tra i requisiti dell'ultima versione di gnumeric c'era goffice-0.8.5 e così ho scaricato goffice-0.8.5, mi sono creato il pacchetto e l'ho installato. Quando però adesso provo a compilare gnumeric ./configure mi da quest'errore:
checking for LIBSPREADSHEET... configure: error: Package requirements (
libgoffice-0.8 >= 0.8.5
libgsf-1 >= 1.14.15
libxml-2.0 >= 2.4.12
libglade-2.0 >= 2.3.6
gtk+-2.0 >= 2.12.0
) were not met:
No package 'libgoffice-0.8' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables LIBSPREADSHEET_CFLAGS
and LIBSPREADSHEET_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.Codice: Seleziona tutto
/usr/local/lib/libgoffice-0.8.so.8.0.5
/usr/local/lib/pkgconfig/libgoffice-0.8.pc
/usr/local/lib/libgoffice-0.8.la
/usr/local/include/libgoffice-0.8
/usr/local/include/libgoffice-0.8/goffice
/usr/local/include/libgoffice-0.8/goffice/app
/usr/local/include/libgoffice-0.8/goffice/app/go-doc-control.h
/usr/local/include/libgoffice-0.8/goffice/app/module-plugin-defs.h
/usr/local/include/libgoffice-0.8/goffice/app/go-plugin-service-impl.h
/usr/local/include/libgoffice-0.8/goffice/app/io-context-priv.h
/usr/local/include/libgoffice-0.8/goffice/app/go-conf.h
/usr/local/include/libgoffice-0.8/goffice/app/go-plugin-loader.h
/usr/local/include/libgoffice-0.8/goffice/app/go-cmd-context.h
/usr/local/include/libgoffice-0.8/goffice/app/go-doc.h
/usr/local/include/libgoffice-0.8/goffice/app/go-doc-control-impl.h
/usr/local/include/libgoffice-0.8/goffice/app/goffice-app.h
/usr/local/include/libgoffice-0.8/goffice/app/error-info.h
/usr/local/include/libgoffice-0.8/goffice/app/go-plugin-service.h
/usr/local/include/libgoffice-0.8/goffice/app/go-plugin-loader-module.h
/usr/local/include/libgoffice-0.8/goffice/app/go-plugin.h
/usr/local/include/libgoffice-0.8/goffice/app/file.h
/usr/local/include/libgoffice-0.8/goffice/app/go-cmd-context-impl.h
/usr/local/include/libgoffice-0.8/goffice/app/io-context.h
/usr/local/include/libgoffice-0.8/goffice/app/go-doc-impl.h
/usr/local/include/libgoffice-0.8/goffice/utils
/usr/local/include/libgoffice-0.8/goffice/utils/go-style.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-glib-extras.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-libxml-extras.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-gradient.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-geometry.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-path.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-cairo.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-styled-object.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-locale.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-units.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-pattern.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-persist.h
/usr/local/include/libgoffice-0.8/goffice/utils/goffice-utils.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-image.h
/usr/local/include/libgoffice-0.8/goffice/utils/regutf8.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-editor.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-file.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-color.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-marker.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-string.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-undo.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-font.h
/usr/local/include/libgoffice-0.8/goffice/utils/datetime.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-bezier.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-line.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-format.h
/usr/local/include/libgoffice-0.8/goffice/utils/go-pango-extras.h
/usr/local/include/libgoffice-0.8/goffice/canvas
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-group.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-path.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-ellipse.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-rectangle.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-line.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-pixbuf.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-styled-item.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-polygon.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-widget.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-circle.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-canvas.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goffice-canvas.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-graph.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-structs.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-polyline.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-arc.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-item.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-text.h
/usr/local/include/libgoffice-0.8/goffice/canvas/goc-utils.h
/usr/local/include/libgoffice-0.8/goffice/data
/usr/local/include/libgoffice-0.8/goffice/data/go-data-impl.h
/usr/local/include/libgoffice-0.8/goffice/data/go-data.h
/usr/local/include/libgoffice-0.8/goffice/data/goffice-data.h
/usr/local/include/libgoffice-0.8/goffice/data/go-data-simple.h
/usr/local/include/libgoffice-0.8/goffice/graph
/usr/local/include/libgoffice-0.8/goffice/graph/gog-axis.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-axis-line-impl.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-series.h
