Problemi hard disk err 71
darkstaring
Messaggio da darkstaring »
Salve a tutti.... oggi il mio hdd esterno "WD 3200bevt" ha deciso di non funzionare più.... da dmesg riesco a veder questo
[  992.628056] usb 5-1: new full speed USB device using uhci_hcd and address 6
[  992.741056] usb 5-1: device descriptor read/64, error -71
[  992.955059] usb 5-1: device descriptor read/64, error -71
[  993.158152] usb 5-1: new full speed USB device using uhci_hcd and address 7
[  993.272160] usb 5-1: device descriptor read/64, error -71
[  993.537086] usb 5-1: device descriptor read/64, error -71
[  993.740074] usb 5-1: new full speed USB device using uhci_hcd and address 8
[  994.148060] usb 5-1: device not accepting address 8, error -71
[  994.250120] usb 5-1: new full speed USB device using uhci_hcd and address 9
[  994.659062] usb 5-1: device not accepting address 9, error -71
[  994.659086] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1004.558080] usb 5-1: new full speed USB device using uhci_hcd and address 10
[ 1004.671094] usb 5-1: device descriptor read/64, error -71
[ 1004.886048] usb 5-1: device descriptor read/64, error -71
[ 1005.089079] usb 5-1: new full speed USB device using uhci_hcd and address 11
[ 1005.202087] usb 5-1: device descriptor read/64, error -71
[ 1005.416083] usb 5-1: device descriptor read/64, error -71
[ 1005.619081] usb 5-1: new full speed USB device using uhci_hcd and address 12
[ 1006.028086] usb 5-1: device not accepting address 12, error -71
[ 1006.130067] usb 5-1: new full speed USB device using uhci_hcd and address 13
[ 1006.538062] usb 5-1: device not accepting address 13, error -71
[ 1006.538083] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1007.767094] usb 5-1: new full speed USB device using uhci_hcd and address 14
[ 1007.880077] usb 5-1: device descriptor read/64, error -71
[ 1008.094071] usb 5-1: device descriptor read/64, error -71
[ 1008.297068] usb 5-1: new full speed USB device using uhci_hcd and address 15
[ 1008.410094] usb 5-1: device descriptor read/64, error -71
[ 1008.624091] usb 5-1: device descriptor read/64, error -71
[ 1008.827090] usb 5-1: new full speed USB device using uhci_hcd and address 16
[ 1009.235060] usb 5-1: device not accepting address 16, error -71
[ 1009.337088] usb 5-1: new full speed USB device using uhci_hcd and address 17
[ 1009.745089] usb 5-1: device not accepting address 17, error -71
[ 1009.745110] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1014.191033] usb 5-1: new full speed USB device using uhci_hcd and address 18
[ 1014.304055] usb 5-1: device descriptor read/64, error -71
[ 1014.467219] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1014.956102] usb 5-1: new full speed USB device using uhci_hcd and address 19
[ 1015.069090] usb 5-1: device descriptor read/64, error -71
[ 1015.283056] usb 5-1: device descriptor read/64, error -71
[ 1015.435076] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1017.783070] usb 5-1: new full speed USB device using uhci_hcd and address 21
[ 1017.896191] usb 5-1: device descriptor read/64, error -71
[ 1018.109091] usb 5-1: device descriptor read/64, error -71
[ 1018.261192] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1022.652044] usb 5-1: new full speed USB device using uhci_hcd and address 23
[ 1022.765072] usb 5-1: device descriptor read/64, error -71
[ 1022.980106] usb 5-1: device descriptor read/64, error -71
[ 1023.183043] usb 5-1: new full speed USB device using uhci_hcd and address 24
[ 1023.296065] usb 5-1: device descriptor read/64, error -71
[ 1023.561050] usb 5-1: device descriptor read/64, error -71
[ 1023.764046] usb 5-1: new full speed USB device using uhci_hcd and address 25
[ 1024.172059] usb 5-1: device not accepting address 25, error -71
[ 1024.274057] usb 5-1: new full speed USB device using uhci_hcd and address 26
[ 1024.682058] usb 5-1: device not accepting address 26, error -71
[ 1024.682081] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1418.545041] usb 5-1: new full speed USB device using uhci_hcd and address 27
[ 1418.658047] usb 5-1: device descriptor read/64, error -71
[ 1418.821078] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1423.215040] usb 5-1: new full speed USB device using uhci_hcd and address 28
[ 1423.328034] usb 5-1: device descriptor read/64, error -71
[ 1423.542178] usb 5-1: device descriptor read/64, error -71
[ 1423.694110] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1432.304055] usb 5-1: new full speed USB device using uhci_hcd and address 30
[ 1432.417154] usb 5-1: device descriptor read/64, error -71
[ 1432.632070] usb 5-1: device descriptor read/64, error -71
[ 1432.835100] usb 5-1: new full speed USB device using uhci_hcd and address 31
[ 1432.949052] usb 5-1: device descriptor read/64, error -71
[ 1433.163098] usb 5-1: device descriptor read/64, error -71
[ 1433.366080] usb 5-1: new full speed USB device using uhci_hcd and address 32
[ 1433.774069] usb 5-1: device not accepting address 32, error -71
[ 1433.876176] usb 5-1: new full speed USB device using uhci_hcd and address 33
[ 1434.285093] usb 5-1: device not accepting address 33, error -71
[ 1434.285116] hub 5-0:1.0: unable to enumerate USB device on port 1
Mentre il device non mi compare propio neanche con win.
Tempo fà vidi una discussione dove si aveva un problema simile, ma non riesco a trovarla....
In pratica vorrei provare con dd... è possibile farlo se in /dev l'hd in questione non c'è?
Grazzzzzzzzie :D
zoros
Nome Cognome: Fabio`Zorba`
Kernel: 5.15.19smp
Desktop: Trinity R14.0.11
Re: Problemi hard disk err 71
Messaggio da zoros »
Ciao,
grazie alla tua segnalazione ho appena recuperato una pennina USB da 16GB :D ... pensavo ad un problema hardware perché non leggibile da nessun S.O. (il guasto si era verificato su un PC windows) ... codice di errore però diverso dal tuo: "error -62"
in rete la soluzione suggerita anche per il tuo errore è:
echo Y >/sys/module/usbcore/parameters/old_scheme_first
nel mio caso la penna è miracolosamente rinata ... i dati sono leggibili, vediamo se rimane ok nel tempo ... intanto thanks all \:D/
darkstaring
La cosa è strana... L'hard disk funziona correttamente su un'altro box... Non so se conoscete gli hard disk LaCie (li scosiglio a tutti)...
Appena acquistati hanno all'interno un'utility che permette il partizionamento.. come ho aperto il programma da windows ero contento
avendo visto Linux.. finalmente i grossi produttori hw aggiungono qualcosa per gli utenti linux...
Ho pensato male :D..
Come il partizionamento è terminato quel box è diventato inutilizzabile ma l'hard disk funziona correttamente!
E non sono il solo, è successo anche al mio prof di info, stesso hard disk, stesso trattamento, stesso problema...
Almeno a lui l'hanno cambiato.. io avevo perso lo scontrino :( ..
Secondo voi è possibile che sia un progr danneggi un box?
Comunque quando potro proverò a modificare old_scheme_first..
Grazie :)
