)
slackware-mix-dvd.sh
http://files.z01.eu/iso/
=== originale di maggio 2010 ===
Slackware ci vende il dvd doppia faccia per avere entrami i sistemi a portata di mano.
Noi comuni mortali che i mezzi per costruirci un doppia faccia non ce l'abbiamo, ce possiamo stringere in una sola faccia.
#!/bin/bash
set -e
CWD=$(pwd)
# i path dove si trovano i due rami
X86=$CWD/slack32
X64=$CWD/slack64
WORK=$CWD/workdir
rm -fr $WORK
mkdir -p $WORK
cd $WORK
mkdir -p isolinux kernels/slack32 kernels/slack64
cp $X86/isolinux/initrd.img isolinux/initrd32.img
cp $X86/kernels/hugesmp.s/* kernels/slack32/
cp $X64/isolinux/initrd.img isolinux/initrd64.img
cp $X64/kernels/huge.s/* kernels/slack64/
cp $X86/isolinux/iso.sort isolinux/iso.sort
cp $X86/isolinux/isolinux.bin isolinux/isolinux.bin
ln -s $X86/slackware slackware
ln -s $X64/slackware64 slackware64
cat $X86/isolinux/message.txt |grep -m1 Welcome > isolinux/message.txt
cat >> isolinux/message.txt << EOF
This DVD contain both Slackware 32bit and Slackware 64bit in a single face :-)
You can start Slackware 32bit Installer typing 'slack32' or simply press ENTER
You can start Slackware 64bit Installer typing 'slack64'
If you need to pass extra parameters to the kernel, enter them at the prompt
below after the name of the kernel to boot (slack32 or slack64).
In a pinch, you can boot your system from here with a command like:
boot: slack32 root=/dev/sda1 rdinit= ro
In the example above, /dev/sda1 is the / Linux partition.
EOF
cat > isolinux/isolinux.cfg << EOF
default slack32
prompt 1
timeout 1200
display message.txt
label slack32
  kernel /kernels/slack32/bzImage
  append initrd=initrd32.img load_ramdisk=1 prompt_ramdisk=0 rw SLACK_KERNEL=slack32
label slack64
  kernel /kernels/slack64/bzImage
  append initrd=initrd64.img load_ramdisk=1 prompt_ramdisk=0 rw SLACK_KERNEL=slack64
EOF
mkisofs -f -o $CWD/slackware-mix-dvd.iso \
  -R -J -A "Slackware32_64" \
  -hide-rr-moved \
  -v -d -N \
  -no-emul-boot -boot-load-size 4 -boot-info-table \
  -sort isolinux/iso.sort \
  -b isolinux/isolinux.bin \
  -c isolinux/isolinux.boot \
  -V "SlackDVDmix" .
In pratica inserisco in un dvd solamente i rami dei pacchetti che, gentilmente, il team di slackware ha chiamato separatamente 'slackware' e 'slackware64'
Il tutto viene 3.2G
ci sarà bisogno di avere i rami (stable o current) in due directory diverse, o le due iso montate o i due dvd montati (beh, sempre se avete doppio lettore).
Nella prima sezione dello script andate a modificare X86= e X64= mettendoci relativamente il path del ramo a 32bit e 64bit.
Personalizzate i messaggi a piacere
Lanciate lo script ed eccovi con un dvd dual boot 32/64bit
Ultima modifica di ZeroUno il mar 14 ago 2012, 13:42, modificato 1 volta in totale.
teox99
Desktop: KDE - Xfce
Re: Slackware 32&64 in un singolo DVD
Messaggio da teox99 »
per costruire un dvd double layer no! ma per comprarne uno vergine e masterizzare antrambe i lati spero di si... :D
teox99 ha scritto:per costruire un dvd double layer no! ma per comprarne uno vergine e masterizzare antrambe i lati spero di si... :D
io in commercio non ne ho mai visti
zoros
Nome Cognome: Fabio`Zorba`
Kernel: 5.15.19smp
Desktop: Trinity R14.0.11
Messaggio da zoros »
buona idea la tua, ZeroUno ... ricordo (per perfezionare ulteriormente l'idea) che per installare una 64bit non occorre avviare un kernel a 64bit ... come dimostro con i miei tools :D ...
