ATI Catalyst 10.9 su Slackware 13.1 64bit
alphamanitine
Slackware: 14
Messaggio da alphamanitine »
Ho provato la creazione dei pacchetti ma non va a buon fine:
Generating package: Slackware/All
ATI SlackBuild Version 1.4.1
by: Emanuele Tomasi <tomasiATcli.di.unipi.it>
    Ezio Ghibaudo <ekxiusATgmail.com>
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o *.ko *.GCC* .??* *.symvers
make -C /lib/modules/2.6.33.4/build SUBDIRS=/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/linux-2.6.33.4'
  CC [M]  /tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function 'KCL_MapPageToPfn':
/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1636: warning: unused variable 'bus_addr'
  CC [M]  /tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
  CC [M]  /tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
  CC [M]  /tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
  CC [M]  /tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c: In function 'KCL_IOCTL_AllocUserSpace32':
/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c:196: error: implicit declaration of function 'compat_alloc_user_space'
/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.c:196: warning: return makes pointer from integer without a cast
make[2]: *** [/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o] Error 1
make[1]: *** [_module_/tmp/fglrx-install.Abj3ft/common/lib/modules/fglrx/build_mod/2.6.x] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.33.4'
make: *** [kmod_build] Error 2
build failed with return value 2
ERROR: i don't have make module
Removing temporary directory: fglrx-install.Abj3ft
Suggerimenti?
Re: ATI Catalyst 10.9 su Slackware 13.1 64bit
Ciao, ho trovato qualcosa che forse può aiutarti. Scarica la patch allegata nella directory /tmp, quindi, da root:
#> mkdir -p /etc/ati/patch/
#> mv /tmp/fglrx_10.9.diff /etc/ati/patch/patch-8.771-$(uname -r)
#> sh ati-driver-installer-10-9-x86.x86_64.run --buildpkg
Per un problema nello SlackBuild interno (che vedo di risolvere per le prossime release), ad un certo punto ti viene chiesto:
can't find file to patch at input line 4
Perhaps you should have used the -p or --strip option?
The text leading up to this was:
|diff -ru ./2.6.x/Makefile ../../../../../../fglrx-install.uZLF8t/common/lib/modules/fglrx/build_mod//2.6.x/Makefile
|--- ./2.6.x/Makefile   2010-09-01 16:05:31.000000000 +0200
|+++ ../../../../../../fglrx-install.uZLF8t/common/lib/modules/fglrx/build_mod//2.6.x/Makefile  2010-09-23 08:47:24.000000000 +0200
File to patch:
e tu mettici:
./2.6.x/Makefile
Dovrebbe essere tutto. Se tutto va bene dopo puoi anche eliminare la directory patch, con:
rm -r /etc/ati/patch/
Fammi sapere,
fglrx_10.9.diff
Patch per i driver ATI Catalist 10.9 (errore su 'compat_alloc_user_space')
(2.9 KiB) Scaricato 407 volte
Linux Registered User #454438
20/04/2013 - Io volevo Rodotà
Amrod
Slackware: x86_64 current
Messaggio da Amrod »
Non so se puo' servire a trovare il problema ma sulla 64 -current mi compilano senza problemi e
li sto usando
Il problema non è la versione della Slackware, ma quella del Kernel. Io ho una current e neanche a me compilano, con la patch si. Il problema è stato già trovato, bisogna solo vedere se la patch funziona :).
Comunque grazie per il feedback. Anzi puoi dirmi che kernel usi? Mi sembra che l'errore sia iniziato dal 2.6.32-22 (o 23).
Amrod
Uso il 2.6.33.4, ho la memoria corta ma almeno negli ultimi 2 o 3 mesi non ho mai dovuto patchare i driver
per compilarli, che dipenda da altro oltre che dal kernel?
No no, forse sono io che sbaglio. L'errore avviene perchè negli ultimi kernel hanno cambiato il nome della funzione, succede sempre così quando i moduli non sono integrati nel ramo di sviluppo del kernel.
alphamanitine
Slackware: 14
Ciao spina. La patch funziona!
fglrxinfo
display: :0.0  screen: 0
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: ATI Radeon HD 4800 Series
OpenGL version string: 3.3.10188 Compatibility Profile Context
Catalyst Control Center non si avvia come utente generico:
bash: /usr/bin/amdcccle: Permission denied
Uso XFCE come DE.
Spesso mi dicono di problemi di permessi. Io generalmente non tocco nulla e lascio che siano quelli della ATI a settare i permessi per i file, però effettivamente ad un comando che è sotto /usr/bin l'utente normale dovrebbe potervi accedere.
Vedo quello che si può fare per una prossima release dei driver, per ora devi settare a mano i permessi :(.
Contento che la patch funzioni,
Ho settato tutti i permessi della directory /usr/bin a (0755). Se avete buona memoria, alla prossima release dei driver fatemi sapere se funziona.
414N
Kernel: 4.4.19
Desktop: KDE4
Messaggio da 414N »
La patch funziona perfettamente anche a me. Grazie spina :thumbright:
