[RISOLTO] gparted-0.8.1
kimotori
Desktop: MATE
Messaggio da kimotori »
Buon giorno a tutti
Avrei un problemino sulla compilazione di gparted; attualmente uso la slack32bit 13.37 kernel 2.6.37.6 (mio)
al seguito del ./configure compare questo strano problema:
checking for a BSD-compatible install... /bin/ginstall -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking build system type... i486-slackware-linux-gnu
checking host system type... i486-slackware-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/i486-slackware-linux/bin/ld
checking if the linker (/usr/i486-slackware-linux/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/i486-slackware-linux/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... /lib/cpp
configure: error: in `/home/kimotori/Desktop/gparted-0.8.1':
configure: error: C preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details
non capisco perchè.. eppure ho tutto il necessario.. o... almeno credo. ....sanity check? Qualche idea?
Devo reinstallare gcc?
Ultima modifica di kimotori il sab 29 set 2012, 14:31, modificato 1 volta in totale.
Loris
Admin
Admin
Nome Cognome: Loris Vincenzi
Re: gparted-0.8.1
Messaggio da Loris »
kimotori
Desktop: MATE
Re: gparted-0.8.1
Grazie loris, ma gradivo capire perchè :)
Re: gparted-0.8.1
dai una occhiata a config.log e manda la riga ./configure completa che hai usato.
kimotori
Desktop: MATE
Re: gparted-0.8.1
nella riga del configure non ho messo opzioni
ho provato anche con questa generica:
CFLAGS="-O2 -march=i486 -mcpu=i686" ./configure --prefix=/usr --disable-static
ed anche questa
CFLAGS="-O2 -march=i686" ./configure --prefix=/usr --disable-static
tutto uguale
config.log
ecco il log
(23.53 KiB) Scaricato 221 volte
Re: gparted-0.8.1
Hai una installazione full di slackware?
http://www.linuxquestions.org/questions ... me-823806/
kimotori
Desktop: MATE
Re: [RISOLTO] gparted-0.8.1
Me ne ero dimenticato, Grazie @ZeroUno.