/usr/local/include/libgoffice-0.8/goffice/graph/goffice-graph.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-view.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-trend-line.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-data-set.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-plot-engine.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-chart-impl.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-chart.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-graph-impl.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-plot-impl.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-grid.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-guru.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-chart-map.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-series-lines.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-object.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-graph.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-data-allocator.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-chart-map-3d.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-axis-line.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-outlined-object.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-reg-curve.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-label.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-error-bar.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-theme.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-legend.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-smoothed-curve.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-3d-box.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-series-impl.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-plot.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-object-xml.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-child-button.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-renderer.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-grid-line.h
/usr/local/include/libgoffice-0.8/goffice/graph/gog-styled-object.h
/usr/local/include/libgoffice-0.8/goffice/goffice-features.h
/usr/local/include/libgoffice-0.8/goffice/component
/usr/local/include/libgoffice-0.8/goffice/component/go-component-factory.h
/usr/local/include/libgoffice-0.8/goffice/component/goffice-component.h
/usr/local/include/libgoffice-0.8/goffice/component/go-component.h
/usr/local/include/libgoffice-0.8/goffice/math
/usr/local/include/libgoffice-0.8/goffice/math/go-quad.h
/usr/local/include/libgoffice-0.8/goffice/math/go-distribution.h
/usr/local/include/libgoffice-0.8/goffice/math/go-math.h
/usr/local/include/libgoffice-0.8/goffice/math/go-cspline.h
/usr/local/include/libgoffice-0.8/goffice/math/goffice-math.h
/usr/local/include/libgoffice-0.8/goffice/math/go-matrix3x3.h
/usr/local/include/libgoffice-0.8/goffice/math/go-complex.h
/usr/local/include/libgoffice-0.8/goffice/math/go-R.h
/usr/local/include/libgoffice-0.8/goffice/math/go-fft.h
/usr/local/include/libgoffice-0.8/goffice/math/go-regression.h
/usr/local/include/libgoffice-0.8/goffice/math/go-rangefunc.h
/usr/local/include/libgoffice-0.8/goffice/goffice.h
/usr/local/include/libgoffice-0.8/goffice/drawing
/usr/local/include/libgoffice-0.8/goffice/drawing/god-paragraph-attributes.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-image-store.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-shape.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-drawing.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-text-model.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-drawing-view.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-property-table.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-drawing-renderer-gdk.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-anchor.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-image.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-drawing-group.h
/usr/local/include/libgoffice-0.8/goffice/drawing/god-default-attributes.h
/usr/local/include/libgoffice-0.8/goffice/gtk
/usr/local/include/libgoffice-0.8/goffice/gtk/go-combo-color.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-line-selector.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-pixbuf.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-color-selector.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-combo-box.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-combo-pixmaps.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-charmap-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-font-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-calendar-button.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-rotation-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-action-combo-color.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-selector.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-color-palette.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-color-group.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-3d-rotation-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-action-combo-stack.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-locale-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-gradient-selector.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-pattern-selector.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-action-combo-pixmaps.h
/usr/local/include/libgoffice-0.8/goffice/gtk/goffice-gtk.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-action-combo-text.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-image-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-format-sel.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-marker-selector.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-palette.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-graph-widget.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-combo-text.h
/usr/local/include/libgoffice-0.8/goffice/gtk/go-optionmenu.h
/usr/local/include/libgoffice-0.8/goffice/ms-compat
/usr/local/include/libgoffice-0.8/goffice/ms-compat/god-drawing-ms-client-handler.h
/usr/local/include/libgoffice-0.8/goffice/ms-compat/god-drawing-ms.h
/usr/local/include/libgoffice-0.8/goffice/ms-compat/go-ms-parser.h
/usr/local/include/libgoffice-0.8/goffice/ms-compat/god-image-ms.h
Ho fatto delle prove dopo aver letto la man di pkg-config ma non ci sono riuscito...
CIao