zoros ha scritto:buona idea la tua, ZeroUno ... ricordo (per perfezionare ulteriormente l'idea) che per installare una 64bit non occorre avviare un kernel a 64bit ... come dimostro con i miei tools :D ...
no. qualche doinst.sh ha dei chroot che chiaramente non funzionano se hai un kernel a 32bit
Comunque se pure il kernel può essere lo stesso non credo che si possa dire altrettanto dell'installer che, suppongo, prenderebbe slackware/ anzichè slackware64/
zoros
Kernel: 5.15.19smp
ma sì ZeroUno, hai ragione,
puoi considerare il mio intervento come un post++ ... c'è a monte qualcosa che non va ... volevo solo dire questo ... ciauz ;)
Vic Steele
Nome Cognome: Luigi Caiazza
Slackware: current x86_64
Kernel: 3.0.0
Desktop: Fluxbox / KDE 4.7.0
Distribuzione: Fedora 15
Messaggio da Vic Steele »
Su certi store online si trovano anche a 90 centesimi (Verbatim!)...
Comunque i dual layer non si masterizzano da entrambi i lati :D , c'è questa "leggenda metropolitana" sentita più volte da sfatare.
Blallo
Nome Cognome: Savino Liguori
Slackware: 14.2 / 12.2
Kernel: 4.4.14-smp
Desktop: DWM
Messaggio da Blallo »
Vic Steele ha scritto:Comunque i dual layer non si masterizzano da entrambi i lati :D , c'è questa "leggenda metropolitana" sentita più volte da sfatare.
ti confondi con i double layer
i dual layer, a meno che non si abbiamo masterizzatori compatibili, si devono girare
Vic Steele
Kernel: 3.0.0
Hai perfettamente ragione.
414N
Kernel: 5.15.19
Messaggio da 414N »
Veramente, dual layer e double layer sono considerati sinonimi di "doppio strato" (faccia singola), non "doppia faccia"(ognuna a singolo strato): http://en.wikipedia.org/wiki/DVD#Dual-layer_recording.
Se non sbaglio, uno è riferito ai DVD-R e l'altro ai DVD+R.
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
ehm...http://recensioni.ebay.it/Differenza-tr ... 0006763202
termine OT
Beh, volendo dovrebbero esistere anche i doppio strato&doppia faccia, per un tot di 17G
Ma tralasciando tutta la parte dei formati e cosa esiste e cosa non esiste e come si chiamano (e quanto costano),
l'utilità di avere le due slackware su una sola faccia è che puoi prendere un pennarello e scriverci "SLACKWARE" a caratteri cubitali. Sui doppia faccia ti devi accontentare del paio di centimetri quadrati al centro del dvd.
zoros
Kernel: 5.15.19smp
ZeroUno ha scritto:...
no. qualche doinst.sh ha dei chroot che chiaramente non funzionano se hai un kernel a 32bit ...
... come scritto in precedenza il mio era un post++ più che altro per rimarcare che a livello struttura filesystem/pacchetti nulla cambia tra 32bit e 64bit ... si può leggere/scrivere/riparare una installazione a 64bit anche a da una 32 ... chiaramente il chroot non si può fare ... qualcuno sa dire quali sono i txz/tgz che prevedono l'esecuzione di un chroot al loro interno? (scusate l'OT :) ) ...
zoros ha scritto:qualcuno sa dire quali sono i txz/tgz che prevedono l'esecuzione di un chroot al loro interno? (scusate l'OT :) ) ...
grep chroot /var/log/scripts/*
zoros
Kernel: 5.15.19smp
thanks ZeroUno, semplice semplice ... non ci avevo pensato #-o ...
be, in effetti non sono molti i pacchetti ... comunque, nel caso di prima installazione, sono tutti settaggi che si potrebbero fare al riavvio del sistema, almeno così sembra ... ma era solo una curiosità tecnica ... diciamo che si può fare (installare da 32 una 64) a patto di completare alcuni settaggi al primo riavvio ...
