oot@pino:~# lilo
Warning: /etc/lilo.conf should be writable only for root
Warning: LBA32 addressing assumed
Warning: boot record relocation beyond BPB is necessary: /dev/fd0
Warning: The boot sector and map file are on different disks.
Fatal: bmp-timer: value out of range [1,76]
Questo è lilo.conf del caso
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
# Append any additional kernel parameters:
append=" vt.default_utf8=0"
boot = /dev/fd0
# Boot BMP Image.
# Bitmap in BMP format: 640x480x8
bitmap = /boot/slack.bmp
# Menu colors (foreground, background, shadow, highlighted
# foreground, highlighted background, highlighted shadow):
bmp-colors = 255,0,255,0,255,0
# Location of the option table: location x, location y, number of
# columns, lines per column (max 15), "spill" (this is how many
# entries must be in the first column before the next begins to
# be used. We don't specify it here, as there's just one column.
bmp-table = 60,6,1,16
# Timer location x, timer location y, foreground color,
# background color, shadow color.
bmp-timer = 300
# Standard menu.
# Or, you can comment out the bitmap menu above and
# use a boot message with the standard menu:
#message = /boot/boot_message.txt
# Wait until the timeout to boot (if commented out, boot the
# first entry immediately):
prompt
# Timeout before the first entry boots.
# This is given in tenths of a second, so 600 for every minute:
timeout = 1200
# Override dangerous defaults that rewrite the partition table:
change-rules
reset
vga = 773
# Normal VGA console
# vga = normal
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# End LILO global section
image = /boot/vmlinuz
root = /dev/sda6
label = slackware12.1
read-only
# Windows bootable partition config begins
other = /dev/sda1
label = Windows
table = /dev/sda
# Windows bootable partition config ends
# Linux1 bootable partition config begins
image = /mnt/boot/vmlinuz
root = /dev/hdb2
label = slackware131
read-only
# Linux1 bootable partition config ends
Ultima modifica di pino il sab 20 nov 2010, 12:48, modificato 3 volte in totale.
man lilo.conf ha scritto:bmp-timer=<x>,<y> Optional specification of the 'timeout=' countdown timer. <x>,<y> specifies the character (or pixel) coordinate of the location of the timer [...]
Penso bmp-timer non sia ciò che credi.
Cosa è? Il problema, che non credo niente non ho la minima idea di che significa
Grazie pino
bmp-timer, che e' opzionale quindi almeno come test potresti direi farne a meno, dovrebbe definire
la posizione e altre caratteristiche(il colore) del timer del lilo.
Dal man di lilo.conf sembra volere delle coordinate, quindi il tuo 300 non viene interpretato in nessun modo.
Coomentalo o metti delle coordinate, qui trovi un esempio: https://wiki.archlinux.org/index.php/Graphical_Lilo
